problem with websphere application server [message #546161] |
Sun, 11 July 2010 17:53  |
I downloaded eclipse-jee-helios-win32.zip and unzipped it.
I would like to add WebSphere Application Server.
The first time I new server, I was asked for configure WebSphere 6.0 Runtime environment, I specified JRE and IBM WebSphere Installation Directory, but got message:
ActivitySession.jar is missing from directory C:\Program Files\IBM\WebSphere\AppServer\lib. I manually added it(copying it from RAD), then asked for more, Eventually, I added 72 jars(Silly I am).
Then I was able to create the runtime.
Then I was asked to configure the IBM WebSphere v6.0 Server.
I input :
Port: 9080
Server Profile Directory: C:\Program Files\IBM\WebSphere\AppServer\profiles
Cell: cell1
Node: node1
Server: server1
Then I got server1 created, but when I tried to start it, I got:
The java class is not found: Files.IBM.WebSphere.AppServer.java.jre.lib.ext.ibmorb.jar
The installed JRE I used for WebSphere Runtime is:
C:\Program Files\IBM\WebSphere\AppServer\java, from which I can see ibmorb.jar was there for sure under C:\Program Files\IBM\WebSphere\AppServer\java\jre\lib\ibmorb.jar
Could anybody tell me if I am doing the right approach? I could not get a step-by-step manual to get eclipse working with websphere applicaiton server. So any help would be greatly appreciated!h
Re: problem with websphere application server [message #851709 is a reply to message #546161] |
Sat, 21 April 2012 03:57  |
I am a fresher working in ODM project Me too having same problem while adding new ibm websphere sever missing activity session.jar have you tried and go succeed. Plz help me too instruct me how i may do things to get clear with that missing class path error..
FUDForum. Page generated in 0.07954 seconds
