Home » Eclipse Projects » Remote Application Platform (RAP) » Compiler error: The import org.eclipse.ui.views.properties cannot be resolved
Compiler error: The import org.eclipse.ui.views.properties cannot be resolved [message #544069] |
Thu, 01 July 2010 14:03 |
KwanKin Yau Messages: 32 Registered: July 2009 |
Member |
Hi, all!
I have an common bundle, but I got an error the when I use RAP, then compiler error message is:
"The import org.eclipse.ui.views.properties cannot be resolved."
But my bundle was declared required-package for org.eclipse.ui.views.properties.
The content of MANIFEST.MF as follow:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Eclipse UI
Bundle-SymbolicName: net.yau.eclipse.ui;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Activator: net.yau.eclipse.ui.EclipseUIPlugin
Bundle-Vendor: Yau KwanJane
Require-Bundle: net.yau.lib;bundle-version="1.0.0",
net.yau.thirdparty.Jakarta.commons;bundle-version="1.0.0",
net.yau.eclipse.common;bundle-version="1.0.0",
org.eclipse.osgi;bundle-version="3.5.1"
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Bundle-ActivationPolicy: lazy
Export-Package: net.yau.eclipse.ui,
net.yau.eclipse.ui.dialogs,
net.yau.eclipse.ui.dialogs.errPanel,
net.yau.eclipse.ui.dialogs.test,
net.yau.eclipse.ui.editingSupport,
net.yau.eclipse.ui.fieldassist,
net.yau.eclipse.ui.gui,
net.yau.eclipse.ui.gui.directoryPanel,
net.yau.eclipse.ui.net,
net.yau.eclipse.ui.net.customDNSService,
net.yau.eclipse.ui.net.dnsprefs,
net.yau.eclipse.ui.net.ui,
net.yau.eclipse.ui.props,
net.yau.eclipse.ui.validators,
net.yau.eclipse.ui.validators.ui
Bundle-Localization: plugin
Import-Package: org.eclipse.core.commands,
org.eclipse.core.databinding.validation,
org.eclipse.core.runtime;version="3.4.0",
org.eclipse.core.runtime.jobs,
org.eclipse.jface.dialogs,
org.eclipse.jface.fieldassist,
org.eclipse.jface.preference,
org.eclipse.jface.resource,
org.eclipse.jface.viewers,
org.eclipse.jface.window,
org.eclipse.swt,
org.eclipse.swt.custom,
org.eclipse.swt.events,
org.eclipse.swt.graphics,
org.eclipse.swt.layout,
org.eclipse.swt.widgets,
org.eclipse.ui;ui.workbench=split,
org.eclipse.ui.application,
org.eclipse.ui.dialogs,
org.eclipse.ui.forms,
org.eclipse.ui.forms.widgets,
org.eclipse.ui.plugin,
org.eclipse.ui.progress,
org.eclipse.ui.views,
org.eclipse.ui.views.properties,
org.osgi.framework;version="1.5.0"
Who can I resolve this problem? Hope your help, Thanks.
Re: Compiler error: The import org.eclipse.ui.views.properties cannot be resolved [message #544072 is a reply to message #544069] |
Thu, 01 July 2010 14:04 |
Benjamin Muskalla Messages: 338 Registered: July 2009 |
As stated on the dev-list:
This sounds like an issue with split packages.
See http://wiki.eclipse.org/RAP/FAQ#Problems_using_Import-Packag e_header
The split id of the package is "ui.views".
Ben
Yau wrote:
> Hi, all!
> org.eclipse.swt,
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Current Time: Thu Sep 19 20:06:47 GMT 2024
Powered by FUDForum. Page generated in 0.03721 seconds
