Home » Eclipse Projects » EclipseLink » An unexpected error > EXCEPTION_ACCESS_VIOLATION(This issue occurs when two entities refers each other)
An unexpected error > EXCEPTION_ACCESS_VIOLATION [message #552826] |
Fri, 13 August 2010 12:25  |
Hi, All!
Please would you provide your ideas on what could cause such behavior.
I have very simple model, and orm mapping. Two classes, Book and Writer, one Book contains reference to Writer, and Writer contains collection of books he wrote:
<orm:entity-mappings xmlns:orm="http://www.eclipse.org/eclipselink/xsds/persistence/orm" version="2.1">
<orm:access>FIELD</orm:access>
<orm:entity class="org.eclipse.emf.texo.test.model.samples.library.Book" name="Book">
<orm:attributes>
<orm:basic name="title" optional="true"/>
<orm:basic name="pages" optional="true"/>
<orm:basic name="category" optional="true">
<orm:enumerated>STRING</orm:enumerated>
</orm:basic>
<orm:many-to-one name="author" optional="false" target-entity="org.eclipse.emf.texo.test.model.samples.library.Writer">
<orm:cascade>
<orm:cascade-persist/>
<orm:cascade-merge/>
<orm:cascade-refresh/>
</orm:cascade>
</orm:many-to-one>
</orm:attributes>
</orm:entity>
<orm:entity class="org.eclipse.emf.texo.test.model.samples.library.Writer" name="Writer">
<orm:attributes>
<orm:basic name="name" optional="true"/>
<orm:one-to-many name="books" target-entity="org.eclipse.emf.texo.test.model.samples.library.Book">
<orm:order-column/>
<orm:join-table name="Writer_books"/>
<orm:cascade>
</orm:cascade>
</orm:one-to-many>
</orm:attributes>
</orm:entity>
Then I just try to get EntityManager to be used later, the following code is performed:
Map properties = new HashMap();
EntityManagerFactory emf = Persistence.createEntityManagerFactory(PERSISTENCE_UNIT_NAME,
properties);
EntityManager em = emf.createEntityManager();
and I have the exception provided below.
Be noticed when I commented reference to Writer from Book entity - everything works ok for me. Another thing is when I tried to debug - everything again works nice. So this is an issue I have when running this code in runtime e.g. under tomcat in servlet environment, as junit test and as java standalone application.
Eclipse helios is used, and last (2.1.0.v20100614-r7608) version of EclipseLink.
Also EclipseLink is installed as plugin to Eclipse environment.
# An unexpected error has been detected by HotSpot Virtual Machine:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0093daa3, pid=4088, tid=1896
# Java VM: Java HotSpot(TM) Client VM (1.5.0_13-b05 mixed mode)
# Problematic frame:
# j org.eclipse.persistence.mappings.CollectionMapping.addDescen dingOrdering(Ljava/lang/String;)V+11
--------------- T H R E A D ---------------
Current thread (0x0035c7f8): JavaThread "main"
siginfo: ExceptionCode=0xc0000005, reading address 0x0e000031
Registers:
EAX=0x072a5c59, EBX=0x0e000001, ECX=0x0007f0ec, EDX=0x70800001
ESP=0x0007f0bc, EBP=0x0007f0e0, ESI=0x071d9933, EDI=0x0007f0ec
EIP=0x0093daa3, EFLAGS=0x00010246
Top of Stack: (sp=0x0007f0bc)
0x0007f0bc: 00932aba 0007f0ec 0007f0c4 071d9933
0x0007f0cc: 0007f0ec 074a0db0 00000000 071d9968
0x0007f0dc: 0007f0e8 0007f108 00932b3b 032b2db8
0x0007f0ec: 0007f0ec 072a5c59 0007f110 074b13a8
0x0007f0fc: 00000000 072a5c70 0007f110 0007f148
0x0007f10c: 00a6295c 032b2db8 02a1c700 0007f138
0x0007f11c: 073797a0 00000000 02a1c8f8 02a1c8a8
0x0007f12c: 02a1c700 02a1c8a8 02a1c750 00000001
Instructions: (pc=0x0093daa3)
0x0093da93: 00 3b 01 ff 63 30 8b 41 04 8b 9c 98 18 01 00 00
0x0093daa3: 8b 53 30 8b c3 ff e2 90 90 00 00 00 00 f0 00 00
Stack:
V
V
V
V
C
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+111
j org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( )Ljava/lang/Object;+15
j org.junit.internal.runners.model.ReflectiveCallable.run()Lja va/lang/Object;+1
j org.junit.runners.model.FrameworkMethod.invokeExplosively(Lj ava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+10
j org.junit.internal.runners.statements.InvokeMethod.evaluate( )V+12
j org.junit.runners.BlockJUnit4ClassRunner.runChild(Lorg/junit /runners/model/FrameworkMethod;Lorg/junit/runner/notificatio n/RunNotifier;)V+31
j org.junit.runners.BlockJUnit4ClassRunner.runChild(Ljava/lang /Object;Lorg/junit/runner/notification/RunNotifier;)V+6
j org.junit.runners.ParentRunner$3.run()V+12
j org.junit.runners.ParentRunner$1.schedule(Ljava/lang/Runnabl e;)V+1
j org.junit.runners.ParentRunner.runChildren(Lorg/junit/runner /notification/RunNotifier;)V+40
j org.junit.runners.ParentRunner.access$000(Lorg/junit/runners /ParentRunner;Lorg/junit/runner/notification/RunNotifier;)V+ 2
j org.junit.runners.ParentRunner$2.evaluate()V+8
j org.junit.runners.ParentRunner.run(Lorg/junit/runner/notific ation/RunNotifier;)V+20
j org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(Lorg/eclipse/jdt/internal/junit/runner/TestExecution;)V+7 2
j org.eclipse.jdt.internal.junit.runner.TestExecution.run([Lor g/eclipse/jdt/internal/junit/runner/ITestReference;)V+17
j org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts([Ljava/lang/String;Ljava/lang/String;Lorg/eclipse/jdt/in ternal/junit/runner/TestExecution;)V+61
j org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(Lorg/eclipse/jdt/internal/junit/runner/TestExecution;)V+ 10
j org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run() V+70
j org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( [Ljava/lang/String;)V+14
v ~StubRoutines::call_stub
V
V
V
V
C
C
C
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0ae6f218 JavaThread "MySQL Statement Cancellation Timer" daemon
0x0ae71008 JavaThread "ReaderThread"
0x00914790 JavaThread "Low Memory Detector" daemon
0x009134c0 JavaThread "CompilerThread0" daemon
0x00912900 JavaThread "Signal Dispatcher" daemon
0x009087f8 JavaThread "Finalizer" daemon
0x00907388 JavaThread "Reference Handler" daemon
=>0x0035c7f8 JavaThread "main"
Other Threads:
0x0035f970 VMThread [id=3028]
0x00911ae8 WatcherThread [id=2436]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 896K, used 460K [0x029b0000, 0x02aa0000, 0x02e90000)
eden space 832K, 52% used [0x029b0000, 0x02a1d638, 0x02a80000)
from space 64K, 36% used [0x02a80000, 0x02a85ca0, 0x02a90000)
to space 64K, 0% used [0x02a90000, 0x02a90000, 0x02aa0000)
tenured generation total 11344K, used 7441K [0x02e90000, 0x039a4000, 0x069b0000)
the space 11344K, 65% used [0x02e90000, 0x035d4590, 0x035d4600, 0x039a4000)
compacting perm gen total 14080K, used 13913K [0x069b0000, 0x07770000, 0x0a9b0000)
the space 14080K, 98% used [0x069b0000, 0x07746558, 0x07746600, 0x07770000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040d000 E:\program_files\isdk_1_5\bin\javaw.exe
0x7c900000 - 0x7c9b0000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f4000 C:\WINDOWS\system32\kernel32.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f01000 C:\WINDOWS\system32\RPCRT4.dll
0x77d40000 - 0x77dd0000 C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f56000 C:\WINDOWS\system32\GDI32.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\MSVCRT.dll
0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.DLL
0x6d740000 - 0x6d8dd000 E:\program_files\isdk_1_5\jre\bin\client\jvm.dll
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x6d300000 - 0x6d308000 E:\program_files\isdk_1_5\jre\bin\hpi.dll
0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d710000 - 0x6d71c000 E:\program_files\isdk_1_5\jre\bin\verify.dll
0x6d380000 - 0x6d39d000 E:\program_files\isdk_1_5\jre\bin\java.dll
0x6d730000 - 0x6d73f000 E:\program_files\isdk_1_5\jre\bin\zip.dll
0x6d540000 - 0x6d553000 E:\program_files\isdk_1_5\jre\bin\net.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x20b00000 - 0x20b46000 C:\WINDOWS\system32\imon.dll
0x71ad0000 - 0x71ad9000 C:\WINDOWS\system32\WSOCK32.dll
0x20c00000 - 0x20c0c000 C:\Program Files\nod32\pr_imon.dll
0x77690000 - 0x776b1000 C:\WINDOWS\system32\NTMARTA.DLL
0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll
0x774e0000 - 0x7761c000 C:\WINDOWS\system32\ole32.dll
0x71bf0000 - 0x71c03000 C:\WINDOWS\system32\SAMLIB.dll
0x10000000 - 0x1000f000 C:\WINDOWS\system32\dcsws2.dll
0x71a50000 - 0x71a8f000 C:\WINDOWS\system32\mswsock.dll
0x662b0000 - 0x66308000 C:\WINDOWS\system32\hnetcfg.dll
0x71a90000 - 0x71a98000 C:\WINDOWS\System32\wshtcpip.dll
0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll
0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll
0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll
VM Arguments:
jvm_args: -Dfile.encoding=Cp1251 -Xbootclasspath:E:\program_files\isdk_1_5\jre\lib\endorsed\s erializer-2.7.0.jar;E:\program_files\isdk_1_5\jre\lib\endors ed\xercesImpl-2.8.1.jar;E:\program_files\isdk_1_5\jre\lib\en dorsed\xml-apis-2.8.1.jar;E:\program_files\isdk_1_5\jre\lib\ rt.jar;E:\program_files\isdk_1_5\jre\lib\jsse.jar;E:\program _files\isdk_1_5\jre\lib\jce.jar;E:\program_files\isdk_1_5\jr e\lib\charsets.jar
java_command: org.eclipse.jdt.internal.junit.runner.RemoteTestRunner -version 3 -port 4689 -testLoaderClass org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader -loaderpluginname org.eclipse.jdt.junit4.runtime -classNames org.eclipse.emf.texo.json.Tester
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=E:\program_files\isdk_1_6
CLASSPATH=.;C:\Program Files\Java\jre1.5.0\lib\ext\QTJava.zip;E:\projects\remote\sp ringsite\yageo\dev\YageoRD\install\lucene\lucene-2.4.0\lucen e-core-2.4.0.jar;E:\projects\remote\springsite\yageo\dev\Yag eoRD\install\lucene\lucene-2.4.0\lucene-demos-2.4.0.jar;E:\p rojects\remote\springsite\yageo\dev\YageoRD\trunk\Lucene\lib \Multivalent20060102.jar;C:\welcome\java\pdfbox\lib\apache-p dfbox-0.8.0-incubator-dev.jar;C:\welcome\java\pdfbox\externa l\FontBox-0.2.0-dev.jar;C:\welcome\java\pdfbox\external\bcpr ov-jdk14-132.jar;
PATH=C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:/Program Files/Java/jre6/lib/i386;I:\Program Files\Delphi7\Bin;I:\Program Files\Delphi7\Projects\Bpl\;E:\PROGRA~1\CBUILD~1\Bin;E:\PROG RA~1\CBUILD~1\Projects\Bpl;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\system32\WBEM;E:\program_files\perl\bin\;C:\WINDOWS \system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI.ACE\;E:\program_files\ant\bin\;D:\program_f iles\svn_server\bin\;E:\program_files\maven_2.0.7\bin\;E:\pr ogram_files\isdk_1_5\bin\;C:\Program Files\QuickTime\QTSystem\;E:\aidoss\installed\maven-1.0.2\bi n\;E:\program_files\jwsdp\jaxrpc\bin\;E:\aidoss\install\ecli pse\;E:\program_files\cygwin\bin;c:\Program Files\TortoiseCVS\;E:\program_files\jad\;D:\program_files\sa msung\;E:\projects\R_D\setx;E:\program_files\OpenSSL\bin\;E: \Alfresco\bin\;C:\Program Files\TortoiseSVN\bin;E:\projects\research\libxslt\;C:\Progr am Files\MySQL\MySQL Server 5.0\bin;C:\welcome\java\jboss-seam-2.1.0.GA\;H:\.\common;G:\ Program Files\common;E:\program_files\appserv\Apache2.2\bin;E:\progr am_files\appserv\php5;E:\program_files\appserv\MySQL\bin
USERNAME=zmicer
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 6, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 (cores per cpu 2, threads per core 1) family 6 model 15 stepping 6, cmov, cx8, fxsr, mmx, sse, sse2
Memory: 4k page, physical 2095480k(765040k free), swap 4033520k(2452716k free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_13-b05) for windows-x86, built on Sep 25 2007 19:11:52 by "java_re" with MS VC++ 6.0
Re: An unexpected error > EXCEPTION_ACCESS_VIOLATION [message #553075 is a reply to message #552942] |
Mon, 16 August 2010 06:38  |
Hi, Chris!
Thanks for your detailed answer, and sharing your experience with IBM JVM.
I my case I should use Java 5 as requirement.
But your post helped to me - I downloaded newest version of 1.5 Java - it is update 22, and this problem fixed.
The problem I had is I was thinking this is something related to EclipseLink (as it uses Asm and some classloading manipulations) but seems to be it is a combination of EclipseLink advanced java techniques + Java worked not in a proper way mixing byte code execution from various streams.
Thus, thanks a lot, Chris, for an idea to update JRE.
Dzmitry
Current Time: Mon Sep 22 05:06:29 EDT 2025
Powered by FUDForum. Page generated in 0.07683 seconds
