Home » Modeling » Epsilon » [EVL] Question about the HasName constraint in the filesystemExample.
[EVL] Question about the HasName constraint in the filesystemExample. [message #550514] |
Fri, 30 July 2010 15:40 |
Toñi Reina Messages: 209 Registered: July 2009 |
I'm testing the filesystem example validation part explained in
http://www.eclipse.org/gmt/epsilon/doc/articles/evl-gmf-inte gration/ My
question is about the HasName constraint whose context is File. I'm
wondering if this constraint is really needed, I mean, if write my
metamodel constraining the cardinality name, as I write above, the
editor shouldn't let you write a not defined name, should it?
@gmf.node(figure="figures.FileFigure",
label.icon="false", label="name", label.placement="external")
class File {
attr String [1]name;
Concerning to this question, I'm also wondering if the eugenia generated
editor is able to validate some cardinality constraints, without any evl
extra code. For example, if I change the Folder class to restrict the
number of files it can include (as it is shown below), could the editor
avoid the user add more than one file to a folder?
@gmf.node(label=name)
class Folder {
attr String name;
@gmf.compartment(layout="free",collapsible="true")
val File[1] contents;
Thanks a lot
Re: [EVL] Question about the HasName constraint in the filesystemExample. [message #550566 is a reply to message #550514] |
Fri, 30 July 2010 19:04 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Toni,
On 30/07/2010 18:40, Toñi Reina Quintero wrote:
> class File {
I think you're right. We just used HasName as a simple example
demonstrating simple EVL constraints.
> class Folder {
> attr String name;
It should.
> Thanks a lot
Dimitris
Re: [EVL] Question about the HasName constraint in the filesystemExample. [message #591092 is a reply to message #550514] |
Hi Toni,
> class File {
> class Folder {
> attr String name;
It should.
> Thanks a lot
Dimitris
Current Time: Fri Apr 26 19:48:46 GMT 2024
Powered by FUDForum. Page generated in 0.02942 seconds
