Re: multiple context menu's in one editor [message #544629 is a reply to message #544602] |
Mon, 05 July 2010 06:34 |
Daniel Krügler Messages: 853 Registered: July 2009 |
On 04.07.2010 22:07, SlowStrider wrote:
> I have one (Form)editor with multiple TableViewers. I would like each
> TableViewer to have it's own context menu.
> My menu's can contain commands such as "insert new row", "delete
> selection", etc...
> I think it's not hard to do this in pure SWT with "low level" selection
> listeners, but I would like to do it the clean RCP way with commands and
> structured selections. (Actually I am not sure if I ever need another
> plugin to contribute commands, but it would be nice to have this
> possibility).
> As described
> http://www.ralfebert.de/blog/eclipsercp/commands_context_men u/, I found
> out how to add a context menu to one TableViewer(s) and register it and
> it's structured selection with the editor so that plugins can contribute
> commands. Their handlers can then access the selection using
> HandlerUtil.getCurrentSelection(event) inside their execute method.
> But in my case I have multiple TableViewers that should have their own
> commands and have their own selection. So I have these questions:
> 1. How can I contribute commands to one specific TableViewer but not to
> the others? Can I somehow change the
> <menuContribution locationURI="popup:some.package.someditor">
> to
> <menuContribution locationURI="popup:some.package.someditor.someviewer">?
Yes, in fact the latter assumption is correct. You have to create a
MenuManager for each Table control (or whatever control you need a
context menu for) as described in the Link. You also need to invoke
the call to registerContextMenu, but this time you need the three-
parameter version:
void registerContextMenu(String menuId, MenuManager menuManager,
ISelectionProvider selectionProvider);
For the first parameter you need to provide a unique ID for each
viewer. This i9d needs to be used within the locationURI as you
assumed.
You don't need to invoke
getSite().setSelectionProvider(tableViewer);
because this would not only register one of the viewers as selection
provider.
> 2. When I write a handler for a command such as "insert new row" or
> "delete selected rows" or "call selected person" I will need access to
> the structured selection of the specific TableViewer and I need access
> to the WritableList in it's content provider to remove/add the new
> items. And what do I do when I need access to other data/methods that is
> only known by my specific editor? What is a clean way to get access to
> this information in the handler code?
Use HandlerUtil.getActiveEditor or HandlerUtil.getActivePart and
cast to your concrete Editor class - or even better: Let your editor
implement some specific interface that provides the functionality you
need and cast to the interface.
HTH & Greetings from Bremen,
Daniel Krügler
Re: multiple context menu's in one editor [message #544754 is a reply to message #544675] |
Mon, 05 July 2010 12:35 |
Henno Vermeulen Messages: 126 Registered: July 2009 |
Ok it works! Without setting the selection provider on the entire site,
returns null.
But I found out that
HandlerUtil.getActiveMenuSelection(event)
Returns the selection of the ISelectionProvider (TableViewer) I associated with the popup menu.
But how can I properly re-use this command from a button inside my editor? Then the popup menu will not be active. I think I'll just solve this by making a "removeSelectedConcreteObject" method in my editor...
[Updated on: Mon, 05 July 2010 12:45] Report message to a moderator
FUDForum. Page generated in 0.02999 seconds
