Re: P2 Update of RCP based application failes [message #546687 is a reply to message #546613] |
Tue, 13 July 2010 17:59 |
Originally posted by: cjcool.comcast.net
Hey Daniel:
I have a similar issue, but unfortunartely I do not have a solution yet.
However, I was able to get my product-based P2-enabled application to update
by using the following path:
1. Select Help->About MyProduct
2. Click on Installation Details
3. Select the installed product from the lis (MyProduct)
4. Click the Update... button on the bottom of the screen.
Then the Update dialogs appear and it works fine. What I don't understand is
why this path works but the 'Check for Updates' doesn't.
I think it has to do with the RCP being product-based, but I haven't been
able to figure out a workaround. From your post it looks like you are also
doing a product-based build. Is that correct?
BTW, I posted this question back in Dec in the eclipse.platform.pde and in
Jan in the eclipse.technology.equinox groups but did not get a response.
There appears to be a new eclipse.p2 group, so you may want to post your
question there also.
Chris
"Daniel Murygin" <daniel.murygin@googlemail.com> wrote in message
news:i1hu1b$sfv$1@build.eclipse.org...
>I trying to update an Eclipse-RCP-3.5 based application by an P2
>update-site. Application contains two features.
> Product is build by Eclipse Buckminster. Creation of the P2 update site is
> part of the product build.
> When start the update by Menu: Update -> Check for Updates a messages box
> is shown: There is nothing to update.
> When i try Menu: Update -> Install New Software... an select the same
> update-site an error is reported:
> Your original request has been modified.
> "Verinice Anwendung" is already installed, so an update will be performed
> instead.
> "verinice server Feature" is already installed, so an update will be
> performed instead.
> Cannot complete the install because of a conflicting dependency.
> Software being installed: Verinice Anwendung 1.1.1.201007130142
> (sernet.gs.ui.rcp.main.feature.feature.group 1.1.1.201007130142)
> Software currently installed: verinice 1.1.1
> (sernet.gs.ui.rcp.main.product 1.1.1)
> Only one of the following can be installed at once: Verinice Anwendung
> 1.1.1.201007130142 (sernet.gs.ui.rcp.main.feature.feature.jar
> 1.1.1.201007130142)
> Verinice Anwendung 1.1.1.201007021358
> (sernet.gs.ui.rcp.main.feature.feature.jar 1.1.1.201007021358)
> Cannot satisfy dependency:
> From: Verinice Anwendung 1.1.1.201007021358
> (sernet.gs.ui.rcp.main.feature.feature.group 1.1.1.201007021358)
> To: sernet.gs.ui.rcp.main.feature.feature.jar [1.1.1.201007021358]
> From: Verinice Anwendung 1.1.1.201007130142
> To: sernet.gs.ui.rcp.main.feature.feature.jar [1.1.1.201007130142]
> From: verinice 1.1.1 (sernet.gs.ui.rcp.main.product 1.1.1)
> To: sernet.gs.ui.rcp.main.feature.feature.group [1.1.1.201007021358]
> What's going wrong?
FUDForum. Page generated in 0.04072 seconds
