Re: [Acceleo] Import UML Profile to use in templates [message #543743 is a reply to message #542818] |
Wed, 30 June 2010 12:54 |
--------------040006060209090606030500
Hi Attila,
You cannot use profiles directly in Acceleo templates, you can however
use profiled UML models and access profile information through the usual
UML APIs.
For example if you have a class stereotyped "Entity" and you wish to
retrieve the value of its property ""; you can use :
[template public generateSomething(class : Class) ? (not
class.getAppliedStereotype(fqn::Entity).oclIsUndefined)]
class [class.name/] has stereotype fqn::Entity.
Its table_name tagged value is
[class.getValue(class.getAppliedStereotype(fqn::Entity), 'table_name')/]
[/template]
Does this suit your need? Otherwise please elaborate on what you need to do.
Laurent Goubet
Obeo
Bak Attila wrote:
> How can i import uml profiles for use in templates?
> For example i have Persistence.profile.uml.
> Do i need to register it somewhere?
> What are the steps i need to do?
> Thanks
> attila
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040006060209090606030500--
FUDForum. Page generated in 0.08012 seconds
