Home » Archived » BIRT » BIRT Excel export, Office 2007, warning(The file you are trying to open, 'name.ext', is in a different format than specified by the file extension.)
Re: BIRT Excel export, Office 2007, warning [message #548674 is a reply to message #548367] |
Thu, 22 July 2010 15:41 |
Reinhard,
Are you running the XLS directly from the designer or are you first
viewing it in the viewer and then exporting to xls?
Jason
On 7/21/2010 11:08 AM, Reinhard wrote:
> Hello,
> opening my BIRT excel report with Office 2007 causes warning:
> than specified by the file extension. Verify that the file is not
> corrupted and is from a trusted source before opening the file. Do you
> want to open the file now?
> How can I avoid this warning?
> I'm using:
> BIRT 2.5.2
> Office 2007
> Eclipse Build: 20100218-1602
> Regards
> Reinhard
Re: BIRT Excel export, Office 2007, warning [message #549170 is a reply to message #548367] |
Sun, 25 July 2010 18:19 |
I always get that warning and you can ignore it. The default Excel emitter doesn't write binary-format Excel files, it writes an interchange format that Microsoft publishes. Excel recognizes the file type when it parses the input but complains that it should have a different extension so it won't have to change gears. I don't know what the extension Microsoft expects is.
Current Time: Sat May 11 12:55:50 GMT 2024
Powered by FUDForum. Page generated in 0.04994 seconds
