Home » Eclipse Projects » Eclipse 4 » Comboviewer binding in XWT(How to bind enum value to JFace Comboviewer in XWT)
Comboviewer binding in XWT [message #546834] Wed, 14 July 2010 08:00 Go to next message
I have an object model which contains an enumeration field. I would like to create for it an comboviewer on my xwt form.
I've put the chooseable items by setinput, I also define the contentprovider, labelprovider, everything works fine but the binding.
Let's say the model is a Phone entity which has to fields:
- phoneType is an enumeration
- number is a String
I would like to bind the phoneType to a comboviewer, it should be a comboviewer due to I have to provide the forms on many languages, so I have to use labelprovider..
So, any Idea how to bind the comboviewer's selected item to the model's phoneType?
Thx in advance,
Istvan
[Updated on: Wed, 14 July 2010 08:00] by Moderator
Re: Comboviewer binding in XWT [message #547015 is a reply to message #546834] Wed, 14 July 2010 21:13 Go to previous messageGo to next message
In general, it should be:
<ComboViewer input="{binding path=phoneType}">
</ComboViewer>
But it needs a content provider to return all literals of enum. Please try
it your-self, If it doesn't work, please report a bug.
Best regards
Yves YANG
"Istvan Benedek" <istvan.benedek@bestest.hu> wrote in message
news:i1k8t1$mgq$1@build.eclipse.org...
> to create for it an comboviewer on my xwf form. I've put the chooseable
> phoneType?
> Thx in advance,
> Istvan
Re: Comboviewer binding in XWT [message #547458 is a reply to message #546834] Fri, 16 July 2010 21:51 Go to previous messageGo to next message
I have made a try. The solution I suggested doesn't work.
I have created a bug to track the development of this feature
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320154
Best regards
Yves YANG
Re: Comboviewer binding in XWT [message #547631 is a reply to message #547458] Mon, 19 July 2010 04:18 Go to previous messageGo to next message
This featrue is implemented. The modification is committed in CVS. It'll be
available in the next build.
Please read the bug comment to get more information.
Best regards
Yves YANG
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:i1r2bi$dsg$1@build.eclipse.org...
> Best regards
> Yves YANG
Re: Comboviewer binding in XWT [message #548079 is a reply to message #547631] Tue, 20 July 2010 11:25 Go to previous messageGo to next message
I've just seen your answer.. Thx for the fix. In the meantime we made a workaround...
<ComboViewer name="bloodType"
input="xx.xxx.xxx.xxx.xxx.enums.BloodType">
<ComboViewer.singleSelection>
<Binding path="bloodType">
</Binding>
</ComboViewer.singleSelection>
<ComboViewer.labelProvider>
<c:ServerCoreEnumLabelProvider />
</ComboViewer.labelProvider>
<ComboViewer.contentProvider>
<c:ServerCoreEnumContentProvider />
</ComboViewer.contentProvider>
<ComboViewer.layoutData>
<GridData horizontalAlignment="FILL" verticalAlignment="FILL"
grabExcessHorizontalSpace="true" grabExcessVerticalSpace="true" />
</ComboViewer.layoutData>
<ComboViewer.control>
</ComboViewer.control>
</ComboViewer>
where the ServerCoreEnumContentProvider's getElements
public Object[] getElements(Object inputElement) {
if(inputElement instanceof String){
try{
Class<?> clazz=Class.forName((String) inputElement);
Method method=clazz.getMethod("values", new Class[]{});
Object [] objectArray=(Object[]) method.invoke(clazz, new Object[]{});
if(objectArray !=null)
return objectArray;
else
return EMPTY;
}catch (Exception e) {
e.printStackTrace();
return EMPTY;
obviously it was hack... btw it works for all enum by name binding input parameter.
Istvan
Re: Comboviewer binding in XWT [message #548253 is a reply to message #547631] Wed, 21 July 2010 05:14 Go to previous messageGo to next message
There is an other issue on comboviewer, the setselection invoked before the setinput, which means, the comboviewer does not show the value from the model at first time.
Re: Comboviewer binding in XWT [message #548657 is a reply to message #548253] Thu, 22 July 2010 10:47 Go to previous messageGo to next message
I have noticed this t. it is fixed in the same time .
Best regards
Yves YANG
news:i26dp3$36j$1@build.eclipse.org...
Re: Comboviewer binding in XWT [message #549223 is a reply to message #548657] Mon, 26 July 2010 03:55 Go to previous messageGo to next message
Thx!
Re: Comboviewer binding in XWT [message #549971 is a reply to message #546834] Wed, 28 July 2010 11:33 Go to previous messageGo to next message
org.eclipse.e4.xwt.XWTException: Type cannot be a content of java.lang.Object org.eclipse.e4.xwt.internal.core.Binding.source
When I try the ComboViewer examples I get that exception. Did I forget anything?
Re: Comboviewer binding in XWT [message #550227 is a reply to message #549971] Thu, 29 July 2010 10:50 Go to previous messageGo to next message
Please check with the testcase first.
Best regards
Yves YANG
"Mo P." <moritzpavlik@gmx.de> wrote in message
news:i2pijs$6m0$1@build.eclipse.org...
> anything?
Re: Comboviewer binding in XWT [message #550231 is a reply to message #546834] Thu, 29 July 2010 11:00 Go to previous messageGo to next message
I tried the ComboViewer_enum and ComboViewer_enum_singleSelection which are both in ...tests.jface.enumeration.
Re: Comboviewer binding in XWT [message #550604 is a reply to message #550231] Sat, 31 July 2010 04:44 Go to previous messageGo to next message
The testcase works fine for me. Please make sure you have used the last
build.
Best regards
Yves YANG
news:i2s51m$eo8$1@build.eclipse.org...
Re: Comboviewer binding in XWT [message #553086 is a reply to message #546834] Mon, 16 August 2010 08:39 Go to previous messageGo to next message
where can i get the latest build? do i have to check out the classes and build the jar on my own?
when i download the latest release of eclipse e4 the filename is org.eclipse.e4.xwt_0.9.1.v20100720-1930.jar. why isnt that jar updated?
thanks in advance
Re: Comboviewer binding in XWT [message #553800 is a reply to message #553086] Wed, 18 August 2010 17:54 Go to previous message
You can find here:
http://download.eclipse.org/e4/downloads/
Best regards
Yves YANG
news:i4bbi7$ikh$1@build.eclipse.org...
> thanks in advance
Re: Comboviewer binding in XWT [message #578898 is a reply to message #547631] Tue, 20 July 2010 11:25 Go to previous message
</Binding>
</ComboViewer>
try{
return objectArray;
else
return EMPTY;
return EMPTY;
Istvan
Re: Comboviewer binding in XWT [message #578966 is a reply to message #547631] Wed, 21 July 2010 05:14 Go to previous message
Re: Comboviewer binding in XWT [message #579090 is a reply to message #548253] Thu, 22 July 2010 10:47 Go to previous message
Best regards
Yves YANG
Re: Comboviewer binding in XWT [message #579446 is a reply to message #548657] Mon, 26 July 2010 03:55 Go to previous message
Thx!
Re: Comboviewer binding in XWT [message #579580 is a reply to message #549971] Thu, 29 July 2010 10:50 Go to previous message
Best regards
Yves YANG
> anything?
Previous Topic:Testing Text style
Next Topic:Comboviewer binding in XWT
Current Time: Fri Sep 26 23:59:09 EDT 2025
Powered by FUDForum. Page generated in 0.12598 seconds
