Home » Modeling » TMF (Xtext) » deadlock problem
deadlock problem [message #544214] Thu, 01 July 2010 23:38 Go to next message
I am running into a deadlock situation. I seems like Highlighting and
Outline are deadlocking.
I have let the IDE run for a bit and then paused, when repeating it is
stuck in the same two places... (See stack tracess below)
The problem can be replicated - I always get the problem when in a
particular position in the source text.
If I remove my semantic highlighting, it does not hang, and I get an
error marker instead (because of a syntax error - which is expected).
Do I need to protect the highlighting in a UnitOfWork some way, or
should it work without this? I read this: "Please refer to
DefaultContentOutlineNodeFactory.getEObjectHandle(EObject,
IStateAccess<XtextResource>) to learn more about IEObjectHandles. ", and
I have seen that I may not work directly with the model.
And I looked at the mentioned code, but I just don't get it...
What I am doing now is like this...
public void provideHighlightingFor2(XtextResource resource,
IHighlightedPositionAcceptor acceptor) {
if(resource == null)
return;
EList<EObject> contents = resource.getContents();
if(contents == null || contents.size() == 0)
return; // nothing there at all - probably an empty file
BeeModel model = (BeeModel) contents.get(0);
// BuildUnit bu = model.getBody();
TreeIterator<EObject> all = model.eAllContents();
while(all.hasNext()) {
EObject o = all.next();
// TODO: OPTIMIZE the if-then-else below using an EMF switch
if(o instanceof BuildUnit)
highlightBuildUnit((BuildUnit) o, acceptor);
// handle literals
else if(o instanceof BLiteralExpression) {
Object val = ((BLiteralExpression) o).getValue();
// handle real numbers (INT and HEX are handled by terminal rules)
if(val instanceof Float || val instanceof Double)
highlightObject(o, BeeLangHighlightConfiguration.REAL_ID, acceptor);
else if(o instanceof PathVector)
highlightPaths((PathVector) o, acceptor);
// etc. etc...
Where the the various highlightObject, highlightPaths, use a variant of
finding "firstFeature" as I seen used by others...
Am I doing something wrong?
If I should use "readOnly" and "IUnitOfWork", how to I get to the model
from the XtextResource passed in in the call to provideHighlightingFor ?
(The version on b3's HEAD has the semantic highlighting disabled since I
am working on a proposal provider for the position where this issue
occurs...)
// provideHighlightingFor2(resource, acceptor);
- henrik
Daemon Thread [Thread-0] (Suspended)
Unsafe.park(boolean, long) line: not available [native method]
LockSupport.park(Object) line: 158
ReentrantReadWriteLock$NonfairSync(AbstractQueuedSynchronize r).parkAndCheckInterrupt() line: 747
ReentrantReadWriteLock$NonfairSync(AbstractQueuedSynchronize r).doAcquireShared(int) line: 877
ReentrantReadWriteLock$NonfairSync(AbstractQueuedSynchronize r).acquireShared(int) line: 1197
ReentrantReadWriteLock$ReadLock.lock() line: 594
XtextDocument$XtextDocumentLocker(IStateAccess$AbstractImpl<P >).readOnly(IUnitOfWork<T,P>) line: 36
XtextDocument.readOnly(IUnitOfWork<T,XtextResource>) line: 58
XtextContentOutlinePage.synchronizeOutlinePage() line: 312
EditorSelectionChangedListener.selectionChanged(SelectionCha ngedEvent)
line: 31
XtextSourceViewer(TextViewer).firePostSelectionChanged(Selec tionChangedEvent) line: 2745
XtextSourceViewer(TextViewer).firePostSelectionChanged(int, int)
line: 2693
TextViewer$5.run() line: 2672
Display.runTimers() line: 3742
Display.readAndDispatch() line: 3256
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2624
Workbench.runUI() line: 2588
Workbench.access$4(Workbench) line: 2422
Workbench$7.run() line: 670
Realm.runWithDefault(Realm, Runnable) line: 332
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 663
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
IDEApplication.start(IApplicationContext) line: 115
EclipseAppHandle.run(Object) line: 196
EclipseAppLauncher.runApplication(Object) line: 110
EclipseAppLauncher.start(Object) line: 79
EclipseStarter.run(Object) line: 369
EclipseStarter.run(String[], Runnable) line: 179
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 597
Main.invokeFramework(String[], URL[]) line: 619
Main.basicRun(String[]) line: 574
Main.run(String[]) line: 1407
Main.main(String[]) line: 1383
AND
Thread [Worker-3] (Suspended)
MergingHighlightedPositionAcceptor.mergePositions(int, int, int,
LightweightPosition$IntToStringArray[]) line: 88
MergingHighlightedPositionAcceptor.mergePositions() line: 71
MergingHighlightedPositionAcceptor.provideHighlightingFor(Xt extResource, IHighlightedPositionAcceptor) line: 47
HighlightingReconciler.reconcilePositions(XtextResource) line: 87
HighlightingReconciler.modelChanged(XtextResource) line: 275
XtextDocument.notifyModelListeners(XtextResource) line: 90
XtextDocument$XtextDocumentLocker.afterModify(XtextResource, Object,
IUnitOfWork<?,XtextResource>) line: 142
XtextDocument$XtextDocumentLocker.afterModify(Object, Object,
IUnitOfWork) line: 1
XtextDocument$XtextDocumentLocker(IStateAccess$AbstractImpl<P >).modify(IUnitOfWork<T,P>) line: 58
XtextDocument$XtextDocumentLocker.modify(IUnitOfWork<T,XtextResource >)
line: 149
XtextDocument.modify(IUnitOfWork<T,XtextResource>) line: 62
XtextDocumentReconcileStrategy.reconcile(IRegion) line: 27
XtextReconciler.run(IProgressMonitor) line: 179
Worker.run() line: 54
Re: deadlock problem [message #544349 is a reply to message #544214] Fri, 02 July 2010 08:36 Go to previous messageGo to next message
I've filed a bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=318704
Sven
Henrik Lindberg schrieb:
> return;
> // handle literals
> terminal rules)
> highlightObject(o,
> // etc. etc...
> occurs...)
> Regards
> - henrik
> line: 747
> line: 877
> line: 1197
> line: 36
> line: 31
> line: 2745
> line: 2693
> 149
> AND
> line: 58
> line: 149
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: deadlock problem [message #544537 is a reply to message #544349] Sat, 03 July 2010 09:27 Go to previous messageGo to next message
Hi Henrik,
can you confirm that it's an endless loop in
MergedHighlightingPositionAcceptor.mergePositions?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 02.07.10 14:36, schrieb Sven Efftinge:
> Sven
>> and I have seen that I may not work directly with the model.
>> return;
>> // handle literals
>> // etc. etc...
>> of finding "firstFeature" as I seen used by others...
>> model from the XtextResource passed in in the call to
>> I am working on a proposal provider for the position where this issue
>> occurs...)
>> Regards
>> - henrik
>> Daemon Thread [Thread-0] (Suspended) Unsafe.park(boolean, long) line:
>> not available [native method] LockSupport.park(Object) line: 158
>> line: 747
>> line: 877
>> line: 1197 ReentrantReadWriteLock$ReadLock.lock() line: 594
>> line: 36 XtextDocument.readOnly(IUnitOfWork<T,XtextResource>) line: 58
>> line: 31
>> line: 2745 XtextSourceViewer(TextViewer).firePostSelectionChanged(int,
>> int) line: 2693 TextViewer$5.run() line: 2672 Display.runTimers()
>> line: 3742 Display.readAndDispatch() line: 3256
>> Workbench.runUI() line: 2588 Workbench.access$4(Workbench) line: 2422
>> Workbench$7.run() line: 670 Realm.runWithDefault(Realm, Runnable)
>> line: 332 Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor)
>> line: 663 PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor)
>> line: 149 IDEApplication.start(IApplicationContext) line: 115
>> EclipseAppLauncher.start(Object) line: 79 EclipseStarter.run(Object)
>> line: 369 EclipseStarter.run(String[], Runnable) line: 179
>> available [native method] NativeMethodAccessorImpl.invoke(Object,
>> Object[]) line: 39 DelegatingMethodAccessorImpl.invoke(Object,
>> Object[]) line: 25 Method.invoke(Object, Object...) line: 597
>> Main.basicRun(String[]) line: 574 Main.run(String[]) line: 1407
>> AND
>> line: 58
>> line: 149 XtextDocument.modify(IUnitOfWork<T,XtextResource>) line: 62
>> XtextReconciler.run(IProgressMonitor) line: 179 Worker.run() line: 54
Re: deadlock problem [message #544545 is a reply to message #544537] Sat, 03 July 2010 10:23 Go to previous messageGo to next message
So far, I have only paused the execution and looked at where the
different threads were executing - did not look at exact positions, but
"mergePositions" was always on the call stack (afaict).
How can I provide more info?
To replicate:
If you update your b3 workspace remove the o.e.b3.backend.[edit, editor
and test] projects (obsolete generated stuff).
Then uncomment line 145 in
/org.eclipse.b3.beelang.ui/src/org/eclipse/b3/coloring/BeeLa ngSemanticHighlightingCalculator.java
which says:
And with a b3 file like this:
unit HelloDeadlock version | {
Place the marker at | (if you get that far after typing 'version'), try
typing a version '1.0.0', or invoke proposals.
(I posted this in the bug as well...)
- henrik
On 7/3/10 3:27 PM, Sebastian Zarnekow wrote:
> Hi Henrik,
> Sebastian
Re: deadlock problem [message #544567 is a reply to message #544545] Sat, 03 July 2010 20:32 Go to previous message
For those that do not follow the bug - the cause of this was asking the
highlighter to highlight something of 0 length.
- henrik
> To replicate:
> which says:
> - henrik
>> Hi Henrik,
>> Regards,
>> Sebastian
Previous Topic: no viable alternative at character '' on line 24
Next Topic:Cartridges in MWE2
Current Time: Mon Sep 15 11:54:40 EDT 2025
Powered by FUDForum. Page generated in 0.03983 seconds
