Home » Language IDEs » PHP Development Tools (PDT) » not break with xdebug(not break either at first line or the break point.)
not break with xdebug [message #553225] |
Mon, 16 August 2010 17:26 |
ccc123 Messages: 7 Registered: August 2010 |
Junior Member |
installed xdebug and not stop when start debug from elipse PDT.
the debug window shows STOP button but step in/step out/step over all are grayed out. the webpage is showing as a full run.
here are the settings:
1) Eclipse for PHP Developers
Version: Helios Release
Build id: 20100617-1415
2) from apache php.ini, i added the following lines:
[PHP]
[XDebug]
;; Only Zend OR (!) XDebug
zend_extension ="C:\wamp\bin\php\php5.3.0\ext\php_xdebug-2.1.0-5.3-vc6.dll "
xdebug.remote_enable=true
xdebug.remote_host=127.0.0.1
xdebug.remote_port=11001
xdebug.remote_handler=dbgp
xdebug.profiler_enable=1
xdebug.profiler_output_dir="C:\wamp\tmp"
xdebug.remote_log="c:\wamp\tmp\xdebug_remote.log"
3) os is windows xp sp3, apache 2.2.11 is installed from wamp
4) phpinfo():
PHP Version 5.3.0
System Windows NT SUP-JIANG 5.1 build 2600 (Windows XP Professional Service Pack 3) i586
Build Date Jun 29 2009 21:23:30
Compiler MSVC6 (Visual C++ 6.0)
Architecture x86
Configure Command cscript /nologo configure.js "--enable-snapshot-build" "--disable-isapi" "--enable-debug-pack" "--with-pdo-oci=D:\php-sdk\oracle\instantclient10\sdk,shared " "--with-oci8=D:\php-sdk\oracle\instantclient10\sdk,shared" " --with-oci8-11g=D:\php-sdk\oracle\instantclient11\sdk,shared " "--with-enchant=shared"
Server API Apache 2.0 Handler
Virtual Directory Support enabled
Configuration File (php.ini) Path C:\WINDOWS
Loaded Configuration File C:\wamp\bin\apache\Apache2.2.11\bin\php.ini
Scan this dir for additional .ini files (none)
Additional .ini files parsed (none)
PHP API 20090626
PHP Extension 20090626
Zend Extension 220090626
Zend Extension Build API220090626,TS,VC6
PHP Extension Build API20090626,TS,VC6
Debug Build no
Thread Safety enabled
Zend Memory Manager enabled
Zend Multibyte Support disabled
IPv6 Support enabled
Registered PHP Streams php, file, glob, data, http, ftp, zip, compress.zlib, phar
Registered Stream Socket Transports tcp, udp
Registered Stream Filters convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, zlib.*
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.3.0, Copyright (c) 1998-2009 Zend Technologies
with Xdebug v2.1.0, Copyright (c) 2002-2010, by Derick Rethans
PHP Credits
Configuration
apache2handler
Apache Version Apache/2.2.11 (Win32) PHP/5.3.0
Apache API Version 20051115
Server Administrator admin@localhost
Hostname:Port localhost:80
Max Requests Per Child: 0 - Keep Alive: on - Max Per Connection: 100
Timeouts Connection: 300 - Keep-Alive: 5
Virtual Server No
Server Root C:/wamp/bin/apache/Apache2.2.11
Loaded Modules core mod_win32 mpm_winnt http_core mod_so mod_actions mod_alias mod_asis mod_auth_basic mod_authn_default mod_authn_file mod_authz_default mod_authz_groupfile mod_authz_host mod_authz_user mod_autoindex mod_cgi mod_dir mod_env mod_include mod_isapi mod_log_config mod_mime mod_negotiation mod_setenvif mod_version mod_php5
Directive Local Value Master Value
engine 1 1
last_modified 0 0
xbithack 0 0
Apache Environment
Variable Value
HTTP_HOST 127.0.0.1
HTTP_USER_AGENT Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.3) Gecko/20090824 Firefox/3.5.3 (.NET CLR 3.5.30729) FirePHP/0.4
HTTP_ACCEPT text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q= 0.8
HTTP_ACCEPT_LANGUAGE en-us
HTTP_ACCEPT_ENCODING gzip,deflate
HTTP_ACCEPT_CHARSET ISO-8859-1,utf-8;q=0.7,*;q=0.7
HTTP_KEEP_ALIVE 300
HTTP_CONNECTION keep-alive
HTTP_COOKIE zenid=3rdjbmedli6fkumr74fc3e49n6
PATH C:\Python26\Scripts;C:\Python26\;C:\Program Files\Java\jdk1.5.0_22\bin;C:\Perl\site\bin;C:\Perl\bin;C:\T cl\bin;C:\TclDevKit\bin;C:\Program Files\ActiveState Komodo IDE 5\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C :\Program Files\Windows Imaging\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files\Symantec\pcAnywhere\;C:\WINDOWS\system32\WindowsPowerS hell\v1.0;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\VisualSVN\bin;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Borland\SC Test Manager 2009\bin;C:\Cygwin\bin;C:\Program Files\jEdit4
SystemRoot C:\WINDOWS
COMSPEC C:\WINDOWS\system32\cmd.exe
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1;.tcl; .py;.pyw
WINDIR C:\WINDOWS
SERVER_SIGNATURE no value
SERVER_SOFTWARE Apache/2.2.11 (Win32) PHP/5.3.0
SERVER_NAME 127.0.0.1
SERVER_ADDR 127.0.0.1
SERVER_PORT 80
REMOTE_ADDR 127.0.0.1
DOCUMENT_ROOT C:/wamp/www/
SERVER_ADMIN admin@localhost
SCRIPT_FILENAME C:/wamp/www/zencart2/phpinfo.php
REMOTE_PORT 4636
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /zencart2/phpinfo.php
SCRIPT_NAME /zencart2/phpinfo.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /zencart2/phpinfo.php HTTP/1.1
Host 127.0.0.1
User-Agent Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.3) Gecko/20090824 Firefox/3.5.3 (.NET CLR 3.5.30729) FirePHP/0.4
Accept text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q= 0.8
Accept-Language en-us
Accept-Encoding gzip,deflate
Accept-Charset ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive 300
Connection keep-alive
Cookie zenid=3rdjbmedli6fkumr74fc3e49n6
HTTP Response Headers
X-Powered-By PHP/5.3.0
bcmath
BCMath support enabled
bcmath.scale 0 0
calendar
Calendar support enabled
com_dotnet
COM support enabled
DCOM support disabled
.Net support not present in this build
com.allow_dcom 0 0
com.autoregister_casesensitive 1 1
com.autoregister_typelib 0 0
com.autoregister_verbose 0 0
com.code_page no value no value
com.typelib_file no value no value
Core
PHP Version 5.3.0
allow_call_time_pass_reference Off Off
allow_url_fopen On On
allow_url_include Off Off
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors On On
display_startup_errors On On
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl Off Off
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 30719 30719
exit_on_timeout Off Off
expose_php On On
extension_dir c:/wamp/bin/php/php5.3.0/ext/ c:/wamp/bin/php/php5.3.0/ext/
file_uploads On On
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush On On
include_path .;C:\php5\pear .;C:\php5\pear
log_errors On On
log_errors_max_len 1024 1024
magic_quotes_gpc Off Off
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.add_x_header On On
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 30 30
max_input_nesting_level 64 64
max_input_time 60 60
memory_limit 128M 128M
open_basedir no value no value
output_buffering 1 1
output_handler no value no value
post_max_size 8M 8M
precision 14 14
realpath_cache_size 16K 16K
realpath_cache_ttl 120 120
register_argc_argv Off Off
register_globals Off Off
register_long_arrays Off Off
report_memleaks On On
report_zend_debug On On
request_order GP GP
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from you@yourdomain you@yourdomain
sendmail_path no value no value
serialize_precision 100 100
short_open_tag Off Off
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors On On
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir c:/wamp/tmp c:/wamp/tmp
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order GPCS GPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
zend.enable_gc On On
ctype
ctype functions enabled
curl
cURL support enabled
cURL Information 7.19.4
Age 3
Features
AsynchDNS No
Debug No
GSS-Negotiate No
IDN No
IPv6 Yes
Largefile Yes
NTLM Yes
SPNEGO No
SSL Yes
SSPI Yes
krb4 No
libz Yes
CharConv No
Protocols tftp, ftp, telnet, dict, ldap, http, file, https, ftps
Host i386-pc-win32
SSL Version OpenSSL/0.9.8k
ZLib Version 1.2.3
date
date/time support enabled
"Olson" Timezone Database Version 2009.10
Timezone Database internal
Default timezone UTC
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone UTC UTC
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.7.3
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
ereg
Regex Library Bundled library enabled
filter
Input Validation and Filtering enabled
Revision $Revision: 1.52.2.39.2.16 $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
gd
GD Support enabled
GD Version bundled (2.0.34 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.3.9
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 6b
PNG Support enabled
libPNG Version 1.2.37
WBMP Support enabled
XBM Support enabled
gd.jpeg_ignore_warning 0 0
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost adler32 crc32 crc32b salsa10 salsa20 haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support enabled
iconv implementation "libiconv"
iconv library version 1.11
iconv.input_encoding ISO-8859-1 ISO-8859-1
iconv.internal_encoding ISO-8859-1 ISO-8859-1
iconv.output_encoding ISO-8859-1 ISO-8859-1
json
json support enabled
json version 1.2.1
libxml
libXML support active
libXML Compiled Version 2.7.3
libXML Loaded Version 20703
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation disabled
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) version 4.7.1
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input pass pass
mbstring.http_output pass pass
mbstring.http_output_conv_mimetypes ^(text/|application/xhtml\+xml) ^(text/|application/xhtml\+xml)
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mcrypt
mcrypt support enabled
Version 2.5.8
Api No 20021217
Supported ciphers cast-128 gost rijndael-128 twofish cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes arcfour
Supported modes cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir no value no value
mcrypt.modes_dir no value no value
mhash
MHASH support Enabled
MHASH API Version Emulated Support
mysql
MySQL Support enabled
Active Persistent Links 0
Active Links 0
Client API version mysqlnd 5.0.5-dev - 081106 - $Revision: 1.3.2.27 $
Persistent cache enabled
put_hits 0
put_misses 0
get_hits 0
get_misses 0
size 2000
free_items 2000
references 2
mysql.allow_local_infile On On
mysql.allow_persistent On On
mysql.cache_size 2000 2000
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket no value no value
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Off
mysqli
MysqlI Support enabled
Client API library version mysqlnd 5.0.5-dev - 081106 - $Revision: 1.3.2.27 $
Inactive Persistent Links 0
Active Links 0
put_hits 0
put_misses 0
get_hits 0
get_misses 0
size 2000
free_items 2000
references 2
mysqli.allow_local_infile On On
mysqli.allow_persistent On On
mysqli.cache_size 2000 2000
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.max_persistent Unlimited Unlimited
mysqli.reconnect Off Off
mysqlnd
mysqlnd enabled
Version mysqlnd 5.0.5-dev - 081106 - $Revision: 1.3.2.27 $
Command buffer size 2048
Read buffer size 32768
Collecting statistics Yes
Collecting memory statistics Yes
Client statistics
bytes_sent 135131
bytes_received 590795
packets_sent 773
packets_received 14018
protocol_overhead_in 56072
protocol_overhead_out 3092
bytes_received_ok_packet 11088
bytes_received_eof_packet 4491
bytes_received_rset_header_packet 5405
bytes_received_rset_field_meta_packet 123516
bytes_received_rset_row_packet 433090
bytes_received_prepare_response_packet 0
bytes_received_change_user_packet 0
packets_sent_command 619
packets_received_ok 168
packets_received_eof 499
packets_received_rset_header 577
packets_received_rset_field_meta 1629
packets_received_rset_row 10991
packets_received_prepare_response 0
packets_received_change_user 0
result_set_queries 485
non_result_set_queries 92
no_index_used 0
bad_index_used 0
slow_queries 0
buffered_sets 485
unbuffered_sets 0
ps_buffered_sets 0
ps_unbuffered_sets 0
flushed_normal_sets 0
flushed_ps_sets 0
ps_prepared_never_executed 0
ps_prepared_once_executed 0
rows_fetched_from_server_normal 10506
rows_fetched_from_server_ps 0
rows_buffered_from_client_normal 10506
rows_buffered_from_client_ps 0
rows_fetched_from_client_normal_buffered 10502
rows_fetched_from_client_normal_unbuffered 0
rows_fetched_from_client_ps_buffered 0
rows_fetched_from_client_ps_unbuffered 0
rows_fetched_from_client_ps_cursor 0
rows_skipped_normal 10506
rows_skipped_ps 0
copy_on_write_saved 5914
copy_on_write_performed 17142
command_buffer_too_small 0
connect_success 14
connect_failure 140
connection_reused 0
reconnect 0
pconnect_success 0
active_connections 0
active_persistent_connections 0
explicit_close 14
implicit_close 0
disconnect_close 0
in_middle_of_command_close 0
explicit_free_result 485
implicit_free_result 0
explicit_stmt_close 0
implicit_stmt_close 0
mem_emalloc_count 2665
mem_emalloc_ammount 2029739
mem_ecalloc_count 3064
mem_ecalloc_ammount 675976
mem_erealloc_count 10604
mem_erealloc_ammount 4424308
mem_efree_count 4278
mem_malloc_count 12526
mem_malloc_ammount 658936
mem_calloc_count 14
mem_calloc_ammount 5936
mem_realloc_count 0
mem_realloc_ammount 0
mem_free_count 13682
proto_text_fetched_null 0
proto_text_fetched_bit 0
proto_text_fetched_tinyint 8
proto_text_fetched_short 0
proto_text_fetched_int24 0
proto_text_fetched_int 1481
proto_text_fetched_bigint 58
proto_text_fetched_decimal 50
proto_text_fetched_float 72
proto_text_fetched_double 0
proto_text_fetched_date 0
proto_text_fetched_year 0
proto_text_fetched_time 0
proto_text_fetched_datetime 86
proto_text_fetched_timestamp 0
proto_text_fetched_string 11602
proto_text_fetched_blob 9641
proto_text_fetched_enum 0
proto_text_fetched_set 0
proto_text_fetched_geometry 0
proto_text_fetched_other 0
proto_binary_fetched_null 0
proto_binary_fetched_bit 0
proto_binary_fetched_tinyint 0
proto_binary_fetched_short 0
proto_binary_fetched_int24 0
proto_binary_fetched_int 0
proto_binary_fetched_bigint 0
proto_binary_fetched_decimal 0
proto_binary_fetched_float 0
proto_binary_fetched_double 0
proto_binary_fetched_date 0
proto_binary_fetched_year 0
proto_binary_fetched_time 0
proto_binary_fetched_datetime 0
proto_binary_fetched_timestamp 0
proto_binary_fetched_string 0
proto_binary_fetched_blob 0
proto_binary_fetched_enum 0
proto_binary_fetched_set 0
proto_binary_fetched_geometry 0
proto_binary_fetched_other 0
odbc
ODBC Support enabled
Active Links 0
ODBC library Win32
odbc.allow_persistent On On
odbc.check_persistent On On
odbc.default_cursortype Static cursor Static cursor
odbc.default_db no value no value
odbc.default_pw no value no value
odbc.default_user no value no value
odbc.defaultbinmode return as is return as is
odbc.defaultlrl return up to 4096 bytes return up to 4096 bytes
odbc.max_links Unlimited Unlimited
odbc.max_persistent Unlimited Unlimited
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 7.9 2009-04-11
pcre.backtrack_limit 100000 100000
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers mysql, sqlite
pdo_mysql
PDO Driver for MySQL enabled
put_hits 0
put_misses 0
get_hits 0
get_misses 0
size 2000
free_items 2000
references 2
pdo_mysql.cache_size 2000 2000
pdo_sqlite
PDO Driver for SQLite 3.x enabled
SQLite Library 3.6.15
Phar
Phar: PHP Archive support enabled
Phar EXT version 2.0.0-dev
Phar API version 1.1.1
CVS revision $Revision: 1.370.2.62 $
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression disabled (install pecl/bz2)
OpenSSL support disabled (install ext/openssl)
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
Reflection
Reflection enabled
Version $Revision: 1.164.2.33.2.45.2.58 $
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php php_binary wddx
session.auto_start Off Off
session.bug_compat_42 On On
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly Off Off
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.hash_bits_per_character 5 5
session.hash_function 0 0
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path c:/wamp/tmp c:/wamp/tmp
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies On On
session.use_trans_sid 0 0
SimpleXML
Simplexml support enabled
Revision $Revision: 1.151.2.22.2.35.2.32 $
Schema support enabled
SPL
SPL support enabled
Interfaces Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Dynamic Library Support enabled
Internal Sendmail Support for Windows enabled
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,input=src,form=fakeentry a=href,area=href,frame=src,input=src,form=fakeentry
user_agent no value no value
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xdebug
xdebug support enabled
Version 2.1.0
Supported protocols Revision
DBGp - Common DeBuGger Protocol $Revision: 1.145 $
xdebug.auto_trace Off Off
xdebug.collect_assignments Off Off
xdebug.collect_includes On On
xdebug.collect_params 0 0
xdebug.collect_return Off Off
xdebug.collect_vars Off Off
xdebug.default_enable On On
xdebug.dump.COOKIE no value no value
xdebug.dump.ENV no value no value
xdebug.dump.FILES no value no value
xdebug.dump.GET no value no value
xdebug.dump.POST no value no value
xdebug.dump.REQUEST no value no value
xdebug.dump.SERVER no value no value
xdebug.dump.SESSION no value no value
xdebug.dump_globals On On
xdebug.dump_once On On
xdebug.dump_undefined Off Off
xdebug.extended_info On On
xdebug.file_link_format no value no value
xdebug.idekey no value no value
xdebug.manual_url http://www.php.net http://www.php.net
xdebug.max_nesting_level 100 100
xdebug.overload_var_dump On On
xdebug.profiler_aggregate Off Off
xdebug.profiler_append Off Off
xdebug.profiler_enable On On
xdebug.profiler_enable_trigger Off Off
xdebug.profiler_output_dir C:\wamp\tmp C:\wamp\tmp
xdebug.profiler_output_name cachegrind.out.%p cachegrind.out.%p
xdebug.remote_autostart Off Off
xdebug.remote_connect_back Off Off
xdebug.remote_cookie_expire_time 3600 3600
xdebug.remote_enable On On
xdebug.remote_handler dbgp dbgp
xdebug.remote_host 127.0.0.1 127.0.0.1
xdebug.remote_log c:\wamp\tmp\xdebug_remote.log c:\wamp\tmp\xdebug_remote.log
xdebug.remote_mode req req
xdebug.remote_port 11001 11001
xdebug.scream Off Off
xdebug.show_exception_trace Off Off
xdebug.show_local_vars Off Off
xdebug.show_mem_delta Off Off
xdebug.trace_format 0 0
xdebug.trace_options 0 0
xdebug.trace_output_dir \ \
xdebug.trace_output_name trace.%c trace.%c
xdebug.var_display_max_children 128 128
xdebug.var_display_max_data 512 512
xdebug.var_display_max_depth 3 3
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.7.3
xmlreader
XMLReader enabled
xmlwriter
XMLWriter enabled
zip
Zip enabled
Extension Version $Id: php_zip.c,v 1.1.2.38.2.29 2009/02/24 23:55:14 iliaa Exp $
Zip version 1.9.1
Libzip version 0.9.0
zlib
ZLib Support enabled
Stream Wrapper support compress.zlib://
Stream Filter support zlib.inflate, zlib.deflate
Compiled Version 1.2.3
Linked Version 1.2.3
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
Environment
Variable Value
ALLUSERSPROFILE C:\Documents and Settings\All Users
CLASSPATH .;C:\Program Files\Java\jre1.6.0_07\lib\ext\QTJava.zip
CommonProgramFiles C:\Program Files\Common Files
COMPUTERNAME SUP-JIANG
ComSpec C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK NO
NUMBER_OF_PROCESSORS 2
OS Windows_NT
Path C:\Python26\Scripts;C:\Python26\;C:\Program Files\Java\jdk1.5.0_22\bin;C:\Perl\site\bin;C:\Perl\bin;C:\T cl\bin;C:\TclDevKit\bin;C:\Program Files\ActiveState Komodo IDE 5\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C :\Program Files\Windows Imaging\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files\Symantec\pcAnywhere\;C:\WINDOWS\system32\WindowsPowerS hell\v1.0;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\VisualSVN\bin;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Borland\SC Test Manager 2009\bin;C:\Cygwin\bin;C:\Program Files\jEdit4
PROCESSOR_ARCHITECTURE x86
PROCESSOR_IDENTIFIER x86 Family 6 Model 23 Stepping 10, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 170a
QTJAVA C:\Program Files\Java\jre1.6.0_07\lib\ext\QTJava.zip
SILK_CONFIG_PATH C:\Program Files\Borland\SilkMeter\cfg
SystemDrive C:
TEMP C:\WINDOWS\TEMP
TestResult2 {faild:test log file.txt} { pass:testlog2.fe}
TMP C:\WINDOWS\TEMP
UATDATA C:\WINDOWS\system32\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A 1FE1BE77
USERPROFILE C:\Documents and Settings\LocalService
VS90COMNTOOLS C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools\
windir C:\WINDOWS
AP_PARENT_PID 21528
PHP Variables
Variable Value
_COOKIE["zenid"] 3rdjbmedli6fkumr74fc3e49n6
_SERVER["HTTP_HOST"] 127.0.0.1
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.3) Gecko/20090824 Firefox/3.5.3 (.NET CLR 3.5.30729) FirePHP/0.4
_SERVER["HTTP_ACCEPT"] text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q= 0.8
_SERVER["HTTP_ACCEPT_LANGUAGE"] en-us
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_COOKIE"] zenid=3rdjbmedli6fkumr74fc3e49n6
_SERVER["PATH"] C:\Python26\Scripts;C:\Python26\;C:\Program Files\Java\jdk1.5.0_22\bin;C:\Perl\site\bin;C:\Perl\bin;C:\T cl\bin;C:\TclDevKit\bin;C:\Program Files\ActiveState Komodo IDE 5\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C :\Program Files\Windows Imaging\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files\Symantec\pcAnywhere\;C:\WINDOWS\system32\WindowsPowerS hell\v1.0;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\VisualSVN\bin;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Borland\SC Test Manager 2009\bin;C:\Cygwin\bin;C:\Program Files\jEdit4
_SERVER["SystemRoot"] C:\WINDOWS
_SERVER["COMSPEC"] C:\WINDOWS\system32\cmd.exe
_SERVER["PATHEXT"] .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1;.tcl; .py;.pyw
_SERVER["WINDIR"] C:\WINDOWS
_SERVER["SERVER_SIGNATURE"] no value
_SERVER["SERVER_SOFTWARE"] Apache/2.2.11 (Win32) PHP/5.3.0
_SERVER["SERVER_NAME"] 127.0.0.1
_SERVER["SERVER_ADDR"] 127.0.0.1
_SERVER["SERVER_PORT"] 80
_SERVER["REMOTE_ADDR"] 127.0.0.1
_SERVER["DOCUMENT_ROOT"] C:/wamp/www/
_SERVER["SERVER_ADMIN"] admin@localhost
_SERVER["SCRIPT_FILENAME"] C:/wamp/www/zencart2/phpinfo.php
_SERVER["REMOTE_PORT"] 4636
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_METHOD"] GET
_SERVER["QUERY_STRING"] no value
_SERVER["REQUEST_URI"] /zencart2/phpinfo.php
_SERVER["SCRIPT_NAME"] /zencart2/phpinfo.php
_SERVER["PHP_SELF"] /zencart2/phpinfo.php
_SERVER["REQUEST_TIME"] 1281978979
5) port number for xdebug is 11001, which is set from eclipse -> windows -> preference -> xdebug -> config
6) when run debug, the xdebug log reads as:
-> <init xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" fileuri="file:///C:/wamp/www/zencart2/index.php" language="PHP" protocol_version="1.0" appid="22228" idekey="ECLIPSE_DBGP"><engine version="2.1.0"><![CDATA[Xdebug]]></engine><author><![CDATA[Derick Rethans]]></author><url><![CDATA[http://xdebug.org]]></url><copyright><![CDATA[Copyright (c) 2002-2010 by Derick Rethans]]></copyright></init>
<- feature_set -i 1 -n show_hidden -v 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="1" feature="show_hidden" success="1"></response>
<- feature_set -i 2 -n max_depth -v 5
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="2" feature="max_depth" success="1"></response>
<- feature_set -i 3 -n max_children -v 31
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="3" feature="max_children" success="1"></response>
<- feature_get -i 4 -n encoding
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_get" transaction_id="4" feature_name="encoding" supported="1"><![CDATA[iso-8859-1]]></response>
<- feature_get -i 5 -n supports_async
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_get" transaction_id="5" feature_name="supports_async" supported="1"><![CDATA[0]]></response>
<- stdout -i 6 -c 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stdout" transaction_id="6" success="1"></response>
<- stderr -i 7 -c 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stderr" transaction_id="7" success="0"></response>
-> <stream xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" type="stdout" encoding="base64">< ![CDATA[H4sIAAAAAAAAA7xZbXPbNhL+fjP3Hza8OfeLJVpu7MaypEwjJxfP OIkbK/U1lxsNREIiGhDgAaBl5df0p3YXICVaL67jSS6OIxHAvj37gl2m9+Ts 3XD02+VLyFwu4fLDi4vzIUStOL7+cRjHZ6Mz+Pfr0ZsL6LQPYGSYssIJrZiM 45dvI4gy54puHM/n8/b8x7Y2s3j0Pr4lXh0irr62XIOynbo0Gvz9bz0v8TaX yva38OmcnJwE8ghSYfqRdCYCydSsH3EVGHCW0qcTTvIB0f5aqCvHuWwnOu/F YR0P5NwxIBEt/r9S3PSjoVaOK9caLQoeQRKe+pHjty4mkaeQZMxY7vrC6taz Z0cnrU4E8ZKXYjnvR5/5Yq5NahscXhnO4dfLt8BRg5ybhO+DLrgCq0v/YDNd 4JKSQnH/UAg1g03eKbeJEQVB1mB/zSXy5eA0rJsLXYAWPE5+U3wTJpGzGXda ywkzDS2U3tSXlS7TzUOjjMNHFDxkxu2h/1N+CiPOcmAqBe0ybuwmlxlX3DB3 h9ESpAQ5QWH0zCCXyWKd+z40gugLVy0675HhwwqLIBBFTpjlkBk+XUZe5/Cn 9gH+dGIkJcp4eRih+gyGS1TFLSS3GecuAoehU0VMYtGUwE2oRJbou9jxvJDM 4bffBcYsnYlX5G1PEg++C/MxPo4npXNa2a8VlPNUsH5UGKHcg8T6k+NtlsVV ehLcOl2ASIlVym9fYwS/wJUobKbixu/lTKhrw4qCm7AD4PcSySxWiJxbi9F4 5Vjy+ZoZRREhmZnR6Z7IZ2BNco+uPpRtLDCsbDwP9O2ZmEbAJCVWWEFAqGb0 I6hFRDAXqcv60eEB4sHFLHPhezyA+lAXzpV1TKI8TFeqVjzBGF4AvxXWWWCu C8PupznLi08YnJ+qCDv89CUZi0DZhkvJKSgNz/UNJngmbIPRVBuwPCmNcAs8 wiy5thcjPB4pj+OTVmuipy1CnRuQeqZ9qil2I2a1YhYxWbRad4EPFA3oa1Y7 SJeEuP/mrtPWt2gN8E+vlLUfJ+i/5bIUgx77y0QcUMT0YjboxUjwNaQ+3tpF Vjyn6BoXGAN9RIYUu9AzdFuDK2ofl5KMqHBdN+aKM5NkGG31/sTURiXoPPMC q1pV0uoTCCTfDeQK6QnejymF21acyZcNkL35zb3oQSA+PEluCjWmRGkXlBE+ P/xtc/l2ddv8J6N7iIrKf1dJc9+pVSYdP11lEn2PB8ELAbM71jk2o4tqzfjN A2hd1hlgmScMr7RWT7D8dO7yrH3y196rvLbVKavthyda5WRdhAYILzLHZ9oI bsGxid1F2Yy/IXMjPLoj1apdv+xDeJkftYVB4qLldBE9Jmn82h4WsNPkkqET O9GgbjXIeVDl0HoGreXB1yKwUdX4F9LGB5TdwOjlx0sK3xGaGCBYSwqKTgxt W0fnqq7sqYktTrvd8LmF9GEg0T8eI1ToEAH6+ZfvxBzRP9NzJTVLHyRh3fJ7 XLx0LzWRV9zciORhEG3IwDurzLE20B2NmT6eYO+Olf8VLRPHjejY6ePlPdfD YJG8riOdg4N/RjDBDpzjeIBXcsKltAVLBM0I1XPB0rR+pjip2sq1ewvNcaYu FC6FGybFTGF5CbFEGqKgKcAEL980QQsm4HW7U4wwBl/Q/pD2Q3TdMRLQyg0O dZR7/mVBPsWSyw32DcH6mnDLXhX/dZKjXdwMtSxzFa3arTM+ZaV0YWLqbKy/ RnWo8xmszRZNX+JgQUMELvmy2lA65QX2KJjNKZ5ByhJbmFL52UO50MVg30KJ 3cjVaKlxcEY0GNFB/ItjAVBEIt+pH1AcsvasqAOiXR8b9MAVVn6bwTzDMUBp qO+yijSFqcBQCR1YG84dsZc6qCpUF3rWGa1mg3h5G9JsWfoLsOK9SpNeXJ2u 3dkoT98Kg7Ng8gIHtYDBOUkPBie6WOCdaXh7XYGaX9OlFNzVhLspBmmamWur 1C3YomAhcZOZaE2Eiud8gjPo8yRP+2Pbuk2kSD7vZRqjIq3GizFKfvbyl5Pr w6cfLz8evTrGexgTEKdNmgf60RSFtqYsF3LRhVwrTdmJc2CzGdmhBFfjD1ex iCdO0e84xXvD8eFwfPGv0LZT10CyQvOAl3n8YNnhcEVN58CKL0hyeJ/6PziB IwgoPgejc6Z+2Ae/giM1N2JKjOtxHP5AlzMcuWXp0I80bOLIq+Ad5hCVVZYY bUOwU8hiNOe2i1VNpXqO/C6EKm/34Q1L4N3VPpydta7fj/ZhhFKdpu+A4f/H 0nrSstK78vXPRSF5yxvRovXocQb504RMF2yOMwqZSCaQCrX07PCbInidYfER UuIhhKzG8/marTFJLb6pYEwXRTmK3d4Uz6D3inKCAQ/X4pU4XZdffGvxHyxJ roXGNmMG7cc8KEos6e3vLv83XQKKxNES65xIqJRhIWNJgkM3XqPGUT2ieiBw WPj+cJxPqQzCnFH91DDh2GArrRa5Li0t2NJM/29aEC5YPREF5WGZhhJdGHHD ksUONUKJ+YbKbBNjeC1oSy8mS1mGch4qf/z0+Pj44OjhFbpRXWMSFSbk5iuH VeOCFaLgiWByrWlZX9/2sxoWXPW6CBuwerDxzcxorhv3GK28p+lxWdZ8P9iF ztFBcbsxGtUc6m5vO1FQolKBhkXfDuIHNZwb71g2xxXYmEauyqLYMa7R1mpW e+RLEE/2oKlrl7Yre0QB2CYbSva79lQcdu03XmBggmLv/o+j7Qx2bK/ogSqL b3MMuXYHrHRIqKm+4DMmlyEh6WlYk1Itr7nsEcNTODzoHDxy6vJrm0OMH47o aiKHtOFSzzkV7Mli61jUfE2/yWv9pUnzZUiN373w3EmiGs+C/vvCV5HtHrn3 gOdQ++x4B4Nd+zG97aVL2uUUlX8CAAD//wMAhIIyXGIaAAA=]] ></stream>
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stderr" transaction_id="7" status="stopping" reason="ok"></response>
6) i use netstat -a and it shows that the port number 11001 is active listening but not established. and webserver is running locally using 127.0.0.1. there is no firewall to block port 11001
7) when debug run, it open firefox session and the address is as:
http://localhost/zencart2/index.php?XDEBUG_SESSION_START=ECL IPSE_DBGP&KEY=12819783480022
it seems that this firefox session failed to connect to eclipse using port 11001? how to tell where is the problem from log?
Re: not break with xdebug [message #553331 is a reply to message #553240] |
Tue, 17 August 2010 07:55 |
Originally posted by: dkel50.hotremovemail.com
Try deleting all your breakpoints in your workspace, then re-create them.
Dave Kelsey
On 16/08/2010 20:06, cajsdy@gmail.com wrote:
> sorry triple post, admin please delete the other two. thanks.
> ok, i tried xdc-1.0b5, an windows client, set port to be 11001. and it
> works with apache/php server. so which means that eclipse setting has
> something wrong.
> the eclipse is a pdt downloaded and it suppose come with xdebug plug in
> already. not sure how to check.
Current Time: Fri Apr 26 14:04:06 GMT 2024
Powered by FUDForum. Page generated in 0.03490 seconds
