Re: Building standalone RCP designer from sources [message #553788 is a reply to message #553778] |
Wed, 18 August 2010 20:56 |
Frank,
Can you open a bug for this? Also add that the wiki page needs to be
updated for the build process.
Jason
On 8/18/2010 4:11 PM, Frank Grimes wrote:
> I'm working off the BIRT_2_6_0_Release_201006171315 tag and don't see
> any build files in the org.eclipse.birt.releng.birtbuilder project.
Re: Building standalone RCP designer from sources [message #554236 is a reply to message #554199] |
Fri, 20 August 2010 17:12 |
Frank,
I will give this a try and get back to you.
Jason
On 8/20/2010 9:48 AM, Frank Grimes wrote:
> It seems that the BIRT_2_6_0_Release_201006171315 tag has been
> re-created for org.eclipse.birt.releng.birtbuilder and I now see the
> build files you mentioned.
> I tried running the build but they try to check out sources from CVS.
> (it failed because I don't have the cvs.exe in my path)
> However, I already have the projects checked out in my workspace.
> How do I build a release from my workspace?
> Is this possible?
Re: Building standalone RCP designer from sources [message #554676 is a reply to message #554672] |
Tue, 24 August 2010 04:11 |
Xiaoying,
Thanks for posting this.
Jason
On 8/23/2010 11:17 PM, Xiaoying Gu wrote:
> Jason,
> To build BIRT RCP designer from source, you should use the RCP export
> tool provided by Eclipse.
> Detailed steps:
> 1. Prepare all source plugins in your workspace, including
> org.eclipse.birt.report.designer.ui.rcp
> 2. Open BIRT.product file which is under
> org.eclipse.birt.report.designer.ui.rcp with Product Configuration Editor
> 3. In the "Overview" tab -> Exporting section, open the "Eclipse Product
> export wizard".
> 4. In the Export dialog, Set the exported Directory. Then click
> "Finish". The exporting of RCP should be started automatically and you
> will get the RCP under the directory when it finishes.
> I will add the RCP exporting steps to the wiki page.
Re: Building standalone RCP designer from sources [message #554888 is a reply to message #554877] |
Tue, 24 August 2010 15:47 |
Understood. Can you add a comment to the bug that states this? As a
work around can you try going into cvs explorer and locate the rcp
project and then do a "check out as" option, which will give you a
chance to refresh the tags. When it lists the tags use v20100624.
Jason
On 8/24/2010 11:24 AM, Frank Grimes wrote:
> 1. Install BIRT prerequisite in Eclipse home. (You can use the allinone
> download to get all prerequisites.)
> I downlaoded and installed the allinone download
> 2. Download or import BIRT source code in workspace, including
> I checked out org.eclipse.birt.report.designer.ui.rcp from the
> BIRT_2_6_0_Release_201006171315 CVS tag.
> 3. Open BIRT.product file which is under
> There is no such file in the project.
Re: Building standalone RCP designer from sources [message #554947 is a reply to message #554919] |
Tue, 24 August 2010 20:40 |
I do not believe those errors affect the build, but you could try
restarting eclipse with the -clean option and try again.
On 8/24/2010 1:44 PM, Frank Grimes wrote:
> I switched to using the v20100624 tag of
> org.eclipse.birt.report.designer.ui.rcp (used
> BIRT_2_6_0_Release_201006171315 tag of other projects)
> I was then able to build a running Birt RCP platform using the new
> instructions on the WIKI.
> While it seems to build ok, I do get the following errors when doing the
> RCP export:
> C:\eclipse-reporting-helios\workspace\.metadata\.plugins\org
> .eclipse.pde.core\temp\org.eclipse.pde.container.feature\pac
> kage.org.eclipse.pde.container.feature.win32.win32.x86.xml:9 3: The
> following error occurred while executing this line:
> kage.org.eclipse.pde.container.feature.win32.win32.x86.xml:9 49: Unable
> to delete file
> .eclipse.pde.core\temp\assemblyLocation\tmp\eclipse\plugins\
> javax.xml.rpc_1.1.0.v201005080400\META-INF\ECLIPSEF.RSA
> The following error occurred while executing this line:
> to delete file
> Are these expected?
> Can they safely be ignored?
Re: Building standalone RCP designer from sources [message #555158 is a reply to message #555118] |
Wed, 25 August 2010 16:00 |
I am glad it is working Frank.
Jason
On 8/25/2010 9:49 AM, Frank Grimes wrote:
> Hi All,
> After getting the re-tagged BIRT_2_6_0_Release_201006171315 version of
> org.eclipse.birt.report.designer.ui.rcp, the problem seems to have gone
> away.
> Thanks everyone!
> Frank Grimes
FUDForum. Page generated in 0.06853 seconds
