Home » Archived » M2M (model-to-model transformation) » [QVTr] QVTd Project - Errors in examples?
[QVTr] QVTd Project - Errors in examples? [message #545898] Fri, 09 July 2010 10:48 Go to next message
I've recently built the QVTd Development Environment as per the instructions at:
http://wiki.eclipse.org/M2M/QVT_Declarative_Installation#Ins tallation_of_QVTd_Development_Environment
with the exception of installing MDT UML2 SDK 3.1.0RC4 instead of UML2 SDK 3.1M4, as the older release is no longer available.
Specifically, I am interested in using it with qvtr files, and thought that a natural place to start would be with the examples. However, loading either of the ones provided results in quite a few errors. Running with the Relations to Core example, the errors are:
http://pastebin.com/WYg1Scy5
I am new to using QVTr, so am unsure if this is due to errors in the example code, or bugs in the implementation, or indeed something else. If it's something I've done wrong then I'd appreciate any guidance on it.
Also, with being new to this I am currently trying to get my head round some (or rather quite a few) things. Can anyone recommend somewhere good to start?
[Updated on: Fri, 09 July 2010 11:43] by Moderator
Re: [QVTr] QVTd Project - Errors in examples? [message #546050 is a reply to message #545898] Sat, 10 July 2010 07:19 Go to previous messageGo to next message
Hi Chris
Thanks for the prod.
I've just updated this for the Helios release, which avoids transient
Milestones and with most of the epndencies in the Helios Modeling
Package installation is easier. More so if you use the Update ZIP,
which will fully update a naked Eclipse in one go.
> http://pastie.org/1037541
Ow. It's embarrassing when my work on one project (MDT/OCL) breaks by
other project (M2M/QVTd).
QVT is aligned with OCL, so with OCL about to define what is reserved
about a reserved word, MDT/OCL has implemented it, and M2M/QVTd had not
been rebuilt accordingly.
Yesterday, M2M/QVTd allowed xx, or "xx" as a property identifier and
xx or _xx as a simpleName (more general navigation). Now M2M/QVTd allows
xx, or _'xx' in both contexts and for compatibility "xx" as a property
identifier or _xx as a simpleName.
This is in CVS. I'll try to get a QVTd release promoted to the project
downloads page.
RelToCore.qvtr now uses e.g. _'domain' as an identifier throughout.
> to start?
QVTr (and even more so QVTc) are very slow to take off. The Eclipse
M2M/QVTd editor might be best. The ModelMorf executor might be best. The
Medini QVT editor and executor might be the most useable. Each has some
documentation. None has a strong team of active developers. Any volunteers?
Ed Willink
Re: [QVTr] QVTd Project - Errors in examples? [message #546283 is a reply to message #546050] Mon, 12 July 2010 07:42 Go to previous messageGo to next message
Edward Willink wrote on Sat, 10 July 2010 07:19
Thanks for the response. I take it from that paragraph that QVTd doesn't have the ability to execute QVTr (that or I'm missing a Run Configuration). ModelMorf being proprietary pretty much rules it out, I'll go and take a look at Medini this afternoon.
As an aside, I've got the QVTd environment up and running, and can see that there are still some errors shown on loading the examples, though they are caused by a couple of instances of the "implementedby" keyword. Am I right in understanding that those are only there because of a missing implementation, rather than problems with the environment?
Thanks again for your help, and sorry for any inane questions I may have asked due to being new to this.
Re: [QVTr] QVTd Project - Errors in examples? [message #546441 is a reply to message #546283] Mon, 12 July 2010 14:56 Go to previous message
Hi Chris
> Configuration).
Yes. No Run Configuration or equivalent.
I'm not certain that it is definitely proprietary. Betas have been
freely available. Progress to the licensed release does not appear to
have happened.
Yes. Since black box functions couldn't be executed, I didn't struggle
to find a solution to the lack of specification about how a Black Box
function declaration was imported.
No problem. Few people have got that far.
Ed Willink
Previous Topic:[ATL] One target model and more than one target metamodels
Next Topic:[ATL] execution order and UML profiles
Current Time: Thu Jun 19 22:32:52 EDT 2025
Powered by FUDForum. Page generated in 0.03622 seconds
