Re: RAServer failed to start [message #55349 is a reply to message #55019] |
Tue, 28 February 2006 08:47 |
Andreas Heinecke Messages: 21 Registered: July 2009 |
thanks for your answer.
You asked for the following:
> 1. If "/tmp/IBMRAC" writable by all user (mode 777)
Yes, it is.
> 2. If "/tmp/IBMRAC/ramaster" is recreated after you run "RAStart.sh" the
> second time
Yes, ramaster is recreated after I run RAStart.sh the second time.
> 3. You Linux distribution and kernel version
I use an Fedora Core 4 with a self compiled kernel 2.6.12.1.
The log tells:
"Cannot resolve the host name of the local machine. Ensure the fully
qualified host name of the local machine is registered with the Domain Name
Server (DNS)."
and
"Cannot create master named pipe: ramaster. Make sure the named pipe is free
and no other Agent Controller is using the same named pipe."
The other log entries are no error messages, as far as I can see.
Andreas
Samson Wai wrote:
> Can you check the following?
> second time
> You can generate a detailed log by editing the Agent Controller's
> "config/serviceconfig.xml" file and change the "loggingLevel" attribute
> to "DEBUG". Rerun "RAStart.sh" and you can check the log for more
> detailed information.
> Regards,
> Samson
> Andreas Heinecke wrote:
>> Hi Group,
>> I've problems to get the Agent Controller to start. I'm using linux and
>> followed the instructions. I set the LD_LIBRARY_PATH variable and set the
>> bin folder to PATH. Then I run the configuration.
>> The next would be to start the controller with RAStart.sh but it always
>> tells me: "RAServer failed to start".
>> Without any other information.
>> As I looked into the servicelog I found the following error log:
>> free and no other Agent Controller is using the same named pipe."
>> So I tried to delete the /tmp/IBMRAC/ramaster and start the RAStart.sh
>> again, but with the same result.
>> Whats going wrong?
>> Please help me, I ran out of ideas.
>> Andreas
Re: RAServer failed to start [message #55454 is a reply to message #55349] |
Tue, 28 February 2006 12:47 |
This still doesn't work. Why is it so complicated to get this thing running?
I recently read about IAC. How can I use this? Am I right, that using IAC
will keep me from using RAC, if profiling on the same machine?
The problem is now that I dont know how to configure TPTP to use the IAC
instead of the RAC.
Andreas
> Yes, it is.
>> second time
> The log tells:
> Name Server (DNS)."
> and
> Andreas
> Samson Wai wrote:
>> Hi,
>> second time
>> Regards,
>> Samson
>>> Hi Group,
>>> the bin folder to PATH. Then I run the configuration.
>>> Whats going wrong?
>>> Andreas
FUDForum. Page generated in 0.04364 seconds
