Home » Modeling » EMF » Multiple Inheritance - Some mix-ins not created?
Multiple Inheritance - Some mix-ins not created? [message #553288] |
Tue, 17 August 2010 01:12 |
Kirsten M. Z. Messages: 132 Registered: July 2010 |
Hi @all,
I have read through several documents and even some old posts on this forum about EMF and multiple inheritance. And, of course, I know the problems of mapping multiple inheritance to technical realization, e.g. Java code.
What I could get from the documents I found (please feel free to add references to more detailed material here), EMF model code generation is doing its best and creates mixins.
However, I wonder why my model code still has some unimplemented code (which means that I don't even get an placeholder). My unqualified assumption is that there is a problem with mixing a special category of references. However, it could be my fault, and my use case simply violates all rules again (*sigh*).
Stuff for reproducing the problem (Topcased 4.0.0 - Eclipse 3.6.0):
Ecore File:
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="test"
nsURI="test" nsPrefix="test">
<eClassifiers xsi:type="ecore:EClass" name="NewClass" eSuperTypes=" platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Mult iplicityElement platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Name dElement "/>
</ecore:EPackage>
GenModel File:
(default - no modification)
Now generate Model code.
Errors (Java Compiler):
Description Resource Path Location Type
The type NewClassImpl must implement the inherited abstract method NamedElement.createNameExpression(String, Type) NewClassImpl.java /TestProjekt/src/test/impl line 64 Java Problem
The type NewClassImpl must implement the inherited abstract method NamedElement.getClientDependency(String, boolean, EClass) NewClassImpl.java /TestProjekt/src/test/impl line 64 Java Problem
The type NewClassImpl must implement the inherited abstract method NamedElement.getClientDependency(String) NewClassImpl.java /TestProjekt/src/test/impl line 64 Java Problem
I would expect that the missing methods are at least generated in a form many others are, e.g.:
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public String getQualifiedName() {
// TODO: implement this method to return the 'Qualified Name' attribute
// Ensure that you remove @generated or mark it @generated NOT
throw new UnsupportedOperationException();
Kirsten
Re: Multiple Inheritance - Some mix-ins not created? [message #553295 is a reply to message #553288] |
Tue, 17 August 2010 02:19 |
Ed Merks Messages: 33142 Registered: July 2009 |
Kirsten,
Comments below.
vultur wrote:
> Hi @all,
> e.g. Java code.
> Ecore File:
> iplicityElement
> </ecore:EPackage>
> GenModel File:
> Problem
> Problem
> * @generated
> attribute
UML is generated from an extended GenModel so I think extensions of UML2
need to use that extended GenModel as well. Have a look at UML2's
GenModel. I think you can turn your existing *.genmodel into a UML2 one
just by changing the namespace of the xmlns declaration...
> Kirsten
Ed Merks
Re: Multiple Inheritance - Some mix-ins not created? [message #553459 is a reply to message #553395] |
Tue, 17 August 2010 15:07 |
Kirsten,
I thought the details of how to extend UML2 were document somewhere. If
not, you'll need to ask about it on the UML2 newsgroup.
>> UML2 need to use that extended GenModel as well. Have a look at
>> UML2's GenModel. I think you can turn your existing *.genmodel into a
>> UML2 one just by changing the namespace of the xmlns declaration...
> I changed the namespace to
> xmlns:genmodel="http://www.eclipse.org/uml2/2.2.0/GenModel"
> Then I was able to adjust some additional UML2 settings for
> generation... However, I was not able to generate working code,
> neither with the simple xmlns change, nor a complete customization of
> my *.genmodel file (and I checked the original uml.genmodel file for
> its settings). The more changes I made, the more errors I got. The
> method "createNameExpression", for example, has never been generated.
> In my opinion, only some step-by-step instructions would help me (and
> possibly some other people) generating their UML extensions.
> Otherwise, I am like a blind person stumbling in the darkness of
> hundreds of generation settings.
Ed Merks
Current Time: Fri Apr 26 06:46:09 GMT 2024
Powered by FUDForum. Page generated in 0.04426 seconds
