Re: P2 UI menu contributions in E4 application [message #551302 is a reply to message #551196] |
Thu, 05 August 2010 19:47 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Well those things only work if you have the compat-layer with you.
An application built with the pure Eclipse 4.0 Application Platform does
not understand any extension points beside:
* org.eclipse.e4.workbench.model: for model contributions
* org.eclipse.e4.ui.css.swt.theme: to contribute themes and styles
That's all extension points you need to make up complete applications -
we don't need more than those because the
org.eclipse.e4.workbench.model-extension points allows to contribute
model fragments and the model itself knows about, commands, handlers, ... .
Tom
Am 05.08.10 16:53, schrieb Chris:
> Hello,
> In a 3.6 application, adding p2 feature UI was sufficient to have
> "Install new Software..." and "Check Update..." in "Help" menu.
> Now, my application is E4. It doesn't work anymore. Even if I have a
> menu with id=help in Application.e4xmi and a separator with id=additions.
> My question is : does old 3.6 contributions system work with E4
> application ?
> Thanks.
> For information, the contribution of P2 UI DK is :
> <extension
> point="org.eclipse.ui.menus">
> <menuContribution
> locationURI="menu:help?after=additions">
> <command
> commandId="org.eclipse.equinox.p2.ui.sdk.update"
> mnemonic="%Update.command.mnemonic"
> id="org.eclipse.equinox.p2.ui.sdk.update">
> </command>
> </menuContribution>
> <menuContribution
> locationURI="menu:help?after=org.eclipse.equinox.p2.ui.sdk.update ">
> <command
> commandId="org.eclipse.equinox.p2.ui.sdk.install"
> mnemonic="%Install.command.mnemonic"
> id="org.eclipse.equinox.p2.ui.sdk.install">
> </command>
> </menuContribution>
> </extension>
FUDForum. Page generated in 1.27363 seconds
