Home » Eclipse Projects » Remote Application Platform (RAP) » [TreeViewer] post selection changes are not handled as expected (as in RCP)?
[TreeViewer] post selection changes are not handled as expected (as in RCP)? [message #546673] Tue, 13 July 2010 13:40 Go to next message
I added a post selection changed listener to my TreeViewer like this:
TreeViewer.addPostSelectionChangedListener(new ISelectionChangedListener() {
    public void selectionChanged(final SelectionChangedEvent e) {
        System.out.println("post selection changed");
The problem is that if I change the selection twice very quickly by pressing the arrow up or arrow down key, then "post selection changed" is printed out twice. But it should occur only once - exactly for the last selected element, isn't it?
Because the JavaDoc of IPostSelectionProvider says:
* A post selection changed event is equivalent to selection changed event
* if the selection change was triggered by the mouse, but it has a delay
* if the selection change is triggered by keyboard navigation.
In RCP I see it only once, as expected.
Use case:
I need to open the selected objects from my Tree in corresponding editors. But if I change selection quickly with the keyboard I only need to open the object I stop on. Not to open all traversed objects. Isn't it the use of post selection anyway?
Could you please advise me what I could do to make it work like in RCP?
[Updated on: Tue, 13 July 2010 13:42] by Moderator
Re: [TreeViewer] post selection changes are not handled as expected (as in RCP)? [message #548410 is a reply to message #546673] Wed, 21 July 2010 13:26 Go to previous messageGo to next message
Bogdan,
apparently this is a bug in RAP. Feel free to file a bugzilla, however I
doubt that we will be able to fix it.
To work around the issue, you can could implement the delay yourself
with Display#timerExec() or java.util.Timer.
HTH
Rüdiger
> is printed out twice. But it should occur only once, isn't it? Because
> Quote:
>> delay * if the selection change is triggered by keyboard navigation.
> Use case: I need to open the selected objects from my Tree in
Re: [TreeViewer] post selection changes are not handled as expected (as in RCP)? [message #548495 is a reply to message #548410] Thu, 22 July 2010 03:44 Go to previous message
Rüdiger Herrmann wrote on Wed, 21 July 2010 13:26
Bogdan,
apparently this is a bug in RAP. Feel free to file a bugzilla...
Yes, I already did it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=32023
... , however I doubt that we will be able to fix it.To work around the issue, you can could implement the delay yourself
I am already seriously considering it, since I use Display#timerExec() anyway. Thank you!
Previous Topic:sometimes UI cannot automatically refresh, I need to use the mouse to click on UI each tiime
Next Topic:TypeError: undefined is not a function
Current Time: Sat Nov 08 00:03:04 EST 2025
Powered by FUDForum. Page generated in 0.03632 seconds
