Home » Language IDEs » Java Development Tools (JDT) » I can install the ADT plugin, but it doesn't show up
I can install the ADT plugin, but it doesn't show up [message #547831] Mon, 19 July 2010 13:47 Go to next message
Hello all. I've been trying to install the ADT plugin into eclipse. I successfully downloaded the packages from the https:// google server. It even says they're installed on the "What is already installed?" page. Unfortunately, when I go to "Window>Preferences" there is no android tab to be found, as well as when I go to "File>New>Project" with again, no android tab. Any help is appreciated Smile
Re: I can install the ADT plugin, but it doesn't show up [message #549512 is a reply to message #547831] Mon, 26 July 2010 21:19 Go to previous messageGo to next message
I got the same problem and couldn't find how to solve it through google.
Re: I can install the ADT plugin, but it doesn't show up [message #554424 is a reply to message #547831] Mon, 23 August 2010 02:03 Go to previous messageGo to next message
I have the same issue Help Please Urgent
Re: I can install the ADT plugin, but it doesn't show up [message #559809 is a reply to message #547831] Sat, 18 September 2010 23:14 Go to previous message
I found the solution. A post on Android Forum implanted the idea that we're all using the latest version of eclipse, which is 3.6 (hard to tell in Help | About Eclipse). So; I found an earlier version 3.5.2. I installed that and reworked the ADT instructions. It worked.
Eclipse for Java Developers v3.5.2
http://www.eclipse.org/downloads/packages/release/galileo/sr 2
Android Forum Post
http://androidforums.com/application-development/119431-scre enshots-android-sdk-not-showing-up-eclipse-d.html
[Updated on: Sat, 18 September 2010 23:46] by Moderator
Previous Topic:Poor junit performance with threaded tests in 3.6
Next Topic:Make Eclipse + Javadocs ignore a certain file
Current Time: Thu Nov 06 21:07:25 EST 2025
Powered by FUDForum. Page generated in 0.03760 seconds
