Re: concurrent report generation [message #548948 is a reply to message #548947] |
Fri, 23 July 2010 13:56 |
You can also look at the viewer properties file:
# Maximum number of simultaneous viewing sessions that can be open at the
# same time, to prevent cache overflowing through multiple requests.
# A value of 0 means no limit.
viewer.session.maximumSessionCount=0
# Behavior that must be used once the maximum session count is reached
# (if different than 0):
# - A value of 0 will use the "Discard new session" policy that will show
# an error message for all the newer sessions.
# - A value of 1 will use the "Discard the oldest session" policy that will
# try to discard the oldest session, even if it has not expired yet.
# Note that "busy" sessions (for example downloading results) won't be
# cleant by this mechanism.
viewer.session.maximumSessionCountPolicy=1
Jason
On 7/23/2010 9:50 AM, Jason Weathersby wrote:
> Maybe you could do this with tomcat configuration:
> http://tomcat.apache.org/tomcat-5.5-doc/config/http.html
> Check maxThreads and acceptCount
> Jason
> On 7/22/2010 3:47 PM, Joanne wrote:
>> Does any one know how i can limit number of concurrent report generation
>> for BIRT Viewer Example deployed in tomcat 5.5?
>> Thanks
FUDForum. Page generated in 0.03413 seconds
