Home » Language IDEs » C / C++ IDE (CDT) » Exploring std::map and std::list in debugger(can't see any data inside)
Exploring std::map and std::list in debugger [message #544836] Mon, 05 July 2010 12:42 Go to next message
Using Eclipse CDT Helios with GNU gdb 6.8.
I would like to see something like this (MSVC2008):
http://omploader.org/vNHVlNQ/MSVC2008-Debugger-Map-List.png
http://omploader.org/vNHVlNg/MSVC2008-Debugger-Map-List-Iterator.png
And now in Eclipse I can see only this:
http://omploader.org/vNHVlOA/Eclipse-CDT-Debugger-Map-List.png
http://omploader.org/vNHVlOQ/Eclipse-CDT-Debugger-Map-List-Iterator.png
No any data displayed. It is not possible to debug programs. How can this be resolved?
Re: Exploring std::map and std::list in debugger [message #544844 is a reply to message #544836] Mon, 05 July 2010 12:57 Go to previous messageGo to next message
See earlier - no binaries.
Re: Exploring std::map and std::list in debugger [message #544855 is a reply to message #544844] Mon, 05 July 2010 13:44 Go to previous messageGo to next message
No any binaries, there were only screenshots inside messages on the forum.
For a very simple program like this one:
#include <map>
#include <list>
#include <string>
using namespace std;
int main()
    typedef map<string, list<string> > map_t;
    map_t m;
    m["one"].push_back("a");
    m["one"].push_back("b");
    m["one"].push_back("c");
    m["two"].push_back("1");
    m["two"].push_back("2");
    m["two"].push_back("3");
    map_t::const_iterator i = m.begin();
    i++;
    return 0; // <= break point on this line
I've set break point on the line with return statement.
In MSVC2008 debugger I see something like:
[-] m[2]("one",[3]("a","b","c")),("two",[3]("1","2","3")))
 [+] [0] ("one",[3]("a","b","c"))
 [+] [1] ("two",[3]("1","2","3"))
and
[+] i ("two",[3]("1","2","3"))
And Eclipse shows me like this:
[-] m     | map_t                            | {...}
 [+] _M_t | std::_Rb_tree<std::basic_strin.. | {...}
and
[-] i        | std::_Rb_tree_const_iterator<s.. | {...}
 [+] _M_node | std::_Rb_tree<std::basic_strin.. | 0x3e2550
no actual data inside std::map or std::list is displayed.
Re: Exploring std::map and std::list in debugger [message #544897 is a reply to message #544836] Mon, 05 July 2010 18:41 Go to previous messageGo to next message
CDT 7.0 support of GDB's pretty-printing feature. Requires GDB 7.0 or newer as well as python, and GDB's python pretty-printers. Some information available here
Re: Exploring std::map and std::list in debugger [message #544913 is a reply to message #544897] Tue, 06 July 2010 00:33 Go to previous messageGo to next message
Andrey Kourskov wrote on Mon, 05 July 2010 18:41
Already using latest CDT version. Downloaded gdb-7.1-2-mingw32-bin.tar.gz from sourceforge, unpacked to MinGW directory. Now "gdb --version" tells me "GNU gdb (GDB) 7.1". But no any changes in Eclipse debugger, data in STL containers is not displayed.
Re: Exploring std::map and std::list in debugger [message #545005 is a reply to message #544913] Tue, 06 July 2010 06:44 Go to previous messageGo to next message
Nobody wrote on Tue, 06 July 2010 00:33
You have to load some python code into via gdbinit. You can find more info here http://sourceware.org/gdb/wiki/STLSupport
Re: Exploring std::map and std::list in debugger [message #545035 is a reply to message #545005] Tue, 06 July 2010 09:34 Go to previous messageGo to next message
Axel Mueller wrote on Tue, 06 July 2010 06:44
So I have done this: "svn co svn://gcc.gnu.org/svn/gcc/trunk/libstdc++-v3/python". Also created .gdbinit in home directory with content from the link above, changed the path to checked out python directory.
Also I pointed to ~/.gdbinit in Eclipse debug configuration. And now I have the following error:
.gdbinit:6: Error in sourced command file:
Python scripting is not supported in this copy of GDB.
What is wrong with GDB? I have downloaded it from http://sourceforge.net/projects/mingw/files/MinGW/BaseSystem /GDB/GDB-7.1/gdb-7.1-2-mingw32-bin.tar.gz/download. Is this the official place for downloading latest available GDB?
P.S. why such a simple thing like debugging c++ code with STL containers (works in MSVC for a long time) is so non-trivial for Eclipse?
Re: Exploring std::map and std::list in debugger [message #545090 is a reply to message #545035] Tue, 06 July 2010 11:23 Go to previous messageGo to next message
Try to instal this MinGW GDB build
Re: Exploring std::map and std::list in debugger [message #545103 is a reply to message #545090] Tue, 06 July 2010 12:03 Go to previous messageGo to next message
Andrey Kourskov wrote on Tue, 06 July 2010 11:23
Thanks for the link. How did you get it by the way?
Now I have this in gdb console:
(gdb) break 18
Breakpoint 1 at 0x401a40: file ..\src\test.cpp, line 18.
(gdb) run
Starting program: ...\Projects\Eclipse\CDT\test\Debug/test.exe
[New Thread 3784.0xb20]
Breakpoint 1, main () at ..\src\test.cpp:18
18          return 0;
(gdb) print m
$1 = std::map with 2 elements = {
  ["one"] = std::list = {
    [0] = "a",
    [1] = "b",
    [2] = "c"
  ["two"] = std::list = {
    [0] = "1",
    [1] = "2",
    [2] = "3"
So it seems that now GDB can show values inside STL container now.
But almost nothing has changed inside Eclipse when I point to new GDB and .gdbinit file. I mean that it still shows me something like this:
The only progress is in Details below:
	Details:std::map with 2 elements = {\n  ["one"] = std::list = {\n    [0] = "a",\n ...   [2] = "3"\n  }\n}
	Default:{...}
	Decimal:{...}
So it is still not usable. Just look at the screenshot with MSVC above: only the required data is displayed in a very compact way. How can something similar be achived in Eclipse?
Re: Exploring std::map and std::list in debugger [message #545288 is a reply to message #545103] Wed, 07 July 2010 07:29 Go to previous messageGo to next message
Unfortunately, pretty printing of children is not (yet) implemented (see https://bugs.eclipse.org/bugs/show_bug.cgi?id=302121).
As a workaround you can use the gdb console inside Eclipse. I know that's not very comfortable but that's the only way at the moment.
Re: Exploring std::map and std::list in debugger [message #545323 is a reply to message #545288] Wed, 07 July 2010 08:59 Go to previous messageGo to next message
Axel Mueller wrote on Wed, 07 July 2010 07:29
It is a pity that Eclipse still doesn't have usable debugger for c++ development. Any chances for that bug to be fixed in next release?
By the way QtCreator has better integration with debugger. It can display values inside containers:
http://omploader.org/vNHYwbQ/QtCreatorDebugMapList.png
Though it failed to display iterator value correctly.
Re: Exploring std::map and std::list in debugger [message #545516 is a reply to message #545323] Thu, 08 July 2010 03:20 Go to previous message
Feel free to add your comment to the above mentioned bug report. I would also like to see this fixed.
Previous Topic:Cannot get eclipse to build program...? (Win XP)
Next Topic:Problem with building Hello World in Eclipse IDE for C/C++ Developers
Current Time: Tue Oct 28 18:02:56 EDT 2025
Powered by FUDForum. Page generated in 0.07447 seconds
