It works on Windows XP but Windows 7 doesn't work.
When I block createCategories(PaletteRoot root) method , It works fine.
otherwise It works creating only 4 item on each group.
below is source code..
private static List<PaletteContainer> createCategories(PaletteRoot root) {
xmlRootNode = initXmlData("Surge.xml");
List<PaletteContainer> categories = new ArrayList<PaletteContainer>();
Iterator<XMLNode> it = xmlRootNode.getChildNodes().iterator();
String sGroupLabel = null;
String sGroupName = null;
String sGroupPath = null;
String sName = null;
String sSVGPath = null;
String sIconPath = null;
String sNodeName = null;
while(it.hasNext()){
XMLNode tmpNode = it.next();
sGroupLabel = (String) tmpNode.getAttribute("name");
sGroupName = tmpNode.getNodeName();
sGroupPath = (String) tmpNode.getAttribute("path");
PaletteDrawer drawer = new PaletteDrawer(sGroupLabel,
ImageDescriptor.createFromFile(AppPaletteView.class, "/kr/a2m/gef/palette/icons/"+sGroupPath));
Iterator<XMLNode> it2 = tmpNode.getChildNodes().iterator();
while(it2.hasNext()){
XMLNode tmp2Node = it2.next();
Iterator<XMLNode> it3 = tmp2Node.getChildNodes().iterator();
// List<CombinedTemplateCreationEntry> entries = new ArrayList<CombinedTemplateCreationEntry>();
sNodeName = tmp2Node.getNodeName();
int iSize = 0;
while(it3.hasNext()){
XMLNode tmp3Node = it3.next();
if( "name".equals(tmp3Node.getNodeName()) ){
sName = tmp3Node.getNodeValue();
}else if( "icon_path".equals(tmp3Node.getNodeName()) ){
sIconPath = "icons/"+tmp3Node.getNodeValue();
}else if( "svg_path".equals(tmp3Node.getNodeName()) ){
sSVGPath = "/kr/a2m/gef/figure/svg/images/"+tmp3Node.getNodeValue();
}else if( "size".equals(tmp3Node.getNodeName()) ){
iSize = Integer.parseInt(tmp3Node.getNodeValue());
CombinedTemplateCreationEntry combined = new CombinedTemplateCreationEntry(
sName,
sName,
new AtpNodeCreateFactory(sSVGPath, sGroupName, sNodeName, sName, iSize),
ImageDescriptor.createFromFile(AppPaletteView.class, sIconPath),
ImageDescriptor.createFromFile(AppPaletteView.class, sIconPath));
// entries.add(combined);
// drawer.addAll(entries);
drawer.add(combined);
categories.add(drawer);
return categories;
and below is log file.
!ENTRY org.eclipse.ui.workbench 4 0 2010-07-06 16:42:32.255
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDisposed(WorkbenchPartReference.java:171)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:117)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Widget.release(Widget.java:804)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:755)
at org.eclipse.swt.widgets.Widget.release(Widget.java:807)
at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:174)
at org.eclipse.swt.widgets.Decorations.releaseChildren(Decorations.java:771)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1211)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:441)
at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java:446)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:674)
at org.eclipse.swt.widgets.Display.release(Display.java:3472)
at org.eclipse.swt.graphics.Device.dispose(Device.java:261)
at kr.a2m.gef.Application.start(Application.java:36)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!ENTRY org.eclipse.ui.workbench 4 0 2010-07-06 16:42:32.258
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2010-07-06 16:42:32.260
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2010-07-06 16:42:32.261
!STACK 0
Anybody help me~~~! I'm sick of this situation. and I can't find any way to solve it..
