Re: Understanding @XmlInverseReference [message #549364 is a reply to message #549026] |
Mon, 26 July 2010 14:12 |
I haven't been able to reproduce the NPE you are seeing, could you reply back with the version of EclipseLink you are using.
When Parent is the root object when marshalling to XML. You should annotate the getparentBean() method as follows:
@XmlInverseReference(mappedBy="childs")
public Parent getparentBean()
Your JPA mappings do not appear to be correct. The getparentBean method should probably be fully annotated with something like (using a @ManyToOne instead of @OneToMany):
// bi-directional many-to-one association to Child
@ManyToOne
@JoinColumn(name="ID_PARENT")
return this.parentBean;
-Blaise
Re: Understanding @XmlInverseReference [message #550288 is a reply to message #549026] |
Thu, 29 July 2010 18:58 |
We have had some offline discussion about this issue, and for the benefit of others that find this post below is the correct setup of using @XmlInverseReference at multiple levels:
Entity A
import java.io.Serializable;
import javax.persistence.*;
import javax.xml.bind.annotation.XmlAttribute;
import javax.xml.bind.annotation.XmlElement;
import javax.xml.bind.annotation.XmlRootElement;
import java.util.Set;
@Entity
@XmlRootElement
public class EntityA implements Serializable {
private static final long serialVersionUID = 1L;
private String name;
private Set<EntityB> entityBs;
@Id
@XmlAttribute
public String getName() {
return this.name;
public void setName(String name) {
this.name = name;
@OneToMany(mappedBy = "entityABean")
@XmlElement
public Set<EntityB> getEntityBs() {
return this.entityBs;
public void setEntityBs(Set<EntityB> entityBs) {
this.entityBs = entityBs;
Entity B
import org.eclipse.persistence.oxm.annotations.XmlInverseReference;
@Entity
@XmlRootElement
public class EntityB implements Serializable {
private Set<EntityC> entityCs;
private EntityA entityABean;
@Id
@XmlAttribute
return this.name;
this.name = name;
@ManyToOne
@JoinColumn(name = "EntityA")
@XmlInverseReference(mappedBy = "entityBs")
public EntityA getEntityABean() {
return this.entityABean;
public void setEntityABean(EntityA entityABean) {
this.entityABean = entityABean;
@OneToMany(mappedBy = "entityBBean")
@XmlElement
public Set<EntityC> getEntityCs() {
return this.entityCs;
public void setEntityCs(Set<EntityC> entityCs) {
this.entityCs = entityCs;
Entity C
@Entity
public class EntityC implements Serializable {
private EntityB entityBBean;
@Id
return this.name;
this.name = name;
@ManyToOne
@JoinColumn(name = "EntityB")
@XmlInverseReference(mappedBy = "entityCs")
public EntityB getEntityBBean() {
return this.entityBBean;
public void setEntityBBean(EntityB entityBBean) {
this.entityBBean = entityBBean;
Demo
import java.io.FileInputStream;
import javax.xml.bind.JAXBContext;
import javax.xml.bind.Marshaller;
import javax.xml.bind.Unmarshaller;
public class Demo {
public static void main(String[] args) throws Exception {
JAXBContext jc = JAXBContext.newInstance(EntityA.class);
Unmarshaller unmarshaller = jc.createUnmarshaller();
FileInputStream xml = new FileInputStream("src/test/jaxb/input.xml");
EntityA a = (EntityA) unmarshaller.unmarshal(xml);
for(EntityB b : a.getEntityBs()) {
System.out.println(b.getEntityABean());
for(EntityC c : b.getEntityCs()) {
System.out.println(c.getEntityBBean());
Marshaller marshaller = jc.createMarshaller();
marshaller.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, true);
marshaller.marshal(a, System.out);
Demo - Output
test.jaxb.EntityA@1292d26
test.jaxb.EntityB@196c1b0
test.jaxb.EntityB@1e13d52
input.xml
<entityA>
<entityBs>
<entityCs/>
<entityCs/>
</entityBs>
<entityBs>
<entityCs/>
<entityCs/>
</entityBs>
</entityA>
Below is another example of using @XmlInverseReference with a JPA model
- http://bdoughan.blogspot.com/2010/07/jpa-entities-to-xml-bid irectional.html
FUDForum. Page generated in 0.03640 seconds
