Testing Text style [message #553542] |
Tue, 17 August 2010 21:24 |
St Clair Clarke Messages: 118 Registered: March 2010 |
I have successfully tested the style of a Combo by following the ComboTest in the XWT test examples.
However when I apply a similar style test for a Text widget, no error is picked up by JUNIT.
To check the style with a Combo the following statement is use:
public void checkComboStyle( String name, int style )
Object element = findElementByName( root, name );
assertTrue( element instanceof Combo );
Combo combo = ( Combo ) element;
[B]assertTrue( ( combo.getStyle() & style ) == style );[/B]
} // end method checkComboStyle
The above works for different styles.
For text, I use the following below:
public void checkTextStyle( String name, int style )
assertTrue( element instanceof Text );
Text text = ( Text ) element;
[B]assertTrue( ( text.getStyle() & style ) == style );[/B]
} // end method checkTextStyle
public void run()
checkTextStyle( "firstNameText", BORDER );
checkTextStyle( "middleNameText", BORDER );
// the style is actually BORDER, but the test runs with an
// error!
[B]checkTextStyle( "lastNameText", DROP_DOWN );[/B]
} // end method run
Note that
still pases the test for a Text although it cannot have a dropdown style.
What am I doing wrong please.
St Clair
Re: Testing Text style [message #553798 is a reply to message #553542] |
Wed, 18 August 2010 21:41 |
Yves YANG Messages: 688 Registered: July 2009 |
Please debug your code to see what is wrong. Just for your information, some
style bits are ignored by SWT.
Best regards
Yves YANG
"St Clair Clarke" <st_clair@flowja.com> wrote in message
news:i4eum3$4sb$1@build.eclipse.org...
> Hello,
> picked up by JUNIT.
> public void run()
> // error!
> } // end method run
> Note that
> Thanks
> St Clair
FUDForum. Page generated in 0.03156 seconds
