How to remove line above node compartment [message #550151] |
Thu, 29 July 2010 10:15 |
Originally posted by: jan.vandenbergh.uhasselt.be
I am developing a GMF editor for a DSL. This DSL contains several nodes
that contain one compartment. Above this compartment there is a
horizontal line. Can I remove this horizontal line or change its
visualization? I would prefer a solution that only modifies the
..gmfgraph model, if possible.
Many thanks!
Kind regards,
Jan
Re: How to remove line above node compartment [message #550774 is a reply to message #550151] |
Wed, 04 August 2010 09:57 |
Originally posted by: marius.groeger.googlemail.com
Am 29.07.2010 12:15, wrote Jan Van den Bergh:
Late reply, for some reason I couldn't reach the news server for a
couple of days.
You can either modify the compartment's figure in the generated edit
part code, or use the following generic solution which uses a seperate
plugin:
plugin.xml:
<extension
point="org.eclipse.gmf.runtime.diagram.ui.editpolicyProviders ">
<editpolicyProvider class="XXX.policies.EditPolicyProvider">
<Priority
name="Medium">
</Priority>
</editpolicyProvider>
</extension>
XXX.policies.EditPolicyProvider:
private EditPartListener compartmentSilencer = new
EditPartListener.Stub() {
public void childAdded(EditPart child, int index) {
if (child instanceof CompartmentEditPart) {
// remove top border
((CompartmentEditPart)child).getFigure().setBorder(null);
public class EditPolicyProvider implements IEditPolicyProvider {
public void createEditPolicies(EditPart editPart) {
if (editPart instanceof ShapeNodeEditPart) {
editPart.addEditPartListener(compartmentSilencer);
public boolean provides(IOperation operation) {
boolean result = false;
if (operation instanceof CreateEditPoliciesOperation) {
EditPart editPart =
((CreateEditPoliciesOperation)operation).getEditPart();
result = editPart instanceof XXXEditPart;
return result;
I admit this is kind of complicated given the problem to solve, but for
me it's worth it. I prefer not modifying generated code because I want
to keep being able to complete wipe and regenerate it. Also, this method
allows other dynamic "fixes" or additions to be done to the EditParts.
In fact I called the listener "silencer" because in my code it also
registers an editpolicy to inhibit the selection handles and the "delete
from model" context menu entry.
HTH
Marius
Re: How to remove line above node compartment [message #550775 is a reply to message #550151] |
couple of days.
plugin:
plugin.xml:
<extension
<Priority
name="Medium">
</Priority>
</extension>
EditPart editPart =
return result;
HTH
Marius
Re: How to remove line above node compartment [message #553181 is a reply to message #550774] |
Mon, 16 August 2010 15:30 |
>> Hi,
> couple of days.
> plugin:
> plugin.xml:
> <extension
> <Priority
> name="Medium">
> </Priority>
> </extension>
> @Override
> EditPart editPart = ((CreateEditPoliciesOperation)operation).getEditPart();
> return result;
Thank you very much!
This was exactly what I was looking for.
Kind regards,
Jan
> HTH
> Marius
FUDForum. Page generated in 0.03173 seconds
