Home » Language IDEs » Java Development Tools (JDT) » Help with creating new project from source in Eclipse Helios(Help with creating new project from source in Eclipse Helios)
Help with creating new project from source in Eclipse Helios [message #549979] Wed, 28 July 2010 11:47 Go to next message
Hi Guys,
I have been using Eclipse Galileo to do Java development. I use svn command line (outside of Eclipse) to check-in and check-out code. To start a new project in Eclipse, I normallay use the 'Create Java Project' and then check the 'Create project from existing sources' (from my svn working copies) radio button in the project creation wizard.
In the new version of Eclipse (Helios), I could not find a similar option available for me. Can you please let me know the status of this functionality. Was is moved to a different location/replaced with a different but similar functionality? I prefer my SVN command line and hence would like to stick with the approach I have followed with Eclipse Galileo.
Thanks for your help!
Karthik.
Re: Help with creating new project from source in Eclipse Helios [message #550025 is a reply to message #549979] Wed, 28 July 2010 15:20 Go to previous messageGo to next message
Did you check the import menu ?
Olivier
Re: Help with creating new project from source in Eclipse Helios [message #550033 is a reply to message #549979] Wed, 28 July 2010 15:22 Go to previous message
"Karthik" <karthikcm_cse@yahoo.com> wrote in message
news:i2pjeq$eq5$1@build.eclipse.org...
> Hi Guys,
> Galileo.
> Karthik.
In the Create Jave Project wizard, uncheck the use default location box and
browse to the directory with your source code in it.
Previous Topic:How can I get ICompilationUnit form a IFile ?
Next Topic:Java editor fails opening java file.
Current Time: Tue Nov 04 00:38:03 EST 2025
Powered by FUDForum. Page generated in 0.27483 seconds
