Home » Archived » B3 » macos carbon broken?
macos carbon broken? [message #544995] Tue, 06 July 2010 05:52 Go to next message
Hi all,
I have created a working b3aggr model for a composite repository containing
the Helios update site without mirroring artifacts.
However, if I enable these configurations:
* macosx, carbon, x86
* macosx, carbon, ppc
then the build fails with the following error during verifying these
configs:
Missing requirement for filter properties ~= $0:
org.eclipse.rcp.configuration.feature.group 1.0.0.I20100608-0911 requires
'toolingorg.eclipse.equinox.launcher.carbon.macosx [1.1.0.v20100503]' but it
could not be found
Is this a bug? If yes, it is maybe the same one as the one described in the
last post in this newsgroup ("Unable to build Helios release with b3")?
Thanks for your help.
Axel
Re: macos carbon broken? [message #544996 is a reply to message #544995] Tue, 06 July 2010 05:53 Go to previous messageGo to next message
Note that macosx with cocoa does work without problems.
Greetings
Axel
Axel Guckelsberger wrote:
> Hi all,
> containing the Helios update site without mirroring artifacts.
> configs:
> it could not be found
> the last post in this newsgroup ("Unable to build Helios release with
> b3")?
> Regards,
> Axel
Re: macos carbon broken? [message #544997 is a reply to message #544996] Tue, 06 July 2010 06:08 Go to previous message
Could it be possible that this works only when building the composite
repository on a Windows machine? (just like with the branding iron bug, too)
Axel
> Greetings
> Axel
>> Hi all,
>> configs:
>> b3")?
>> Regards,
>> Axel
Re: macos carbon broken? [message #611586 is a reply to message #544995] Tue, 06 July 2010 05:53 Go to previous message
Greetings
Axel
> Hi all,
> configs:
> b3")?
> Regards,
> Axel
Re: macos carbon broken? [message #611588 is a reply to message #544996] Tue, 06 July 2010 06:08 Go to previous message
Axel
> Greetings
> Axel
>> Hi all,
>> configs:
>> b3")?
>> Regards,
>> Axel
Previous Topic:macos carbon broken?
Next Topic:Aggregator: Transformation failed: null
Current Time: Thu Apr 17 21:49:02 EDT 2025
Powered by FUDForum. Page generated in 0.25553 seconds
