Re: [EEF] No property widgets for containment references with a fixed upperbound [message #543998 is a reply to message #543976] |
Thu, 01 July 2010 10:00 |
Stephane Bouchet Messages: 280 Registered: July 2009 |
Hi Ramon,
Using the AdvancedTableCompositionTable widget should work, is this one
you used ?
What is your upperBound limit ? lower bound ?
Le 01/07/2010 10:46, Ramon a écrit :
> Sorry, I forgot the subject...
> Ramon wrote:
>> Using the EEF, I noticed that for containment references with a fixed
>> upperbound no properties widgets for the property view are created. Is
>> this by design?
>> Thanks in advance,
>> Ramon
Stéphane Bouchet, OBEO
Re: [EEF] No property widgets for containment references with a fixed upperbound [message #623030 is a reply to message #543976] |
Hi Ramon,
you used ?
> Ramon wrote:
>> this by design?
>> Thanks in advance,
>> Ramon
FUDForum. Page generated in 0.03671 seconds
