Re: Can't use Eclipse XML Editors and Tools in Helios on Ubuntu 10.04 64 bits [message #544459 is a reply to message #544446] |
Fri, 02 July 2010 18:02 |
On 7/2/2010 1:15 PM, Philippe Cayouette wrote:
> On Ubuntu 10.04 desktop 64 bits:
> On a fresh package of Eclipse Helios CDT from eclipse.org, with
> ~/.eclipse deleted, I installed the plugin "Eclipse XML Editors and
> Tools" which I used in the past on erlier version of Eclipse and Ubuntu.
> However, it doesn't seem to recognize XML files... Eclipse still see
> them as regular text files and I can't find a way to make it see them or
> open them as XML files, with the internal XML editor.
> That being said, I tried the exact same thing, but on WinXP Pro 32 bits
> and it worked without problem.
> Your help is much appreciated.
Files opened previously will open with the last editor you used on them,
unless you choose "Open with" from the file's context menu. If the
editor is not available from that menu, are the preferences for it
showing up?
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03501 seconds
