Re: precommit hook client side [message #553648 is a reply to message #553544] |
Wed, 18 August 2010 10:27 |
olly2 Mising name Messages: 27 Registered: June 2010 |
Hello Sasha,
to answer you question directly: no, it is not possible.
To make some suggestions how you could solve your problem using subversion:
- Include the style check in your make/build enviroment.
If you have some kind of build system (nightly build, a Hudson server, a make file, Ant Tasks ....) use this to generate the necessary checks into a report including somethink like an overall report. I would suggest an appraoch like this:
- when working on the trunk deviations are allowed
- when creating a release branch (you may find some nomenclature for the naming of branches helpful in this case ) deviations to the code styling rules are no longer allowed and an email is send in this case to the team including the deviation report. If you have a nightly build you can add this task there.
- when creasting a baseline (using a tag, again you should introduce naming conventions for tags) and there is still a deviation this is reported to some QA or Management persons, e.g by mail.
- Use a intelligent pre commit hook.
You can get some information about the commit in your pre commit hook including the repository path where the commit is happening. Just check this path and then perform your checks depending on this results.
In my opinion there is no need to introduce a client site pre commit hook, and from a conceptional point of view I think this is difficult and not stabel. So, think over your development process. Where could this check be implemented? And try to give yourselfe a NOT TECHNICAL TOOL answer! When you know this then think of an efficient technical solution.
Sorry for this epical answer but as a process person in my company it is very difficult for me not to think in this direction - so my answers are sometimes a little like "have a look to the whole thing" .. Sorry ..
Olaf
Re: precommit hook client side [message #1761406 is a reply to message #1726585] |
Wed, 10 May 2017 16:10 |
Aruna Chen Messages: 1 Registered: May 2017 |
I am using eclipse-SDK Mars(4.5) Plug-in development environment to create the plugin, and then install the plug-in in the Eclipse IDE for Developers Mars(4.5.2) through the dropins directory in eclipse folder.
I have tried to implement the precommit-hook for SVN using the above code to extend the DefaultCommitActionFactory, and returns DefaultDialog.DIALOG_FAILED; statement, but after I install my plugin and test ( by right click file and team->commit ), the commit Dialog shows up as usual, and allows me to commit changes to the svn repo.
I have also tried to implement the class ICommitActionFactory interface, but still couldn't prevent the commit dialog from showing up.
I know the plugin is installed properly, so I don't know why the method for commit dialog is not being overridden by my plugin.
here is my code, any help with this will be appreciated!
package testtwo;
import java.util.Collection;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.team.svn.core.operation.CompositeOperation;
import org.eclipse.team.svn.core.operation.IActionOperation;
import org.eclipse.team.svn.core.operation.IRevisionProvider;
import org.eclipse.team.svn.ui.dialog.DefaultDialog;
import org.eclipse.team.svn.ui.extension.factory.ICommentDialogPanel;
import org.eclipse.team.svn.ui.extension.factory.ICommitActionFactory;
import org.eclipse.team.svn.ui.extension.factory.ICommitDialog;
import org.eclipse.team.svn.ui.extension.impl.DefaultCommitActionFactory;
import org.eclipse.ui.IWorkbenchPart;
public class CommitActionFactory1 extends DefaultCommitActionFactory {
public ICommitDialog getCommitDialog(final Shell shell, Collection allFilesToCommit,
final ICommentDialogPanel commentPanel) {
return new ICommitDialog() {
public String getMessage() {
return commentPanel.getMessage();
public int open() {
boolean isCommitValid = performSomeValidation();
if (!isCommitValid) {
return DefaultDialog.DIALOG_FAILED;
return new DefaultDialog(shell, commentPanel).open();
private boolean performSomeValidation() {
// TODO Auto-generated method stub
return false;
FUDForum. Page generated in 0.04139 seconds
