[Acceleo 3] Can't find my ecore model [message #550152] |
Thu, 29 July 2010 10:19 |
mami Messages: 3 Registered: July 2010 |
I try to be clear. I have a mtl template (schematron.mtl) that uses 2 ecore models (rules.erore and structure.ecore) through their Ns URI ([module schematron('http://www.bluexml.com/n4ds/rules/1.0','http://www.bluexml.com/n4ds/structure/1.0')/]).
The code generation is associated with a popup action (plugin project). Normally, I launch another eplipse application, I open my data model, but when I try to generate the code by clicking on the action, I have the following error:
java.io.FileNotFoundException: /Users/bluexmlbluexml/Documents/plugin/com.bluexml.n4ds/mode l/structure.ecore (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.creat eInputStream(FileURIHandlerImpl.java:105)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm pl.createInputStream(ExtensibleURIConverterImpl.java:301)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1254)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObje ct(ResourceSetImpl.java:216)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java: 202)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java: 262)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(Ba sicEObjectImpl.java:1483)
at org.eclipse.emf.ecore.impl.ETypedElementImpl.getEType(ETyped ElementImpl.java:321)
at org.eclipse.ocl.ecore.impl.OCLExpressionImpl.getType(OCLExpr essionImpl.java:173)
at org.eclipse.ocl.ecore.impl.OCLExpressionImpl.getType(OCLExpr essionImpl.java:1)
at org.eclipse.ocl.internal.EnvironmentRegistryImpl.getEnvironm entFor(EnvironmentRegistryImpl.java:61)
at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.getOperation Code(OperationCallExpImpl.java:182)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitOperationCallExp(AcceleoEvaluationVisitor.j ava:990)
at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(Opera tionCallExpImpl.java:390)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor$ParameterInitExpression.accept(AcceleoEvaluation Visitor.java:1614)
at org.eclipse.ocl.EvaluationVisitorImpl.visitVariable(Evaluati onVisitorImpl.java:1976)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitVariable(Eva luationVisitorDecorator.java:340)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoQueryInvocation(AcceleoEvaluationVis itor.java:667)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 500)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitExpression(AcceleoEvaluationVisitor.java:91 2)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoForBlock(AcceleoEvaluationVisitor.ja va:332)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 480)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.ja va:781)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 467)
at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(Query Impl.java:152)
at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:62)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvalua te(AcceleoEngine.java:265)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate (AcceleoEngine.java:130)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate Template(AcceleoService.java:544)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate (AcceleoService.java:380)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. generate(AbstractAcceleoGenerator.java:120)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. doGenerate(AbstractAcceleoGenerator.java:99)
at com.bluexml.n4ds.rules.generator.files.Schematron.doGenerate (Schematron.java:148)
at com.bluexml.n4ds.rules.editor.ui.popup.actions.GenerateSchem atronRules$1.run(GenerateSchematronRules.java:92)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Note that "plugin", appears in the path above, doesn't belong to the right path. The right path is: /Users/bluexmlbluexml/Documents/workspace/com.bluexml.n4ds/m odel/structure.ecore !!!!
Question: Why it can't find my ecore model (structure.ecore), knowing that my template (schematron.mtl) recognizes it without any problem ?
Configuration:
- eclipse 3.6 (helios)
- Mac OS X v10.5
Best regards
Re: [Acceleo 3] Can't find my ecore model [message #550198 is a reply to message #550152] |
Thu, 29 July 2010 13:17 |
--------------090105010608070804050709
Hi Mami,
This seems to resemble
https://bugs.eclipse.org/bugs/show_bug.cgi?id=306692 though your problem
is with the model and not the generation folder. Is your model
(structure.ecore) located physically in your workspace? If not, can you
try to copy it in a workspace-located project and see if you can reproduce?
Laurent Goubet
Obeo
mami wrote:
> ([module
> ceImpl.java:1254)
> essionImpl.java:1)
> Visitor.java:1614)
> Impl.java:152)
> that my template (schematron.mtl) recognizes it without any problem ? :x
> Configuration:
> - Mac OS X v10.5
> Best regards
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------090105010608070804050709--
Re: [Acceleo 3] Can't find my ecore model [message #551694 is a reply to message #551413] |
Mon, 09 August 2010 08:15 |
--------------070409080508020605010807
Thanks Mami, we'll try and reproduce this failure when we fix the bug
with workspace outside of the Eclipse directory.
Laurent Goubet
Obeo
mami wrote:
> Hi Laurent and thanks for the answer
> All my projects are in the same workspace including my model
> (structure.ecore). The plugin workspace, where the secand eclipse
> instance is running, is empty, so I just import projects from the
> original workspace.
> This problem still occurs sometimes, but despite the generation is
> done and that is enough for now :d
> Best regards...
--------------070409080508020605010807--
FUDForum. Page generated in 0.04268 seconds
