Re: NullPointerException in ReportDesigner (Debug Report) [message #548166 is a reply to message #548133] |
Tue, 20 July 2010 21:35 |
Debugging the report is usually used when you want to debug Java or
JavaScript event handlers. Look at the report item in the debug
perspective. This does appear to be a bug in the debugger. Can you
select the view report in web viewer from the toolbar and see if that works.
Jason
On 7/20/2010 2:13 PM, ISK wrote:
> Hi Jason,
> Thank you for your help.
> 1. Report runs fine when I use preview tab in designer or when I run it
> from dynamic menu using "Report/Run Report"
> 2. I do not set any beakpoints
> 3. My report xml file is here:
> http://pastebin.com/VfyLCUDv
> Ilya
Re: NullPointerException in ReportDesigner (Debug Report) [message #548647 is a reply to message #548196] |
Thu, 22 July 2010 14:32 |
I tried this as well and it does appear to be a bug. I will log it.
You can still debug the run task, but the error comes on the render task.
Jason
On 7/21/2010 12:47 AM, ISK wrote:
> "View Report" from the toolbar works, it also creates word and HTML
> reports without any problems.
> Debugging does not work from any of the available places (Dynamic menu
> on the right-click, Run menu) and fails with the same NullPointerException.
Re: NullPointerException in ReportDesigner (Debug Report) [message #548648 is a reply to message #548647] |
Thu, 22 July 2010 14:34 |
Here is the bug entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320639
On 7/22/2010 10:32 AM, Jason Weathersby wrote:
> I tried this as well and it does appear to be a bug. I will log it. You
> Jason
FUDForum. Page generated in 0.04240 seconds
