Home » Modeling » TMF (Xtext) » Mwe2Launcher
Mwe2Launcher [message #543463] |
Tue, 29 June 2010 14:01 |
Rubén Porras Campo Messages: 67 Registered: July 2009 |
Member |
i have problems running the standalone setup of a XTEXT grammar with an MWE2 file. I use the Mwe2Launcher.main to launch it. The MWE2 file is
module btt
import org.eclipse.emf.mwe.utils.*
var fileEncoding = "UTF-8"
var modelDir
var targetDir
Workflow {
bean = StandaloneSetup {
platformUri = ".."
registerGeneratedEPackage = "com.foo.bttg.meta_model.btc.btc.BtcPackage"
registerGeneratedEPackage = "com.foo.bttg.meta_model.btpt.btpt.BtptPackage"
component = org.eclipse.xtext.mwe.Reader {
path = modelDir
register = com.foo.bttg.meta_model.btc.BTCStandaloneSetup {}
register = com.foo.bttg.meta_model.btpt.BTPTStandaloneSetup {}
register = com.foo.bttg.meta_model.btt.BTTStandaloneSetup {}
register = com.foo.bttg.meta_model.mtd.MTDStandaloneSetup {}
load = {
slot = "model"
type = "BusinessTrxType"
component = org.eclipse.xpand2.Generator {
metaModel = org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel {}
expand = "com::foo::bttg::generator::abs::btt::Main::main FOREACH model"
outlet = {
path = targetDir
fileEncoding = fileEncoding
The error message is
Quote: |
Mwe2Launcher - [XtextLinkingDiagnostic: null:18 Couldn't resolve reference to JvmType 'com.foo.bttg.meta_model.btc.BTCStandaloneSetup'.]
java.lang.IllegalStateException: [XtextLinkingDiagnostic: null:18 Couldn't resolve reference to JvmType 'com.foo.bttg.meta_model.btc.BTCStandaloneSetup'.]
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runne r.java:66)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Lau ncher.java:76)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2La uncher.java:35)
at com.foo.bttg.Activator.run(Activator.java:85)
at com.foo.bttg.generator_service.BttGenerator.performGeneratio n(BttGenerator.java:149)
at com.foo.bttg.generator_service.BttGenerator.run(BttGenerator .java:128)
at com.foo.bttg.generator_service.BttGenerationApp.main(BttGene rationApp.java:90)
The same errors are given for the other StandaloneSetups registered for mwe.Reader.
A similar MWE2 file works fine within eclipse to generate some files for the model.
To me it seems like a classpath problem. But I don't know where the problem is, since the Activator.java calling the Mwe2Launcher.main() and the registered StandaloneSetups are in the same jar file, and the jar file has the MANIFEST file that follows.
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: com.foo.bttg
Bundle-Vendor: Foo Evolution AG
Bundle-Version: 2.0.0
Bundle-SymbolicName: com.foo.bttg;singleton:=true
Eclipse-RegisterBuddy: org.eclipse.xtext.log4j
Bundle-ActivationPolicy: lazy
Require-Bundle: org.eclipse.xtext,
org.eclipse.xtext.util,
org.eclipse.emf.ecore,
org.eclipse.emf.common,
org.antlr.runtime,
org.apache.log4j;bundle-version="1.2.15",
org.eclipse.xtend,
org.eclipse.emf.mwe2.launch;bundle-version="1.0.0",
org.junit;bundle-version="4.8.1",
org.eclipse.xtend.util.stdlib;bundle-version="1.0.0",
org.apache.ant;bundle-version="1.7.1",
org.eclipse.xtext.generator;bundle-version="1.0.0",
org.apache.commons.logging;bundle-version="1.1.1",
org.eclipse.xtext.xtend;bundle-version="1.0.0"
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: com.foo.bttg.meta_model.btc,
com.foo.bttg.meta_model.btc.btc,
com.foo.bttg.meta_model.btc.btc.impl,
com.foo.bttg.meta_model.btc.btc.util,
com.foo.bttg.meta_model.btc.parseTreeConstruction,
com.foo.bttg.meta_model.btc.parser.antlr,
com.foo.bttg.meta_model.btc.parser.antlr.internal,
com.foo.bttg.meta_model.btc.services,
com.foo.bttg.meta_model.btc.validation,
com.foo.bttg.meta_model.btpt,
com.foo.bttg.meta_model.btpt.btpt,
com.foo.bttg.meta_model.btpt.btpt.impl,
com.foo.bttg.meta_model.btpt.btpt.util,
com.foo.bttg.meta_model.btpt.parseTreeConstruction,
com.foo.bttg.meta_model.btpt.parser.antlr,
com.foo.bttg.meta_model.btpt.parser.antlr.internal,
com.foo.bttg.meta_model.btpt.services,
com.foo.bttg.meta_model.btpt.validation,
com.foo.bttg.meta_model.btt,
com.foo.bttg.meta_model.btt.btt,
com.foo.bttg.meta_model.mtd,
com.foo.bttg.meta_model.mtd.mtd,
com.foo.bttg.meta_model.mtd.mtd.impl,
com.foo.bttg.meta_model.mtd.mtd.util,
com.foo.bttg.meta_model.mtd.parseTreeConstruction,
com.foo.bttg.meta_model.mtd.parser.antlr,
com.foo.bttg.meta_model.mtd.parser.antlr.internal,
com.foo.bttg.meta_model.mtd.services,
com.foo.bttg.meta_model.mtd.validation
Import-Package: org.apache.log4j
Bundle-ClassPath: src/,.
Could anyone help me?
Thanks!
Re: Mwe2Launcher [message #543526 is a reply to message #543463] |
Tue, 29 June 2010 16:42 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
It is a known shortcoming (bug) in the current MWE2Launcher that running
it from within OSGi is not working.
Thr problem is the code in
org.eclipse.xtext.mwe.RuntimeResourceSetInitializer :
public List<String> getClassPathEntries() {
List<String> pathes = Lists.newArrayList();
String classPath = System.getProperty("java.class.path");
String separator = System.getProperty("path.separator");
String[] strings = classPath.split(separator);
for (String path : strings) {
pathes.add(path);
return pathes;
which uses the system property 'java.class.path' to determine the list
of classpath entries. You could override it and bind your own
implementation to RuntimeResourcesetInitializer. You should also use
Mwe2Runner instead of Mwe2Launcher, which is intended to be used from
command line.
We will fix this for the SR1 release (to be released in a couple of weeks).
In the meantime you could still use the old workflow engine in an OSGi
context.
Sorry,
Sven
Ruben schrieb:
> module btt
> var modelDir
> var targetDir
> Workflow {
> platformUri = ".."
> path = modelDir
> load = {
> slot = "model"
> metaModel =
> FOREACH model"
> outlet = {
> path = targetDir
> Quote:
>> r.java:66)
>> ncher.java:76)
>> uncher.java:35)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> .java:128)
>> rationApp.java:90)
> mwe.Reader.
> the model.
> org.antlr.runtime,
> org.eclipse.xtend,
> Thanks!
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Current Time: Fri Apr 26 09:21:34 GMT 2024
Powered by FUDForum. Page generated in 0.03032 seconds
