Birt Deployment error - is it a bug? [message #542968] |
Mon, 28 June 2010 03:45 |
s_^_s Missing name Messages: 3 Registered: June 2010 |
Hi Experts,
I had developed some reports (using connection profile) on my windows machine and had then copied them into the Birt WebViewerExample tomcat application running on windows machine - it worked.
Then I moved the same WebViewerExample app onto a linux machine.
In the connectionProfileStore, I changed the path of jarlist to be correct on the linux environment. (It goes into WebViewerExample\WEB-INF\platform\plugins\.... )
On the linux machine, 'tomcat' user is the owner of this file and (its parent directories) still I am getting this error:
WARNING: handle type: org.eclipse.birt.report.model.api.OdaDataSetHandle
Jun 28, 2010 8:06:36 AM org.eclipse.birt.report.data.adapter.impl.ModelAdapter adaptDataSet
Jun 28, 2010 8:06:37 AM org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection open(Properties)
WARNING: Unable to open a connection with the database connection profile.
org.eclipse.datatools.connectivity.oda.OdaException: Unable to find the connection profile referenced by the data source connection properties.
at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection.open(Connection.java:104)
at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection.open(Connection.java:57)
Is it a known bug / limitation of some sort?
Please guide..
Thanks in advance
-Sebastian
[Updated on: Mon, 28 June 2010 13:01] Report message to a moderator
Re: Birt Deployment error - is it a bug? [message #642256 is a reply to message #642071] |
Tue, 30 November 2010 15:49 |
Have you tried in the beforeOpen of the dataset something like:
rp =
reportContext.getHttpServletRequest().getSession().getServle tContext().getRealPath( "/myjarlist");
this.setExtensionProperty("jarList",rp);
Jason
On 11/29/2010 1:08 PM, Chems wrote:
> Hi;
> in relation with this topic I want to know if i can use a relative path
> in the jarlist proprety( case of query builder repports)???
> thank's
Re: Birt Deployment error - is it a bug? [message #642353 is a reply to message #642071] |
Tue, 30 November 2010 23:02 |
Linda Chan Messages: 845 Registered: July 2009 |
Umm, it depends on which jarlist property is used.
The jarList property of a driver definition (defined in the workspace as described in my earlier post) does *not* accept relative path, nor any variable.
Since a workspace and thus its driver definition is local to each deployment environment, it is not intended to be portable across systems. So an absolute path specific to a local system should be sufficient.
Whereas, the jarList property defined in a connection profile instance can be portable across deployment systems. It can thus be scripted with variable(s) to specify the root path, as appropriate.
Linda
FUDForum. Page generated in 0.25216 seconds
