| Class loader exception during JPA processing [message #543187] |
Mon, 28 June 2010 12:10  |
I am using EclipseLink 2.0.2 with Spring 3.0.2 and 60% of the time I am getting the following exception during the start of my bundle:
Caused by: org.eclipse.persistence.exceptions.EntityManagerSetupException:
Exception Description: Predeployment of PersistenceUnit [app] failed.
Internal Exception: org.eclipse.virgo.kernel.osgi.framework.BundleClassLoaderUnavailableException: Failed to get class loader for bundle 'org.eclipse.virgo.region.user_0.0.0 [1]' - possible resolution problem.
at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:210)
... 23 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.BundleClassLoaderUnavailableException: Failed to get class loader for bundle 'org.eclipse.virgo.region.user_0.0.0 [1]' - possible resolution problem.
at org.eclipse.virgo.kernel.userregion.internal.equinox.EquinoxUtils.getBundleClassLoader(EquinoxUtils.java:69)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.getBundleClassLoader(KernelBundleClassLoader.java:125)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.access$4(KernelBundleClassLoader.java:124)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader$ThrowAwayClassLoader.findClassFromImport(KernelBundleClassLoader.java:415)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader$ThrowAwayClassLoader.findClassInternal(KernelBundleClassLoader.java:392)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader$ThrowAwayClassLoader.loadClass(KernelBundleClassLoader.java:364)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:247)
at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.getClassForName(PrivilegedAccessHelper.java:88)
at org.eclipse.persistence.internal.jpa.metadata.MetadataHelper.getClassForName(MetadataHelper.java:97)
at org.eclipse.persistence.internal.jpa.metadata.ORMetadata.getJavaClass(ORMetadata.java:176)
at org.eclipse.persistence.internal.jpa.metadata.ORMetadata.getJavaClass(ORMetadata.java:151)
at org.eclipse.persistence.internal.jpa.metadata.converters.EnumeratedMetadata.process(EnumeratedMetadata.java:100)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processEnumerated(MappingAccessor.java:1340)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.BasicAccessor.processEnumerated(BasicAccessor.java:340)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processJPAConverters(MappingAccessor.java:1354)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processMappingConverter(MappingAccessor.java:1422)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processMappingValueConverter(MappingAccessor.java:1440)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.BasicAccessor.process(BasicAccessor.java:300)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.IdAccessor.process(IdAccessor.java:69)
at org.eclipse.persistence.internal.jpa.metadata.MetadataDescriptor.processAccessors(MetadataDescriptor.java:1287)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.ClassAccessor.processAccessors(ClassAccessor.java:825)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.processAccessors(EntityAccessor.java:847)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.process(EntityAccessor.java:708)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage2(MetadataProject.java:1333)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:461)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:390)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:945)
... 22 common frames omitted
Caused by: java.lang.ClassCastException: org.eclipse.osgi.internal.composite.CompositeClassLoader cannot be cast to org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader
at org.eclipse.virgo.kernel.userregion.internal.equinox.EquinoxUtils.getBundleClassLoader(EquinoxUtils.java:67)
... 50 common frames omitted
From the EclipseLink source:
org.eclipse.persistence.internal.security.PrivilegedAccessHelper(88)
return Class.forName(className, initialize, loader);
org.eclipse.persistence.internal.jpa.metadata.MetadataHelper(97)
return PrivilegedAccessHelper.getClassForName(classname, true, loader);
org.eclipse.persistence.internal.jpa.metadata.ORMetadata(176)
return MetadataHelper.getClassForName(convertedClassName, getMetadataFactory().getLoader());
It's always happens when processing enums. In my JPA annotated classes I am using:
@Enumerated(EnumType.STRING)
In the persistance.xml file the enums are not specified in the <class> tags.
I am starting Virgo Web server with:
-javaagent:path\spring-instrument-3.0.2.RELEASE.jar
It doesn't matter whether the bundle is specified in a plan or is a part of a par file.
The same is happening with the last version of DM server.
Assen
FUDForum. Page generated in 0.05602 seconds
