Home » Eclipse Projects » Rich Client Platform (RCP) » Simple question: Add and update Text field in Toolbar
Simple question: Add and update Text field in Toolbar [message #549658] Tue, 27 July 2010 09:35 Go to next message
Hello!
I want to add a text field to the coolbar in order to show a certain setting from the application preferences. This text shall then be updated when the preferences change.
So far, so good. As far as I know, the proper to way to add arbitrary GUI elements to the Toolbar is to extend the class org.eclipse.jface.action.ControlContribution.
But how do I later change the displayed text?
My current approach is this:
public class MainFileContribution extends ControlContribution{
	protected Control createControl(Composite parent) {
		final Text text = new Text(parent, SWT.BORDER|SWT.READ_ONLY);
		text.setText(getText());
		preferences.addPreferenceChangeListener(
				new IPreferenceChangeListener() {
			public void preferenceChange(PreferenceChangeEvent event) {
		return text;
Basically, I'm storing a reference to the Text widget and call the setText method when I want to change it.
This works but I get the following exception:
org.eclipse.swt.SWTException: Widget is disposed
Changes are still applied, though.
So now my question is: What is the proper way to accomplish this?
Thanks in advance!
Florian Philipp
Re: Simple question: Add and update Text field in Toolbar [message #551033 is a reply to message #549658] Wed, 04 August 2010 18:22 Go to previous messageGo to next message
Hi Florian,
The disposed message does not come from your text widget. I bet it comes from
the preference widget.
Best Regards,
Wim Jongman
Eclipse Twitter
-- Liar.getLiar().isPantsOnFire()
Kim Horne
> Hello!
> return text;
> Quote:
> Thanks in advance!
> Florian Philipp
Re: Simple question: Add and update Text field in Toolbar [message #551059 is a reply to message #551033] Thu, 05 August 2010 01:18 Go to previous message
Wim Jongman wrote on Wed, 04 August 2010 18:22
Hi Florian,
	at org.eclipse.swt.SWT.error(SWT.java:4083)
	at org.eclipse.swt.SWT.error(SWT.java:3998)
	at org.eclipse.swt.SWT.error(SWT.java:3969)
	at org.eclipse.swt.widgets.Widget.error(Widget.java:466)
	at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:403)
	at org.eclipse.swt.widgets.Text.setText(Text.java:2031)
	at de.[...].MainFileContribution$1.preferenceChange(MainFileContribution.java:36)
	at org.eclipse.core.internal.preferences.EclipsePreferences$2.run(EclipsePreferences.java:753)
	at org.eclipse.core.internal.preferences.EclipsePreferences.firePreferenceEvent(EclipsePreferences.java:756)
	at org.eclipse.core.internal.preferences.EclipsePreferences.put(EclipsePreferences.java:769)
	at de.[...].MainFileAction.run(MainFileAction.java:37)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:452)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3552)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3171)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
	at de.[...].Application.start(Application.java:20)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Looks like it is thrown by SWT.Text ...
Previous Topic:How to control shortcut bar ?
Next Topic:Dynamic TreeViewer
Current Time: Sun Sep 21 20:56:09 EDT 2025
Powered by FUDForum. Page generated in 0.23469 seconds
