Home » Archived » BIRT » Can't set margins of the master-page
Can't set margins of the master-page [message #54704] Thu, 07 July 2005 06:14 Go to next message
Hi list,
when I create a new report project and add a new report, in the outline
view I can see the automatically created master-page. Unfortunately, this
contains an error ('invalid margins'). I'm not able to set the margins,
this always results in:
java.lang.NumberFormatException: For input string: "100,00"
java.lang.NumberFormatException.forInputString(NumberFormatE xception.java:48)
java.lang.FloatingDecimal.readJavaFormatString(FloatingDecim al.java:1207)
at java.lang.Double.parseDouble(Double.java:220)
org.eclipse.birt.report.designer.internal.ui.views.attribute s.widget.Spinner.getSelection(Spinner.java:365)
Actually I would not care about this because I don't want to produce pdf,
but becuase of this bug my layout-view for the reports doesn't work
anymore...
Id there any way to switch off the masterpage?
Or any other idea?
Thanks in advance,
Florian
Re: Can't set margins of the master-page [message #54749 is a reply to message #54704] Thu, 07 July 2005 06:58 Go to previous messageGo to next message
Florian,
We alreday get a bug reports this problem under German environment. We'are
working on it.
Qiangsheng Wang
"Florian Schaefer" <fschaefer@ita-logistics.com>
??????:4411c6f54a763affb0250fbc682a121b$1@www.eclipse.org...
> Hi list,
> at
> at
> at
> anymore...
> Or any other idea?
> Thanks in advance,
> Florian
Re: Can't set margins of the master-page [message #54830 is a reply to message #54749] Thu, 07 July 2005 10:36 Go to previous messageGo to next message
Originally posted by: none.none.none
Is there a workaround or a way to get rid of the master page? Or are you
saying that he mine as well close up shop until the bug is fixed? *If* I
understand Florian correctly, he's saying that he is unable to move forward
right now because of this problem, so simplying knowing that it's a known
bug is not of much use.
Sorry if I sound frustrated, but it appears that I will be receiving no
community support as I begin to use BIRT, so I need to know if I'll will be
stumbling across these kinds of show-stoppers after investing a lot of time
& effort into implementing the product.
"Wang QS" <qwang@actuate.com> wrote in message
news:daj1td$32r$1@news.eclipse.org...
> Florian,
> working on it.
> Thanks
> Qiangsheng Wang
Re: Can't set margins of the master-page [message #54937 is a reply to message #54830] Thu, 07 July 2005 14:59 Go to previous message
Chris,
I 'solved' the problem...
all plugins starting with 'birt.report' i took from the 1.0 version, the
rest from the milestone build. now it runs
Thanks a lot to all that helped me the last days!
Florian
Previous Topic:PDF format with ReportRunner
Next Topic:mysql connector/j 3.1?
Current Time: Mon Nov 10 07:15:55 EST 2025
Powered by FUDForum. Page generated in 0.24474 seconds
