Home » Modeling » Epsilon » [Eugenia] Problem generating the Diagram.
[Eugenia] Problem generating the Diagram. [message #547048] Thu, 15 July 2010 05:30 Go to next message
Hi all,
once I've tested the Eugenia tutorials successfully ;-), I've started
to create my own editor.
During the process, everything is OK, but the last step, the
diagram generation from the gmfgen file, produces an error. The problem
is in the Java generated, concretely in the method
protected boolean provides(CreateNodeViewOperation op) that belongs to
the class MyDSLViewProvider.
This is the generated method, and the problem is in the last return.
There is a variable or a value missing.
* @generated
protected boolean provides(CreateNodeViewOperation op) {
if (op.getContainerView() == null) {
return false;
IElementType elementType = getSemanticElementType(op
.getSemanticAdapter());
EObject domainElement = getSemanticElement(op.getSemanticAdapter());
int visualID;
if (op.getSemanticHint() == null) {
// Semantic hint is not specified. Can be a result of call from
CanonicalEditPolicy.
// In this situation there should be NO elementType, visualID will be
determined
// by VisualIDRegistry.getNodeVisualID() for domainElement.
if (elementType != null || domainElement == null) {
return false;
visualID = GuaranaVisualIDRegistry.getNodeVisualID(op
.getContainerView(), domainElement);
} else {
.getVisualID(op.getSemanticHint());
if (elementType != null) {
if (!GuaranaElementTypes.isKnownElementType(elementType)
|| (!(elementType instanceof IHintedType))) {
return false; // foreign element type
String elementTypeHint = ((IHintedType) elementType)
.getSemanticHint();
if (!op.getSemanticHint().equals(elementTypeHint)) {
return false; // if semantic hint is specified it should be the
same as in element type
if (domainElement != null
&& visualID != GuaranaVisualIDRegistry.getNodeVisualID(
op.getContainerView(), domainElement)) {
return false; // visual id for node EClass should match visual id
from element type
} else {
if (!SolutionEditPart.MODEL_ID.equals(GuaranaVisualIDRegistry
.getModelID(op.getContainerView()))) {
return false; // foreign diagram
switch (visualID) {
default:
return false;
return ;
Re: [Eugenia] Problem generating the Diagram. [message #547049 is a reply to message #547048] Thu, 15 July 2010 05:32 Go to previous messageGo to next message
Sorry,
I sent the previous before finishing it.
The question is: Is the problem I described in the previous message
due to some information I have forgotten in my metamodel annotations?
El 15/07/2010 11:30, Toñi Reina Quintero escribió:
> Hi all,
> once I've tested the Eugenia tutorials successfully ;-), I've started to
> During the process, everything is OK, but the last step, the diagram
> generation from the gmfgen file, produces an error. The problem is in
> * @generated
> return false;
> int visualID;
> determined
> return false;
> } else {
> .getSemanticHint();
> return false; // if semantic hint is specified it should be the same as
> in element type
> return false; // visual id for node EClass should match visual id from
> element type
> } else {
> switch (visualID) {
> default:
> return false;
> return ;
Re: [Eugenia] Problem generating the Diagram. [message #547153 is a reply to message #547049] Thu, 15 July 2010 13:07 Go to previous messageGo to next message
Hi Toni,
It'd probably help if I could have a look at the annotated metamodel.
Dimitris
On 15/07/2010 10:32, Toñi Reina Quintero wrote:
> Sorry,
> The question is: Is the problem I described in the previous message due
>> Hi all,
>> * @generated
>> return false;
>> int visualID;
>> determined
>> return false;
>> } else {
>> .getSemanticHint();
>> in element type
>> element type
>> } else {
>> switch (visualID) {
>> default:
>> return false;
>> return ;
Re: [Eugenia] Problem generating the Diagram. [message #547485 is a reply to message #547153] Sat, 17 July 2010 10:48 Go to previous message
Hi Dimitris,
thanks for your offer, but I'm afraid I have been modifying the
annotated metamodel, trying to solve the problem, and now, I can not
reproduce the same error. Fortunately, now I can generate the editor.
Toñi
El 15/07/2010 19:07, Dimitris Kolovos escribió:
> Hi Toni,
> Cheers,
> Dimitris
>> Sorry,
>>> Hi all,
>>> * @generated
>>> return false;
>>> int visualID;
>>> determined
>>> return false;
>>> } else {
>>> .getSemanticHint();
>>> in element type
>>> element type
>>> } else {
>>> switch (visualID) {
>>> default:
>>> return false;
>>> return ;
Re: [Eugenia] Problem generating the Diagram. [message #590652 is a reply to message #547048] Thu, 15 July 2010 05:32 Go to previous message
Sorry,
> Hi all,
> * @generated
> return false;
> int visualID;
> determined
> return false;
> } else {
> .getSemanticHint();
> in element type
> element type
> } else {
> switch (visualID) {
> default:
> return false;
> return ;
Re: [Eugenia] Problem generating the Diagram. [message #590699 is a reply to message #547049] Thu, 15 July 2010 13:07 Go to previous message
Hi Toni,
Dimitris
> Sorry,
>> Hi all,
>> * @generated
>> return false;
>> int visualID;
>> determined
>> return false;
>> } else {
>> .getSemanticHint();
>> in element type
>> element type
>> } else {
>> switch (visualID) {
>> default:
>> return false;
>> return ;
Re: [Eugenia] Problem generating the Diagram. [message #590752 is a reply to message #547153] Sat, 17 July 2010 10:48 Go to previous message
Hi Dimitris,
Toñi
> Hi Toni,
> Cheers,
> Dimitris
>> Sorry,
>>> Hi all,
>>> * @generated
>>> return false;
>>> int visualID;
>>> determined
>>> return false;
>>> } else {
>>> .getSemanticHint();
>>> in element type
>>> element type
>>> } else {
>>> switch (visualID) {
>>> default:
>>> return false;
>>> return ;
Previous Topic:[Epsilon] Revisiting problems with examples.friends.
Next Topic:[Epsilon] Revisiting problems with examples.friends.
Current Time: Sun Nov 09 20:17:34 EST 2025
Powered by FUDForum. Page generated in 0.04369 seconds
