Re: [EEF] Label not shown on Widget AdvancedTableComposition [message #554739 is a reply to message #550838] |
Tue, 24 August 2010 09:38 |
Stephane Bouchet Messages: 280 Registered: July 2009 |
hi,
sorry, i just saw this message.
BTW, for others people, you already created a bugzilla for this :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=322974
Le 04/08/2010 15:32, Christophe Bouhier a écrit :
> I have a feature which should render it's values in a Widget
> AdvancedTableComposition.
> Unfortunately, the label isn't displayed. (See attachment, in properties
> view an element is selected, but no label).
> I have put a breakpoint on the getText() method on xxItemProvider for
> this object, which doesn't get called. I wonder if the adapterFactory is
> correctly resolved by EEF in this case?
> this is in my .edit plugin.xml
> <extension point="org.eclipse.emf.edit.itemProviderAdapterFactories">
> <factory
> uri="http://www.netxforge.com/15072010/networks"
> class=" com.netxforge.d.networks.provider.NetworksItemProviderAdapte rFactory "
> supportedTypes=
> "org.eclipse.emf.edit.provider.IEditingDomainItemProvider
> org.eclipse.emf.edit.provider.IStructuredItemContentProvider
> org.eclipse.emf.edit.provider.ITreeItemContentProvider
> org.eclipse.emf.edit.provider.IItemLabelProvider
> org.eclipse.emf.edit.provider.IItemPropertySource
> org.eclipse.emf.edit.provider.ITableItemLabelProvider"/>
> </extension>
> Here is some extracts for this object:
> <properties xsi:type="eef-components:PropertiesEditionElement"
> xmi:id="_VSMjaJXLEd-GxtwJpoOb1Q" name="equipmentResources"
> views="_VSNKqZXLEd-GxtwJpoOb1Q">
> <model xsi:type="ecore:EReference"
> href=" file:/Users/dzonekl/Documents/Spaces/netxstudio.gen2/com.net xforge.d/model/networks.ecore#//Equipment/equipmentResources "/>
> <elements xsi:type="eef-views:ElementEditor"
> xmi:id="_VSNKqZXLEd-GxtwJpoOb1Q" name="Equipment Resources">
> <representation
> href=" platform:/plugin/org.eclipse.emf.eef.views/std/EMFProperties .toolkits#//@widgets.7 "/>
> Cheers Christophe
Stéphane Bouchet, OBEO
Re: [EEF] Label not shown on Widget AdvancedTableComposition [message #623149 is a reply to message #550838] |
hi,
> <factory
> supportedTypes=
> </extension>
> <representation
> Cheers Christophe
FUDForum. Page generated in 0.30536 seconds
