Upgrade Birt Engine 2.3.2 to 2.6 [message #544692] |
Mon, 05 July 2010 09:43 |
Wael Mashal Messages: 10 Registered: January 2010 |
Hi All
i have a task to upgrade the Birt Engine that already installed on our application, what we have now Birt version 2.3.2 and ineed to upgrade it to the new release 2.6 ?
my questions , which jars i need to replace them or i need to replace all the runtime folder?
best regards
[Updated on: Mon, 05 July 2010 12:50] Report message to a moderator
Re: Upgrade Birt Engine 2.3.2 to 2.6 [message #545043 is a reply to message #544692] |
Tue, 06 July 2010 14:00 |
Are you upgrading the viewer or just the engine? If you are replacing
the engine just download the 2.6 runtime and replace your current
birt-runtime-2_3_2\ReportEngine\lib with
birt-runtime-2_6_0\ReportEngine\lib and your
birt-runtime-2_3_2\ReportEngine\plugins with
birt-runtime-2_6_0\ReportEngine\plugins. Also delete
birt-runtime-2_3_2\ReportEngine\configuration directory and replace it
with birt-runtime-2_6_0\ReportEngine\configuration.
Jason
On 7/5/2010 5:43 AM, Wael Mashal wrote:
> Hi All
> best regards
Re: Upgrade Birt Engine 2.3.2 to 2.6 [message #547372 is a reply to message #547181] |
Fri, 16 July 2010 13:33 |
On 7/15/2010 4:19 PM, Brian wrote:
> I am trying to do the same thing, upgrade from 2.3.0 to 2.6. Does
> anyone what I have to do to get it up and running with 2.6?
Did you try:
Jason
Re: Upgrade Birt Engine 2.3.2 to 2.6 [message #547381 is a reply to message #547372] |
Fri, 16 July 2010 14:22 |
Brian Messages: 8 Registered: May 2010 Location: Madison |
I took all the plugins/configurations/lib files in the2.6 report viewer and copied them over the old 2.3.0 files that were in are web app. It seems that we have integrated 2.3.0 report viewer with are app. I just replaced all the 2.3 with 2.6 report viewer jar's/jsp's and it worked.
Well it looks what I did is what you told me to do. This was just to see if going to 2.6 would clear up some other out standing problems.
The other thing that I noticed is, with 2.3.0 you could have a data type of any and now, 2.6 do not like this, however from what I have tested, It seems to still work.
[Updated on: Fri, 16 July 2010 14:26] Report message to a moderator
FUDForum. Page generated in 0.03412 seconds
