watermark and company stamp [message #549897] |
Wed, 28 July 2010 11:54 |
pigargo Messages: 14 Registered: May 2010 |
Hallo,
I want to print a watermark and a company stamp on my report.
For both i can use the background image on the master page. But I don't have found any possibility to take an image from the filesystem which is defined in a report datasetrow.
And then I have a problem to set the visibility of the image. There is no visibility definition on the background image and also not on the master page. But the watermark "copie" only should be printed, if the parameter P_ORIGINAL is not set.
Is there any way to solve this problems?
Thanks for your help.
pigargo
[Updated on: Wed, 28 July 2010 11:54] Report message to a moderator
Re: watermark and company stamp [message #550000 is a reply to message #549897] |
Wed, 28 July 2010 17:12 |
If the image did not need to be dynamic based on row data you would just
use some de api in the before factory to set it like:
reportContext.getDesignHandle().findMasterPage("myMasterPage ").setProperty("backgroundImage",
"file://C:\\work\\oldblogs\\My Pictures\\birtlogo.png" );
But since you want it dynamic try this approach.
One way to handle this is to start with a 1x1 grid and set its height
and width to 100%. Create a new style with a background image set in it
and apply it to the grid. Drop your table data inside the grid. You
can then just disable the background image in the onCreate script of the
grid like:
if( !params["showWM"].value ){
this.getStyle().backgroundImage = "";
If you want the background image path to come from the row data, this is
a bit tricky as the grid is already processed before your table is. To
get around this place a hidden table above the grid that does the
background image location calculation. for example I could add the
hidden table with an onCreate script on the row like:
var qty = this.getRowData().getColumnValue("QUANTITYORDERED");
if( qty > 40 ){
SwapBGI = true;
Withouth the var keyword SwapBGI is now global. I can then use this
variable in my grid oncreate.
if( SwapBGI ){
this.getStyle().backgroundImage="c:/dwn/Jellyfish.jpg";
The only other thing you need to do is to set SwapBGI to false in the
onPrepare of the grid
SwapBGI = false;
See the attached example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.0.v20100531 Build <2.6.0.v20100609-1613></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<parameters>
<scalar-parameter name="showWM" id="48">
<property name="valueType">static</property>
<property name="dataType">boolean</property>
<property name="distinct">true</property>
<simple-property-list name="defaultValue">
<value type="constant">true</value>
</simple-property-list>
<property name="paramType">simple</property>
<property name="controlType">check-box</property>
<structure name="format"/>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
<text-property
name="heading">ORDERNUMBER</text-property>
<property name="displayLength">11</property>
<property name="horizontalAlign">justify</property>
<property name="wordWrap">false</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
<text-property
name="heading">PRODUCTCODE</text-property>
<property name="displayLength">15</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
<text-property
name="heading">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
<text-property name="heading">PRICEEACH</text-property>
<property name="displayLength">22</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
<text-property
name="heading">ORDERLINENUMBER</text-property>
<property name="displayLength">6</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails
]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
<style name="NewStyle" id="9">
<property name="backgroundImage">c:/dwn/Koala.jpg</property>
<property name="backgroundRepeat">no-repeat</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="49">
<property name="dataSet">Data Set</property>
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr"
type="javascript">true</expression>
</structure>
</list-property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="78"/>
<column id="79"/>
<column id="80"/>
<column id="81"/>
<column id="82"/>
<header>
<row id="83">
<cell id="84">
<property name="colSpan">5</property>
<property name="rowSpan">1</property>
<label id="89">
<text-property name="text">This table is
hidden an just used to calculate the background image for the grid
below. Look at the on create method of the row.</text-property>
</label>
</cell>
</row>
<row id="50">
<cell id="51">
<label id="52">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="53">
<label id="54">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="55">
<label id="56">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="57">
<label id="58">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="59">
<label id="60">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="61">
<method name="onCreate"><![CDATA[var qty =
if( qty > 40 ){
SwapBGI = true;
}]]></method>
<cell id="62">
<data id="63">
<property name="whiteSpace">nowrap</property>
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="64">
<data id="65">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="66">
<data id="67">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="68">
<data id="69">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="70">
<data id="71">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="72">
<cell id="73"/>
<cell id="74"/>
<cell id="75"/>
<cell id="76"/>
<cell id="77"/>
</row>
</footer>
</table>
<grid id="10">
<property name="style">NewStyle</property>
<property name="height">100%</property>
<property name="width">100%</property>
<method name="onPrepare"><![CDATA[SwapBGI = false;]]></method>
<method name="onCreate"><![CDATA[if( SwapBGI ){
}]]></method>
<column id="11"/>
<row id="12">
<cell id="13">
<table id="14">
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<text-property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<column id="43"/>
<column id="44"/>
<column id="45"/>
<column id="46"/>
<column id="47"/>
<header>
<row id="15">
<cell id="16">
<label id="17">
<text-property
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
</label>
</cell>
<cell id="22">
<label id="23">
<text-property
</label>
</cell>
<cell id="24">
<label id="25">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="26">
<cell id="27">
<data id="28">
<property
<property
</data>
</cell>
<cell id="29">
<data id="30">
<property
<property
</data>
</cell>
<cell id="31">
<data id="32">
<property
<property
</data>
</cell>
<cell id="33">
<data id="34">
<property
<property
</data>
</cell>
<cell id="35">
<data id="36">
<property
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="37">
<cell id="38"/>
<cell id="39"/>
<cell id="40"/>
<cell id="41"/>
<cell id="42"/>
</row>
</footer>
</table>
</cell>
</row>
</grid>
</body>
</report>
On 7/28/2010 7:54 AM, pigargo wrote:
> Hallo,
Re: watermark and company stamp [message #550220 is a reply to message #550139] |
Thu, 29 July 2010 14:44 |
Set the grid height to like 10 in and then select the grid row and set
its height to 9 in. You can test with different numbers, but if they
are bigger than the page you will get the error you are seeing. Take a
look at the modified example I am attaching.
Jason
id="1">
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="layoutPreference">fixed layout</property>
<parameters>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
id="7">
<ex-property>
</ex-property>
<ex-property>
</ex-property>
</list-property>
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
where ordernumber = 10101
]]></xml-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="49">
<structure>
</structure>
</list-property>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<column id="78"/>
<column id="79"/>
<column id="80"/>
<column id="81"/>
<column id="82"/>
<header>
<row id="83">
<cell id="84">
<label id="89">
</label>
</cell>
</row>
<row id="50">
<cell id="51">
<label id="52">
<text-property
</label>
</cell>
<cell id="53">
<label id="54">
<text-property
</label>
</cell>
<cell id="55">
<label id="56">
<text-property
</label>
</cell>
<cell id="57">
<label id="58">
<text-property
</label>
</cell>
<cell id="59">
<label id="60">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="61">
if( qty > 40 ){
SwapBGI = true;
}]]></method>
<cell id="62">
<data id="63">
<property
</data>
</cell>
<cell id="64">
<data id="65">
<property
</data>
</cell>
<cell id="66">
<data id="67">
<property
</data>
</cell>
<cell id="68">
<data id="69">
<property
</data>
</cell>
<cell id="70">
<data id="71">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="72">
<cell id="73"/>
<cell id="74"/>
<cell id="75"/>
<cell id="76"/>
<cell id="77"/>
</row>
</footer>
</table>
<grid id="10">
<property name="masterPage">Simple MasterPage</property>
<property name="height">10in</property>
}]]></method>
<column id="11"/>
<row id="12">
<property name="height">9in</property>
<cell id="13">
<table id="14">
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<text-property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<column id="43"/>
<column id="44"/>
<column id="45"/>
<column id="46"/>
<column id="47"/>
<header>
<row id="15">
<cell id="16">
<label id="17">
<text-property
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
</label>
</cell>
<cell id="22">
<label id="23">
<text-property
</label>
</cell>
<cell id="24">
<label id="25">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="26">
<cell id="27">
<data id="28">
<property
<property
</data>
</cell>
<cell id="29">
<data id="30">
<property
<property
</data>
</cell>
<cell id="31">
<data id="32">
<property
<property
</data>
</cell>
<cell id="33">
<data id="34">
<property
<property
</data>
</cell>
<cell id="35">
<data id="36">
<property
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="37">
<cell id="38"/>
<cell id="39"/>
<cell id="40"/>
<cell id="41"/>
<cell id="42"/>
</row>
</footer>
</table>
</cell>
</row>
</grid>
</body>
</report>
On 7/29/2010 5:27 AM, pigargo wrote:
> Hallo Jason,
> thank you very much. This was a big help for me.
> But now I have two problems.
> 1) My background image will fill the whole page. Now I have limited the
> data, so that they will fill only the half page. What's happen? The
> background image is printed only for the half page.
> 2) If the image is not so big to fill the whole page I will stretch it
> to the size of the grid. So I set the values background size height and
> background size width to contain. The image was contained in preview and
> html, but not in pdf.
> I am using birt 2.5.2, will this be a bug?
> pigargo
FUDForum. Page generated in 0.04656 seconds
