Getting a Plugin [message #550588] |
Fri, 30 July 2010 23:43 |
Originally posted by: nowhere.a.com
I just tried to download a plugin from the Eclipse Marketplace web
pages.
The only "download" link I could find was a down arrow, but that gave
me a text link which is supposed to be copy/pasted into Eclipse. I
assume that Eclipse would then download/install the plugin.
While this machine is connected to the Internet, my development machine
is not and cannot be connected.
I used to be able to download a jar or zip, then copy/expand it into
the Eclipse plugin directory.
I am either missing something basic on the web pages or the changes are
predicated on being connected to the internet.
Any advice would be appreciated.
Wojtek :-)
Re: Getting a Plugin [message #551015 is a reply to message #550989] |
Wed, 04 August 2010 20:35 |
Eric Rizzo wrote :
> On 7/30/10 7:43 PM, Wojtek wrote:
>> I just tried to download a plugin from the Eclipse Marketplace web pages.
>> The only "download" link I could find was a down arrow, but that gave me
>> a text link which is supposed to be copy/pasted into Eclipse. I assume
>> I used to be able to download a jar or zip, then copy/expand it into the
> Installing a plugin manually is still supported, but it is a much more
> error-prone process that way (because you don't get the benefit of dependency
> checking and resolution). If you have no option to get the development
> machine access to the internet, you'll need to put plugin JARs into the
> /dropins folder of Eclipse. Read more here:
> http://wiki.eclipse.org/Equinox_p2_Getting_Started#Dropins
Hmm, to be supported there needs to be a link to the plugin. However I
cannot find any such link (tried the Unnecessary Code Detector as a
test).
Ok, I guess I will setup a dummy Eclipse installation on the Internet
machine, then use that to update/install features. Then I will copy the
entire Eclipse directory to a USB drive and then ask the security guys
to give me an access window to attach the USB and copy Eclipse onto the
development machine.
It's not like I install a new plugin every other day...
Wojtek :-)
FUDForum. Page generated in 0.09450 seconds
