Home » Language IDEs » PHP Development Tools (PDT) » Debugger breaks at every Zend Framework class
Debugger breaks at every Zend Framework class [message #547214] Thu, 15 July 2010 20:49 Go to next message
I recently installed PDT Helios from the Zend Framework site on Ubuntu 10.04 and now when using the debugger, it will break everytime a new class is referenced in the stack for all Zend Framework classes. As far as I can tell, it is only done with ZF classes, and not my application's own classes.
If I have no breakpoints set, it will run continuously until completion but when I set a breakpoint, it stops at every Zend Class along the way.
I never had this problem before. Any workaround for it? This is really a nuisance as it makes debugging pretty much impossible.
Re: Debugger breaks at every Zend Framework class [message #547216 is a reply to message #547214] Thu, 15 July 2010 21:01 Go to previous messageGo to next message
I just installed Galileo to check and debugging works correctly in Galileo. The only difference I notice is that in the Breakpoints tab, the file names are different
Galileo just lists the file name
eg. IndexController.php [line: 9]
while Helios lists longer names:
eg. /myproject/application/controllers/IndexController.php [line: 9]
Would love to get this working on Helios as it seems to be much faster.
Re: Debugger breaks at every Zend Framework class [message #547226 is a reply to message #547216] Thu, 15 July 2010 23:03 Go to previous messageGo to next message
I had similar problem.
Try update "2.2.0 / M201006170734".
PHP Development Tools (PDT) - Downloads
or latest stable build (not recommended).
https://build.eclipse.org/hudson/job/cbi-pdt-2.2-helios/last StableBuild/
Re: Debugger breaks at every Zend Framework class [message #547232 is a reply to message #547226] Fri, 16 July 2010 00:04 Go to previous messageGo to next message
Hmmm...I think I'm using that build already:
My Build ID: 20100617-1415
Re: Debugger breaks at every Zend Framework class [message #548775 is a reply to message #547214] Thu, 22 July 2010 19:16 Go to previous messageGo to next message
Same issue here, but I can confirm that it is not limited to Zend Framework classes. I added PHPExcel as a module and it stops at every PHPExcel class for me.
Re: Debugger breaks at every Zend Framework class [message #548777 is a reply to message #548775] Thu, 22 July 2010 19:21 Go to previous messageGo to next message
I have opened a bug about this - https://bugs.eclipse.org/bugs/show_bug.cgi?id=320058
You may want to post your experience on the bug report to let them know that it is a common problem.
Re: Debugger breaks at every Zend Framework class [message #548851 is a reply to message #548775] Fri, 23 July 2010 05:59 Go to previous messageGo to next message
again Wink
Re: Debugger breaks at every Zend Framework class [message #548955 is a reply to message #548851] Fri, 23 July 2010 10:28 Go to previous messageGo to next message
Ok, that worked. Thank you!
Re: Debugger breaks at every Zend Framework class [message #548959 is a reply to message #547214] Fri, 23 July 2010 10:34 Go to previous messageGo to next message
Newbie question..
How do I manually apply that update once I download it?
Ok, I think I figured that part out, just point the "Install New Software" to content.jar in the update folder.
Now I get :
An error occurred while collecting items to be installed
session context was:(profile=epp.package.php, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact not found: osgi.bundle,org.eclipse.php.debug.core,2.2.0.v20100617-1400.
jar:file:/Users/seed/Downloads/pdt-Update-M201006170734/arti facts.jar!/plugins/org.eclipse.php.debug.core_2.2.0.v2010061 7-1400.jar
Artifact not found: osgi.bundle,org.eclipse.php.debug.core.source,2.2.0.v2010061 7-1400.
jar:file:/Users/seed/Downloads/pdt-Update-M201006170734/arti facts.jar!/plugins/org.eclipse.php.debug.core.source_2.2.0.v 20100617-1400.jar
Artifact not found: org.eclipse.update.feature,org.eclipse.php.all,2.2.0.v201005 19-1400-53-7A51J1WES6MOWsOaXRLXQYez-.
jar:file:/Users/seed/Downloads/pdt-Update-M201006170734/arti facts.jar!/features/org.eclipse.php.all_2.2.0.v20100519-1400 -53-7A51J1WES6MOWsOaXRLXQYez-.jar
Artifact not found: org.eclipse.update.feature,org.eclipse.php,2.2.0.v20100519-1 400-7L7J-F8NcJTJKEUF9UcJJ.
jar:file:/Users/seed/Downloads/pdt-Update-M201006170734/arti facts.jar!/features/org.eclipse.php_2.2.0.v20100519-1400-7L7 J-F8NcJTJKEUF9UcJJ.jar
Artifact not found: org.eclipse.update.feature,org.eclipse.php.mylyn,2.2.0.v2010 0519-1400-2--7w3121152101411.
jar:file:/Users/seed/Downloads/pdt-Update-M201006170734/arti facts.jar!/features/org.eclipse.php.mylyn_2.2.0.v20100519-14 00-2--7w3121152101411.jar
Artifact not found: osgi.bundle,org.eclipse.php.mylyn.ui,1.0.0.v20100410-0300.
jar:file:/Users/seed/Downloads/pdt-Update-M201006170734/arti facts.jar!/plugins/org.eclipse.php.mylyn.ui_1.0.0.v20100410- 0300.jar
Artifact not found: org.eclipse.update.feature,org.eclipse.php.sdk,2.2.0.v201005 19-1400-53-84QAN2IGRoLXQNHWPXdyLa9Od.
jar:file:/Users/seed/Downloads/pdt-Update-M201006170734/arti facts.jar!/features/org.eclipse.php.sdk_2.2.0.v20100519-1400 -53-84QAN2IGRoLXQNHWPXdyLa9Od.jar
Artifact not found: org.eclipse.update.feature,org.eclipse.php.source,2.2.0.v201 00519-1400-7L7J-F8NcJTJKEUF9UcJJ.
jar:file:/Users/seed/Downloads/pdt-Update-M201006170734/arti facts.jar!/features/org.eclipse.php.source_2.2.0.v20100519-1 400-7L7J-F8NcJTJKEUF9UcJJ.jar
[Updated on: Fri, 23 July 2010 10:43] by Moderator
Re: Debugger breaks at every Zend Framework class [message #548968 is a reply to message #548959] Fri, 23 July 2010 10:47 Go to previous messageGo to next message
I couldn't figure out how to install the All-in-one update. The instructions at http://wiki.eclipse.org/PDT/Updates are very vague. I didn't understand how to "point it at your existing workspace"
So I just downloaded the SDK and extracted it into /dropins. Then start eclipse with "eclipse -clean"
That worked for me.
[Updated on: Fri, 23 July 2010 10:48] by Moderator
Re: Debugger breaks at every Zend Framework class [message #548973 is a reply to message #547214] Fri, 23 July 2010 10:54 Go to previous message
Matt...
Your way worked! Thank you.
Previous Topic:Autocomplete in CSS files
Next Topic:PHP 5.3 Zend Debugger
Current Time: Mon Nov 03 14:59:52 EST 2025
Powered by FUDForum. Page generated in 0.04570 seconds
