Home » Modeling » EMF » [CDO] Profiling CDO
[CDO] Profiling CDO [message #542542] Fri, 25 June 2010 05:46 Go to next message
I'd like to know is there is some common knowledge with regard to CDO profiling.
More precisely, when retrieving models as local resources takes too much time, I need a methodology to identify any bottleneck.
This would help me in improving my metamodels and the way I use CDO.
regards,
Bastien
Re: [CDO] Profiling CDO [message #542558 is a reply to message #542542] Fri, 25 June 2010 06:31 Go to previous messageGo to next message
Hi Bastien,
I'm not sure what exactly you mean by "profiling methodology". Are you
already encountering bottlenecks or is this a hypothetical question?
You should start by understanding the optimization potential of CDO's
default configuration. Please study
http://wiki.eclipse.org/Tweaking_CDO_Performance and let us know if you
have more detailed questions ;-)
Cheers
/Eike
Am 25.06.2010 11:46, schrieb Bastien:
> profiling.
> regards, Bastien
Re: [CDO] Profiling CDO [message #542564 is a reply to message #542542] Fri, 25 June 2010 06:58 Go to previous messageGo to next message
We are indeed regularly encoutering performance issues while retrieving / committing models.
We already significantly improved performances by applying some of the optimizations suggested on the page you are linking.
At this stage, we feel that detecting the actual bottlenecks so that we could optimize in the proper way would be more efficient. That would help us in asking more detailed questions Wink
As an example, should properties of a reference in the metamodel be the cause of some slowness, how can we detect it?
Bastien.
Re: [CDO] Profiling CDO [message #542574 is a reply to message #542564] Fri, 25 June 2010 07:09 Go to previous messageGo to next message
Am 25.06.2010 12:58, schrieb Bastien:
Can you describe the nature of these issues and give measures?
Hmm, something in this sentence seems to be missing. I feel that I need
it to understand it :P
> That would help us in asking more detailed questions ;)
Not that I know of. Nobody has reported performance issues for a long
while. That's why I'm walking in the dark without further infos/measures.
Cheers
/Eike
Re: [CDO] Profiling CDO [message #543402 is a reply to message #542542] Tue, 29 June 2010 06:37 Go to previous messageGo to next message
Hi Eike,
My goal is to retrieve locally (as an XMI file) a resource from my CDO server,
I noticed that the method save(OutputStream outputStream, Map<?, ?> options) is not implemented for CDOResource.
Given that information, I chose to make a local copy of my resource with this kind of code :
localResource.getContents().addAll(EcoreUtil.copyAll(remoteR essource.getContents()));
and with that solution, I have checkout times between 150 and 8000 seconds for models between 2 and 15Mo (on a LAN, so I don't think it's a network issue).
that's why I'm wondering if i'm using the right retreival solution and if you have some advices to improve that.
Bastien.
[Updated on: Tue, 29 June 2010 06:40] by Moderator
Re: [CDO] Profiling CDO [message #543414 is a reply to message #543402] Tue, 29 June 2010 07:03 Go to previous messageGo to next message
Hi Bastien,
it is possible that lot of round-trip between client and server is
happening. In the worst case, if there is an content iterator, you'll
get round-trip per each EObject in the Resource tree. That could be a
lot of overhead, depending on the size of the model. As you may guess,
the bigger the model, the bigger the overhead.
Maybe you could perform prefetching of the resource before copying it.
This way you could mitigate a bit the roundtrip overhead, as prefetch
makes the client cache data with the minimum amount of client-server
round-trips.
org.eclipse.emf.cdo.CDOObject.cdoPrefetch(int)
This is available since 3.0.
Give it a try at least and let us know if you see any improvement.
Víctor.
Bastien escribió:
> Hi Eike,
> server,
> this kind of code :
> seconds for models between 2 and 15mo (on a LAN, so I don't think it's a
> network issue).
> Bastien.
Re: [CDO] Profiling CDO [message #543428 is a reply to message #542542] Tue, 29 June 2010 08:34 Go to previous messageGo to next message
Hi Victor,
I tried your solution, unfortunately it doesn't seems to change anything.
I added timers in order to have measurements :
for now I have something like this :
remoteResource.cdoPrefetch(CDORevision.DEPTH_INFINITE)
I also tried with a custom depth and no changes either
localResource.getContents().addAll(remoteRessource.getConten ts());
localResource.save(null);
Prefetching time: 391ms
Copying time: 564048ms
Saving time: 344ms
the model is about 3.5Mo (as an XMI file) and I'm on a 100Mb lan.
Bastien.
Edit : following Cyril's post, I didn't use EcoreUtil#copy during these tests.
[Updated on: Tue, 29 June 2010 10:46] by Moderator
Re: [CDO] Profiling CDO [message #543445 is a reply to message #543428] Tue, 29 June 2010 08:55 Go to previous messageGo to next message
Hi Bastien,
Have you try to:
1/ open a transaction
2/ localResource.getContents().addAll(remoteRessource.getConten ts());
3/ localResource.save(null)
4/ rollback the transaction
Thus you could see if the EcoreUtil#copy is part of the bottleneck.
Cyril
On 06/29/2010 02:34 PM, Bastien wrote:
> Hi Victor,
> Saving time: 344ms
> Bastien.
Re: [CDO] Profiling CDO [message #543449 is a reply to message #542542] Tue, 29 June 2010 09:26 Go to previous messageGo to next message
Hi Cyril,
I tryed to do so except that I don't rollback the transaction, I just don't commit it so no changes are done on my remote resource and my local one is succesfully copied.
I didn't use EcoreUtil#copy in the measurements I gave earlier, I'll modify my previous post consequently.
Bastien.
Re: [CDO] Profiling CDO [message #543493 is a reply to message #543414] Tue, 29 June 2010 11:02 Go to previous messageGo to next message
--------------040709020302070307090500
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Guys,
I vaguely remember that there is a precondition for the prefetching to work effectively: The CDORevision of the CDOObject that you call cdoPrefetch() on must not already be on the client. If it is, then there will be no server round-trip triggered by the prefetch. If you can confirm this by ensuring that the resource that you call cdoPrefetch() on has never been loaded on that client and seeing that the load time decreases drastically, then we may want to consider to remove this constraint somehow.
Cheers
/Eike
Contact: http://www.esc-net.de Blogger <http://thegordian.blogspot.com>Twitter <http://twitter.com/eikestepper>Linkedin <http://de.linkedin.com/in/eikestepper>Xing <http://www.xing.com/profile/Eike_Stepper>
Article: What exactly is inside that p2 repository? < http://thegordian.blogspot.com/2010/05/what-exactly-is-insid e-that-p2.html>
Am 29.06.2010 13:03, schrieb Víctor Roldán Betancort:
> Hi Bastien,
> it is possible that lot of round-trip between client and server is happening. In the worst case, if there is an content iterator, you'll get round-trip per each EObject in the Resource tree. That could be a lot of overhead, depending on the size of the model. As you may guess, the bigger the model, the bigger the overhead.
> Maybe you could perform prefetching of the resource before copying it. This way you could mitigate a bit the roundtrip overhead, as prefetch makes the client cache data with the minimum amount of client-server round-trips.
> Cheers,
> Víctor.
> Bastien escribió:
>> Hi Eike,
>> and with that solution, I have checkout times between 150 and 8000 seconds for models between 2 and 15mo (on a LAN, so I don't think it's a network issue).
>> Regards,
>> Bastien.
Content-Type: multipart/related;
boundary="------------080103070703040700030801"
--------------080103070703040700030801
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Hi Guys,<br>
<br>
consider to remove this constraint somehow.<br>
<br>
<!--WISESTAMP_SIG_66763_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
<div style="padding: 5px 0pt; font-family: arial,sans-serif;
font-size: 13.3px;"><span style="color: gray;">Contact: <a
href="http://www.esc-net.de">http://www.esc-net.de</a></span>
<a href="http://thegordian.blogspot.com" style="padding: 0pt
2px; color: blue; font-size: 10pt;" _service=""><img
src="cid:part1.04060109.08090001@esc-net.de" alt="Blogger"
style="vertical-align: middle; padding-bottom: 5px;"
border="0" height="16" width="16"></a><a
href="http://twitter.com/eikestepper" style="padding: 0pt
src="cid:part2.04050703.09010806@esc-net.de" alt="Twitter"
href="http://de.linkedin.com/in/eikestepper" style="padding:
0pt 2px; color: blue; font-size: 10pt;" _service=""><img
src="cid:part3.06070402.00090904@esc-net.de"
alt="Linkedin" style="vertical-align: middle;
padding-bottom: 5px;" border="0" height="16" width="16"></a><a
href="http://www.xing.com/profile/Eike_Stepper"
style="padding: 0pt 2px; color: blue; font-size: 10pt;"
_service=""><img
src="cid:part4.04030201.09050806@esc-net.de" alt="Xing"
border="0" height="16" width="16"></a></div>
<div style="color: gray; font-size: 13.3px; padding-bottom:
5px;">Article: <span style="color: blue; text-decoration:
underline;"><a
href=" http://thegordian.blogspot.com/2010/05/what-exactly-is-insid e-that-p2.html"
undefined="">What exactly is inside that p2 repository?</a></span></div>
</div>
</span><!--WISESTAMP_SIG_66763_END--><br>
<br>
<blockquote cite="mid:i0ck4l$u0a$1@build.eclipse.org" type="cite">Hi
Bastien,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Víctor.
<br>
<br>
Bastien escribió:
<br>
<blockquote type="cite">Hi Eike,
<br>
<br>
my CDO server,
<br>
Map&lt;?, ?&gt; options)  is not implemented for CDOResource.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Bastien.
<br>
<br>
</blockquote>
</blockquote>
</body>
</html>
Content-Type: image/png;
name="blogger.png"
Content-ID: <part1.04060109.08090001@esc-net.de>
Content-Disposition: inline;
filename="blogger.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAMAAAAoLQ9TAAAABGdBTUEAAK/I NwWK6QAAABl0
RVh0U29mdHdhcmUAQWRvYmUgSW1hZ2VSZWFkeXHJZTwAAADkUExURf9xEv9m AP////9lAP+Q
SP9kAP9jAP9fAP9nAf9vD//x5/9hAP/iz/9iAP9eAP/s4P9vEP9yEv9qAP9q B/+LRP+we/90
I/+RSP/z6/+jZv/y6P+8kP/59f5yE//awf/Ttv9hAf9nAv/17v+4if9sC/9o BP+bWP/r3v/k
0v+wfP+QRv/o2f9gAP+OQ/93HP/l0/+0gv/Rsv/9/P/j0P+pcP+0hf/dx//D m//+/v+td/9o
AP+NQv/Yvf+zgv/x6P/q2/9xG//p2f9pAP/s3//8+fxxE//ex/+AK/9oCP/j 0f/Uuv///4Xw
StcAAABMdFJOU/////////////////////////////////////////////// ////////////
/////////////////////////////////////////wCejeTMAAAAsklEQVR4 2kSP1w6DMBAE
7cMGQg0hvffee++d//+f2IaIeTlppNXtIo88UAjxEIlhjCUG5lwJQuwoulqh FuUGcWGSiTF7
bt40EEoXBKtyIPQS5PffFqyHlhCS2obTK5kDmJ8lXxgA0zsPXer0L3zSUVmI D9ip3SC+hKwQ
2CxCtXYYL25gu1S8bf4jib5fTM+MNE079jom/+KwJUojwnAVifcQ46jM4M23 BHmkEK53iPcT
YACE/Q4KzoVQVwAAAABJRU5ErkJggg==
name="twitter.png"
Content-ID: <part2.04050703.09010806@esc-net.de>
filename="twitter.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAABmJLR0QA/wD/ AP+gvaeTAAAA
CXBIWXMAAABIAAAASABGyWs+AAAACXZwQWcAAAAQAAAAEABcxq3DAAABxUlE QVQ4y4WTMW4U
QRBFX3X3zoy8FgZphTCYAEg4gAPEYbgBJEgEXIALkHMfAjIwItnAAfLK2JYB r3dmuj7BzI5m
2WBLqqzq//q/fxt9NTmrzo7MCIhgRpWSsaMSgEta5czcjYtWTKPxfALZXTEE 2wmAxLXD11VL
BZy2MAuJB/iuA3oAoJb4lUUCVkAGTM5t06gjATMjBiPFaFsADvx1MTFoBd/q zHkMeLcLgCEe
JqjbrCJ1IAkghGDz20Z/XEzMMMTnZTsSYANMAl7fq7YlZOBaUCCk4WowwyRA mBmL7CxcmwDu
rh+rzKU71YhQ/dnr8VbiaRF4MgmbAAZkxJU7lRk3Wby5W3FcJlbSICAjZjFS jJ42rSXWgoWL
fYPfLvaCMTVxJ0XoJTmQ/stF6GPABDhzcepi7uJ74yQDuXcDErjjGhkwNvHx xCjMOMkCg3eX
S85zyVEMtGt24GWVxvsM5yi3+nBV8/7iBmJv0gaZQMZhNL4cHXBYdDkY7HQL vD0oebVfQuud
a8FGHSAaP1vnpMmbHgDEECwafLq/x8fZlGfJKCVKiapvXLyoEsdl3JYwBMpd uW1YEjlz4aMh
AY+iURiU/Vf/B6EE4kjfs5YLAAAAAElFTkSuQmCC
name="linkedin.png"
Content-ID: <part3.06070402.00090904@esc-net.de>
filename="linkedin.png"
CXBIWXMAAABIAAAASABGyWs+AAAACXZwQWcAAAAQAAAAEABcxq3DAAACGklE QVQ4y6WTO2sU
URTHf3dmdp0kTnZJzErSrPjKYqNY2GljodhoLRLB1sLCD2DrZxAsfCAE/AaC grY+SBQSFTSC
xizGzZ3MTiYz92UxY5KNYuOBP+eew/3/73lwxfWHT9yjuR8YL0CwyxygAAPo Cqr0ntFcvjBB
cH++x8WzJzm8v/EnWVdks0PEgNWO95/XePD4HZ4ADk6MAhD6Hs26/08yBjwr ODrZBK0JADyv
LP7GsX2Evse9xR5Lsvgr+XfsO7ctoKwj9AWh7wEQIFCF+3sFGjCmgiJwQFwY Yge3X3cZrwXM
r2SDg9tJ1rokaw1alRXI3NAO61w60AAHTkE7qtNu1PjSUywsb3L60AgjNcHz hZgXb39WApoA
C3FqsIGjMxYC8OZbxlQU0GmFTLdCznWireV0pobYSDKevuzilMZDg0wN/cxu XdrMLVqX53TT
cu3OJ87cmmdlrQBgemoYKTMwqhSI+4Z0QMBhjANgcTnj1UdJHGd8Xc0AmBit Ecu0moGGODH0
h7cF8tyidSmgjSWWG6AUWpkypw1xLwXA4z8tQINcN/T3moEWtLZbr0mZQV5s 55RFJuU8RHR1
1iWtIzQ8nxOtIVCw9D2lWbM06w4ZZ8wtrEJRcLw9TDMUyKRg7kOPSHQR0ZVZ lyRjMDkOOVAU
FfLS57viHRaJLsHM+THuPtuDUgLTW2U0X672t47rrw82vOu/z9w8xS+MkDzV Boy6+QAAAABJ
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.04030201.09050806@esc-net.de>
filename="xing.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAACXBIWXMAAAsT AAALEwEAmpwY
AAABsklEQVR42mP8//8/AymAEb+G1x9333hU9fffZy52ZTONrQQ0/P7z7sLd hJfvN7Mw80mL
ROkqTodqAIKvv379+fuXhZmZh50dpv7f49dLLt1LYWD4ryRZCETsrJIIDYdu 3y5fu16AizPE
0CTFzgoo8fPXoxPX/T9/v8DHbWCito6LXRHFDw/evnXpm3D39Ws1Eck9xVmy wqLP3/SevlXC
ysKtLtuoJFmMxdObL17ymzqN8S9LnZddua/VrUcWD149FRNwNFFby8oiiEXD itNnImfN5WTi
nBhu7Gvw5OLdiv+MQnqKU6WEI7AE6+vPnx17+68+fmGrJL0wRe/rl/jbL94r isfqKs1kZuJE
1/Dt16/27TtatmzjYeZcnuZpqnDi3J16FmZxYDhKCAViibiVp8+Ur1v39N0H X12DFRkJ33/u
O3LVk+E/i5xYqq7iNCwaXn769PLTZ0ZGBnFePjE+3j9/3155kPvk9XIudgV9 5XnCfI6Ek8a7
T4dO3vD4+++HlHC4kepywhr+/P0ITEIPXk5jZxXTVpgE1EY48X36euHs7fBv P+8CVespzYGH
FSOpyRsAAuDh4a3m5z0AAAAASUVORK5CYII=
--------------080103070703040700030801--
--------------040709020302070307090500--
Re: [CDO] Profiling CDO [message #543494 is a reply to message #543449] Tue, 29 June 2010 11:04 Go to previous messageGo to next message
--------------020800090207020402080904
Hi Bastien,
Please also note the other hints on http://wiki.eclipse.org/Tweaking_CDO_Performance .
Cheers
/Eike
Am 29.06.2010 15:26, schrieb Bastien:
> Hi Cyril,
> Bastien.
boundary="------------050203070905040404050905"
--------------050203070905040404050905
<html>
<head>
</head>
Hi Bastien,<br>
<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/Tweaking_CDO_Performance">http://wiki.eclipse.org/Tweaking_CDO_Performance</a> .
<br>
<br>
<!--WISESTAMP_SIG_23141_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.03020304.01080806@esc-net.de" alt="Blogger"
src="cid:part2.09060002.03050309@esc-net.de" alt="Twitter"
src="cid:part3.06080808.04090909@esc-net.de"
_service=""><img
src="cid:part4.04020808.09050204@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_23141_END--><br>
<br>
<blockquote cite="mid:i0cs9p$ie2$1@build.eclipse.org" type="cite">Hi
Cyril,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Bastien.
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.03020304.01080806@esc-net.de>
name="twitter.png"
Content-ID: <part2.09060002.03050309@esc-net.de>
name="linkedin.png"
Content-ID: <part3.06080808.04090909@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.04020808.09050204@esc-net.de>
filename="xing.png"
--------------050203070905040404050905--
--------------020800090207020402080904--
Re: [CDO] Profiling CDO [message #543745 is a reply to message #542542] Wed, 30 June 2010 09:16 Go to previous messageGo to next message
Hi Eike,
I wrote the smallest program which retreives a model from my CDO, I applied the tweaks you describe here :
Setting EMF Parameters
Loading Partial Collections CDOCollectionLoadingPolicy
chunksize = 100
Prefetching Target Objects CDORevisionPrefetchingPolicy
initialChunkSize = 10, resolveChunkSize = 20
cdo-server.xml caching options
<property name="currentLRUCapacity" value="100000"/>
<property name="revisedLRUCapacity" value="100"/>
I also prefetched my remote resource but it doesn't seems to be working properly in spite of your advice.
I ran this program 5 times in a new workspace and from a newly started server.
Here are the informations about the model I retreive:
number of model elements : 59258
copying times :
#1: 133sec
#2: 134sec
#3: 129sec
#4: 128sec
#5: 126sec
As I started from a clean workspace and a newly started server, when I made these retreivals I was sure that my CDO resource wasn't loaded client side.
Bastien.
Re: [CDO] Profiling CDO [message #543843 is a reply to message #543745] Wed, 30 June 2010 13:37 Go to previous messageGo to next message
Bastien,
some tips to help finding out the bottleneck:
- Although you already tried out with prefetch, lets try at least if
increasing CDORevisionPrefetchingPolicy and CDOCollectionLoadingPolicy
has any impact. If you have large collections, you trying out with
chunkSizes of 100 and up...
- Try to use a profiler, like VisualVM (free), Yourkit Java Profiler
(comercial). These would help you find out which methods are taking most
CPU time.
- Not sure which Database you're using, but I would recommend trying H2.
Derby is definitely not recommended, it provides very poor performances
:( Try also HSQLDB, just so you can get some numbers as reference for
your measures / comparisons.
Let's us know it there is an improvement...
Bastien escribió:
> Hi Eike,
> Loading Partial Collections CDOCollectionLoadingPolicy chunksize = 100
> server.
> copying times :
> #1: 133sec
> #2: 134sec
> #3: 129sec
> #4: 128sec
> #5: 126sec
> client side.
> Bastien.
Re: [CDO] Profiling CDO [message #544063 is a reply to message #543843] Thu, 01 July 2010 09:45 Go to previous messageGo to next message
Victor,
Thanks for the tips.
I first tried the alternative database servers you suggested. They were easy to set up, but timings were similar to what we already recorded with MySQL.
I then took a set of measures using a TCP proxy (from grinder.sourceforge.net), restarting the client and server between each test.
For all tests, I used the same 3Mo model (when serialized to XMI) composed of about 49000 EObjects.
For each measure, I modified createRevisionPrefetchingPolicy, initialChunkSize, numberOfIndexToResolve or cdoPrefetch, one at a time, up to large values (1000 or more).
No tweaking led to meaningful timing differences. According to logged traffic, I never got under 33000 client requests (the typical initial number of requests was 37000).
My feeling is that this high requests count is my current bottleneck. I also think that those CDO parameters only influence the fetching of direct children of each node.
Yet, interestingly, my test model is a rather shallow and wide tree (no references between siblings as an example). My understanding is that if only direct children are fetched, this graph structure will always lead to a high request count.
So I suppose that I need a "deep" fetching of children, greatchildren, etc. In this regard, what I feel is more surprising is that the cdoPrefetch parameter does not seem to influence this behavior; even set to 10 (our max tree depth is 7) or DEPTH_INFINITE, a large number of client requests is still performed.
Bastien.
Re: [CDO] Profiling CDO [message #544073 is a reply to message #544063] Thu, 01 July 2010 10:08 Go to previous messageGo to next message
--------------050806040305090305020806
Hi Guys,
Unfortunately I do not have much time because I am with a customer until tomorrow. Have you already tried the mapping strategy HorizontalAuditMappingStrategyWithRanges? It has been contributed to optimize the many-valued feature mapping performance problems. Please try to find out how to set it up and come back with questions here ;-)
Cheers
/Eike
Am 01.07.2010 15:45, schrieb Bastien:
> Victor,
> Bastien.
boundary="------------080708080505010106000505"
--------------080708080505010106000505
<html>
<head>
</head>
Hi Guys,<br>
<br>
come back with questions here ;-)<br>
<br>
<!--WISESTAMP_SIG_53373_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.06000808.07070208@esc-net.de" alt="Blogger"
src="cid:part2.09070602.06010308@esc-net.de" alt="Twitter"
src="cid:part3.01050500.04030808@esc-net.de"
_service=""><img
src="cid:part4.07030904.09060100@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_53373_END--><br>
<br>
<blockquote cite="mid:i0i65f$2gc$1@build.eclipse.org" type="cite">Victor,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
each test.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
performed.
<br>
<br>
<br>
<br>
Bastien.
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.06000808.07070208@esc-net.de>
name="twitter.png"
Content-ID: <part2.09070602.06010308@esc-net.de>
name="linkedin.png"
Content-ID: <part3.01050500.04030808@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.07030904.09060100@esc-net.de>
filename="xing.png"
--------------080708080505010106000505--
--------------050806040305090305020806--
Re: [CDO] Profiling CDO [message #544100 is a reply to message #544073] Thu, 01 July 2010 11:09 Go to previous messageGo to next message
Hi Eike,
I tried your solution, following this entry :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=296440
Unfortunately, I didn't notice any performance improvement.
The retreival duration and the number of client requests are still the same as before.
Bastien
Re: [CDO] Profiling CDO [message #544117 is a reply to message #544100] Thu, 01 July 2010 11:27 Go to previous messageGo to next message
--------------060105020508060303090701
Hi Bastien,
Sorry, IIRC the HorizontalAuditMappingStrategyWithRanges was meant to optimize commits of changes ;-(
Cheers
/Eike
Am 01.07.2010 17:09, schrieb Bastien:
> Hi Eike,
> Bastien
boundary="------------010008080501050703010402"
--------------010008080501050703010402
<html>
<head>
</head>
Hi Bastien,<br>
<br>
to optimize commits of changes ;-(<br>
<br>
<!--WISESTAMP_SIG_58438_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.03060403.03050306@esc-net.de" alt="Blogger"
src="cid:part2.03000508.08020809@esc-net.de" alt="Twitter"
src="cid:part3.09050806.09060704@esc-net.de"
_service=""><img
src="cid:part4.03080402.03070403@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_58438_END--><br>
<br>
<blockquote cite="mid:i0ib3f$6hc$1@build.eclipse.org" type="cite">Hi
Eike,
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=296440">https://bugs.eclipse.org/bugs/show_bug.cgi?id=296440</a>
<br>
<br>
<br>
the same as before.
<br>
<br>
<br>
Bastien
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.03060403.03050306@esc-net.de>
name="twitter.png"
Content-ID: <part2.03000508.08020809@esc-net.de>
name="linkedin.png"
Content-ID: <part3.09050806.09060704@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.03080402.03070403@esc-net.de>
filename="xing.png"
--------------010008080501050703010402--
--------------060105020508060303090701--
Re: [CDO] Profiling CDO [message #544680 is a reply to message #542542] Mon, 05 July 2010 05:13 Go to previous messageGo to next message
Hi Eike,
following what you said about cdoPrefetch() method which was that it only works when it's the first time the resource is loaded, I studied a bit how this works and I think the way I get a resource from my CDO is not right.
Here's how I do this :
CDOView view = session.openView();
view.options().setRevisionPrefetchingPolicy(CDOUtil.createRe visionPrefetchingPolicy(10000));
cdoResource = (CDOResource) view.getResource("/pathToMyResource");
cdoResource.cdoPrefetch(10);
The thing is, the getResource() method automatically loads it with default prefetching depth value : 0.
So when I call the cdoPrefetch() method, it considers that my resource is already loaded and doesn't process the prefetching code.
that's why I'd like to know either if there's a way to set a default prefetching parameter (server side for example) or if I my code have to be modified.
regards,
Bastien.
Re: [CDO] Profiling CDO [message #544695 is a reply to message #544680] Mon, 05 July 2010 05:34 Go to previous messageGo to next message
--------------080900010504060108070205
Hi Bastien,
As long as the cdoPrefetch() call is ignored for already loaded objects it may be a bad idea to use a RevisionPrefetchingPolicy with the CDOView. Maybe it helps to remove the policy and call cdoPrefetch() not on the resource but on its root objects?
Cheers
/Eike
Am 05.07.2010 11:13, schrieb Bastien:
> Hi Eike,
> regards,
> Bastien.
boundary="------------090804070407040006000405"
--------------090804070407040006000405
<html>
<head>
</head>
Hi Bastien,<br>
<br>
cdoPrefetch() not on the resource but on its root objects?<br>
<br>
<!--WISESTAMP_SIG_21975_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.00020109.04020306@esc-net.de" alt="Blogger"
src="cid:part2.05050103.05050407@esc-net.de" alt="Twitter"
src="cid:part3.00030005.01020709@esc-net.de"
_service=""><img
src="cid:part4.02070303.05070102@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_21975_END--><br>
<br>
<blockquote cite="mid:i0s7on$98h$1@build.eclipse.org" type="cite">Hi
Eike,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
code.
<br>
<br>
<br>
<br>
regards,
<br>
Bastien.
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.00020109.04020306@esc-net.de>
name="twitter.png"
Content-ID: <part2.05050103.05050407@esc-net.de>
name="linkedin.png"
Content-ID: <part3.00030005.01020709@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.02070303.05070102@esc-net.de>
filename="xing.png"
--------------090804070407040006000405--
--------------080900010504060108070205--
Re: [CDO] Profiling CDO [message #544756 is a reply to message #542542] Mon, 05 July 2010 08:42 Go to previous messageGo to next message
Hi Eike,
Here's how my code looks like considering the advices you gave me:
cdoResource = view.getResource("/pathToMyResource");
EObject rootObj = cdoResource.getContents().get(0);
((CDOObject)rootObj).cdoPrefetch(10);
my root object is automatically added to the revisionCache when accessed with cdoResource.getContents().get(0);
My feeling is that during the prefetching, the revisionManager considers it as available (RevisionInfo.Available) instead of missing (RevisionInfo.Missing), and that's why the prefetching is not done.
That's why I'm wondering if there's a problem with my code or if maybe there's a way to clean up the revision cache.
Bastien.
Re: [CDO] Profiling CDO [message #544803 is a reply to message #544756] Mon, 05 July 2010 10:17 Go to previous messageGo to next message
Am 05.07.2010 14:42, schrieb Bastien:
> Hi Eike,
As I mentioned before, this must be a result of your view.options().setRevisionPrefetchingPolicy(...). Remove it if you want to manually prefetch trees.
Exactly. I mentioned before that you could submit a bugzilla to ask for a change.
Without the RevisionPrefetchingPolicy your root objects should be in PROXY state and their revisions should not be already cached.
> Bastien.
Re: [CDO] Profiling CDO [message #544838 is a reply to message #542542] Mon, 05 July 2010 12:46 Go to previous messageGo to next message
Eike,
I already removed the view.options().setRevisionPrefetchingPolicy(...) in my previous post,I should have said so in order to be clearer, my apologies.
When the cdoPrefetch() method is called my root object is in CLEAN state, even when I removed the RevisionPrefetchingPolicy.
I filed a bugzilla here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318919
Bastien.
Re: [CDO] Profiling CDO [message #544876 is a reply to message #544838] Mon, 05 July 2010 15:49 Go to previous messageGo to next message
--------------010000000106060405010806
Hi Bastien,
Are you using the new legacy mode? Maybe by accident?
Cheers
/Eike
Am 05.07.2010 18:46, schrieb Bastien:
> Eike,
> Bastien.
boundary="------------030204070308020800050501"
--------------030204070308020800050501
<html>
<head>
</head>
Hi Bastien,<br>
<br>
Are you using the new legacy mode? Maybe by accident?<br>
<br>
<!--WISESTAMP_SIG_12696_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.05090203.07000807@esc-net.de" alt="Blogger"
src="cid:part2.04040708.06090108@esc-net.de" alt="Twitter"
src="cid:part3.09000401.02010904@esc-net.de"
_service=""><img
src="cid:part4.09030406.04060400@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_12696_END--><br>
<br>
<blockquote cite="mid:i0t2a3$dsc$1@build.eclipse.org" type="cite">Eike,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=318919">https://bugs.eclipse.org/bugs/show_bug.cgi?id=318919</a>
<br>
<br>
<br>
Bastien.
<br>
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.05090203.07000807@esc-net.de>
name="twitter.png"
Content-ID: <part2.04040708.06090108@esc-net.de>
name="linkedin.png"
Content-ID: <part3.09000401.02010904@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.09030406.04060400@esc-net.de>
filename="xing.png"
--------------030204070308020800050501--
--------------010000000106060405010806--
Re: [CDO] Profiling CDO [message #544882 is a reply to message #542542] Mon, 05 July 2010 17:17 Go to previous messageGo to next message
Hum indeed I'm using it, I once had a problem with a model I wanted to commit, so I had to activate it.
Bastien.
Re: [CDO] Profiling CDO [message #544914 is a reply to message #544882] Tue, 06 July 2010 00:44 Go to previous messageGo to next message
--------------070902070508000207080607
Hi Bastien,
That might explain it. As far as I know lazy loading is not supported for legacy objects at all. We might be able to optimize that a little bit but in general the legacy mode is not well suited for large models.
Cheers
/Eike
Am 05.07.2010 23:17, schrieb Bastien:
> Bastien.
boundary="------------000305080806080206060602"
--------------000305080806080206060602
<html>
<head>
</head>
Hi Bastien,<br>
<br>
for large models.<br>
<br>
<!--WISESTAMP_SIG_69298_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.06070009.06000500@esc-net.de" alt="Blogger"
src="cid:part2.00070500.04000803@esc-net.de" alt="Twitter"
src="cid:part3.08060607.03050403@esc-net.de"
_service=""><img
src="cid:part4.09000707.03010404@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_69298_END--><br>
<br>
<blockquote cite="mid:i0ti4g$l01$1@build.eclipse.org" type="cite">Hum
<br>
<br>
<br>
Bastien.
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.06070009.06000500@esc-net.de>
name="twitter.png"
Content-ID: <part2.00070500.04000803@esc-net.de>
name="linkedin.png"
Content-ID: <part3.08060607.03050403@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.09000707.03010404@esc-net.de>
filename="xing.png"
--------------000305080806080206060602--
--------------070902070508000207080607--
Re: [CDO] Profiling CDO [message #544940 is a reply to message #544914] Tue, 06 July 2010 03:21 Go to previous messageGo to next message
Hi Bastien,
yes. Sounds as if Legacy could be the root of the problem. ;(
As Eike mentioned there is some potential for optimization but I doubt that as long legacy does not support lazy loading it is well suited for models of your size.
Could you please file a bugzilla for this topic? Then we will see what we can do.
You mentioned that you had trouble with your model and that's why switched to legacy. What was this problem? Maybe we can help solving this (maybe it's even a bug)?
Martin
[Updated on: Tue, 06 July 2010 03:24] by Moderator
Re: [CDO] Profiling CDO [message #544945 is a reply to message #542542] Tue, 06 July 2010 03:48 Go to previous messageGo to next message
Hi Martin and Eike,
I had to activate the legacy mode this friday (02/07) afternoon because the problem happened after I updated my cdo 3.0 version from v20100309 to v20100618
was the legacy mode implemented in the earlier version I used, and was it activated by default?
Edit: after verification, before this friday, I couldn't use legacy mode because of my earlier version of CDO v20100309.
Bastien.
[Updated on: Tue, 06 July 2010 04:00] by Moderator
Re: [CDO] Profiling CDO [message #544961 is a reply to message #544945] Tue, 06 July 2010 04:42 Go to previous messageGo to next message
--------------010605000600090303050306
Hi Bastien,
So, what was that problem that you hoped to fix with using the legacy mode?
Cheers
/Eike
Am 06.07.2010 09:48, schrieb Bastien:
> Hi Martin and Eike,
> I had to activate the legacy mode this friday (07/02) afternoonn because the problem happened after I updated my cdo 3.0 version from v20100309 to v20100618
> Bastien.
boundary="------------080500070000020309080905"
--------------080500070000020309080905
<html>
<head>
</head>
Hi Bastien,<br>
<br>
legacy mode?<br>
<br>
<!--WISESTAMP_SIG_45878_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.07070802.04050606@esc-net.de" alt="Blogger"
src="cid:part2.06030806.06060908@esc-net.de" alt="Twitter"
src="cid:part3.03010204.00040802@esc-net.de"
_service=""><img
src="cid:part4.09050004.00000200@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_45878_END--><br>
<br>
<blockquote cite="mid:i0un56$f8h$1@build.eclipse.org" type="cite">Hi
Martin and Eike,
<br>
<br>
from v20100309 to v20100618 <br>
<br>
<br>
<br>
Bastien.
<br>
<br>
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.07070802.04050606@esc-net.de>
name="twitter.png"
Content-ID: <part2.06030806.06060908@esc-net.de>
name="linkedin.png"
Content-ID: <part3.03010204.00040802@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.09050004.00000200@esc-net.de>
filename="xing.png"
--------------080500070000020309080905--
--------------010605000600090303050306--
Re: [CDO] Profiling CDO [message #544965 is a reply to message #542542] Tue, 06 July 2010 04:56 Go to previous messageGo to next message
Eike,
Actually I commit several models (conform to different meta-models) on my CDO, and it's the commit of one of these model (always the same) which posed problem.
I had an error saying that the legacy mode was not activated, so I activated it and the commit worked.
regards,
Bastien.
[Updated on: Tue, 06 July 2010 05:04] by Moderator
Re: [CDO] Profiling CDO [message #544967 is a reply to message #544945] Tue, 06 July 2010 04:44 Go to previous messageGo to next message
> Hi Martin and Eike,
IIRC. that was approximately the period when we realized that the legacy mode accidentally was left on by default and changed the default to "off".
The question is still why you are thinking that you need the legacy mode, whether it's on by default or by your manual configuration?
Re: [CDO] Profiling CDO [message #544968 is a reply to message #544945] Tue, 06 July 2010 04:45 Go to previous messageGo to next message
--------------020003090708040206020806
Hi Bastien,
Another question: Do your posts appear wrongly "rooted" only for me? Why don't you reply to the post that your reply should appear under?
Cheers
/Eike
> Hi Martin and Eike,
> Bastien.
boundary="------------050307070800000609010001"
--------------050307070800000609010001
<html>
<head>
</head>
Hi Bastien,<br>
<br>
Why don't you reply to the post that your reply should appear under?<br>
<br>
<!--WISESTAMP_SIG_39221_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.06030501.07010207@esc-net.de" alt="Blogger"
src="cid:part2.04020208.04010801@esc-net.de" alt="Twitter"
src="cid:part3.09000800.01030201@esc-net.de"
_service=""><img
src="cid:part4.06010307.03070806@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_39221_END--><br>
<br>
Martin and Eike,
<br>
<br>
<br>
<br>
<br>
Bastien.
<br>
<br>
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.06030501.07010207@esc-net.de>
name="twitter.png"
Content-ID: <part2.04020208.04010801@esc-net.de>
name="linkedin.png"
Content-ID: <part3.09000800.01030201@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.06010307.03070806@esc-net.de>
filename="xing.png"
--------------050307070800000609010001--
--------------020003090708040206020806--
Re: [CDO] Profiling CDO [message #544975 is a reply to message #544968] Tue, 06 July 2010 05:09 Go to previous messageGo to next message
Eike,
I'm sorry I use the flat view message and topic listing instead of tree message listing.
I'll allways use the "reply message" in my next posts, this topic will then be clearer.
Regards, Bastien.
Re: [CDO] Profiling CDO [message #544980 is a reply to message #544967] Tue, 06 July 2010 05:16 Go to previous messageGo to next message
Eike,
But the model which posed problem with the legacy mode is not the one which I have performance issues with.
regards,
Bastien.
Re: [CDO] Profiling CDO [message #544981 is a reply to message #544965] Tue, 06 July 2010 05:17 Go to previous messageGo to next message
Bastien,
if you recieve an error saying that legacy is not enable, this means that you tried to commit a non-native CDO model. This means that you are operating on a plain EMF objects instead of a converted one. Switching to legacy in this case should only be done if there is a good reason for it (e.g you cannot regenerate the model). Otherwise the model should always be converted to a CDO native one. Wink
Martin
Re: [CDO] Profiling CDO [message #544984 is a reply to message #544981] Tue, 06 July 2010 05:29 Go to previous messageGo to next message
Martin,
The genmodel corresponding to the model I want to commit is already converted, maybe there's an issue somewhere.
Bastien.
Re: [CDO] Profiling CDO [message #544985 is a reply to message #544965] Tue, 06 July 2010 05:19 Go to previous messageGo to next message
--------------000305070906080601020604
Hi Bastien,
This error message that you're referring to was basically telling you two things:
1) Your object was a legacy object (i.e. not generated for CDO).
2) Your transaction was not configured for legacy objects.
Generally you should try to fix it by changing point 1), i.e. regenerate your model for CDO. See http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO
Only if it's not possible or desirablefor mysterious resons you should consider to fix it by changing point 2).
There's more info here:
http://www.mftech.org/blog/pivot/entry.php?id=18
Cheers
/Eike
Am 06.07.2010 10:56, schrieb Bastien:
> Eike,
> regards,
> Bastien.
boundary="------------040906000308080508030205"
--------------040906000308080508030205
<html>
<head>
</head>
Hi Bastien,<br>
<br>
you two things:<br>
<br>
1) Your object was a legacy object (i.e. not generated for CDO).<br>
2) Your transaction was not configured for legacy objects.<br>
<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO">http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO</a><br>
<br>
should consider to fix it by changing point 2).<br>
<br>
There's more info here:<br>
<a class="moz-txt-link-freetext" href="http://www.mftech.org/blog/pivot/entry.php?id=18">http://www.mftech.org/blog/pivot/entry.php?id=18</a><br>
<br>
<!--WISESTAMP_SIG_74949_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.03000209.08090503@esc-net.de" alt="Blogger"
src="cid:part2.01080507.07060405@esc-net.de" alt="Twitter"
src="cid:part3.02040704.00040801@esc-net.de"
_service=""><img
src="cid:part4.08010005.02080702@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_74949_END--><br>
<br>
<blockquote cite="mid:i0ur4d$1gs$1@build.eclipse.org" type="cite">Eike,
<br>
<br>
<br>
<br>
regards,
<br>
Bastien.
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.03000209.08090503@esc-net.de>
name="twitter.png"
Content-ID: <part2.01080507.07060405@esc-net.de>
name="linkedin.png"
Content-ID: <part3.02040704.00040801@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.08010005.02080702@esc-net.de>
filename="xing.png"
--------------040906000308080508030205--
--------------000305070906080601020604--
Re: [CDO] Profiling CDO [message #544993 is a reply to message #544984] Tue, 06 July 2010 06:09 Go to previous messageGo to next message
Hum in fact it was an issue in my code, consider it solved, the legacy mode is no longer used or required.
regards,
Bastien.
[Updated on: Tue, 06 July 2010 06:09] by Moderator
Re: [CDO] Profiling CDO [message #545001 is a reply to message #544993] Tue, 06 July 2010 06:26 Go to previous messageGo to next message
--------------010501090300070404020501
Excellent ;-)
Cheers
/Eike
Am 06.07.2010 12:09, schrieb Bastien:
> Hum in fact it was an issue in my code, consider it solved, the legacy mode is no longer used.
> regards,
> Bastien.
boundary="------------060500070002000809090106"
--------------060500070002000809090106
<html>
<head>
</head>
Excellent ;-)<br>
<br>
<!--WISESTAMP_SIG_69427_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.05010909.06090701@esc-net.de" alt="Blogger"
src="cid:part2.09000103.08070605@esc-net.de" alt="Twitter"
src="cid:part3.07030308.01080903@esc-net.de"
_service=""><img
src="cid:part4.09090300.06050000@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_69427_END--><br>
<br>
<blockquote cite="mid:i0uvc8$t8i$1@build.eclipse.org" type="cite">Hum
<br>
<br>
regards,
<br>
Bastien.
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.05010909.06090701@esc-net.de>
name="twitter.png"
Content-ID: <part2.09000103.08070605@esc-net.de>
name="linkedin.png"
Content-ID: <part3.07030308.01080903@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.09090300.06050000@esc-net.de>
filename="xing.png"
--------------060500070002000809090106--
--------------010501090300070404020501--
Re: [CDO] Profiling CDO [message #545003 is a reply to message #545001] Tue, 06 July 2010 06:34 Go to previous messageGo to next message
Eike,
considering the scope of this bug (4.0 version):
Can you point me to the classes I should study in order for me to modify my local CDO installation (client and server side) and force the prefetching?
Bastien.
Re: [CDO] Profiling CDO [message #545013 is a reply to message #545003] Tue, 06 July 2010 07:03 Go to previous messageGo to next message
--------------090200000101000805020902
Hi Bastien,
I think this method should react to the prefetchDepth parameter of its calling method:
org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.createRevisionInfos(List <CDOID>, CDOBranchPoint, boolean, RevisionInfo[])
.... and only return RevisionInfo.Missing instances.
Cheers
/Eike
Am 06.07.2010 12:34, schrieb Bastien:
> Eike,
> Bastien.
boundary="------------090903020605010107070005"
--------------090903020605010107070005
<html>
<head>
</head>
Hi Bastien,<br>
<br>
its calling method:<br>
<br>
org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.createRevisionInfos(List&lt;CDOID&gt;,
<br>
<br>
... and only return RevisionInfo.Missing instances.<br>
<br>
<!--WISESTAMP_SIG_38011_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.00040202.09070602@esc-net.de" alt="Blogger"
src="cid:part2.03060506.05030700@esc-net.de" alt="Twitter"
src="cid:part3.04000600.04010209@esc-net.de"
_service=""><img
src="cid:part4.02000809.08080503@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_38011_END--><br>
<br>
<blockquote cite="mid:i0v0sb$a1b$1@build.eclipse.org" type="cite">Eike,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Bastien.
<br>
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.00040202.09070602@esc-net.de>
name="twitter.png"
Content-ID: <part2.03060506.05030700@esc-net.de>
name="linkedin.png"
Content-ID: <part3.04000600.04010209@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.02000809.08080503@esc-net.de>
filename="xing.png"
--------------090903020605010107070005--
--------------090200000101000805020902--
Re: [CDO] Profiling CDO [message #545038 is a reply to message #545013] Tue, 06 July 2010 09:44 Go to previous messageGo to next message
Eike,
Thanks for the tip, I've had already located this method, but a confirmation is always welcome Wink
I did some modification by my side:
First, I modified the
org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.createRevisionInfos(List <CDOID>, CDOBranchPoint, boolean, RevisionInfo[]) for it to return all kinds of revision infos.
then I had to modify org.eclipse.emf.cdo.internal.server.Repository.loadRevisions (List <RevisionInfo> infos, CDOBranchPoint branchPoint, int referenceChunk, int prefetchDepth) method,
basically I removed the whole switch about the RevisionInfo.Type
With these modifications, the CDOObject#cdoPrefetch() method is working effectively, but there's still a little issue, indeed, I have a TimeOutException after 10seconds.
I tried to use this: connector.setOpenChannelTimeout(IConnector.NO_CHANNEL_TIMEOU T); but I still have a timeout after 10 seconds. Is there an option to add in my server configuration for example?
Bastien.
Re: [CDO] Profiling CDO [message #545107 is a reply to message #545038] Tue, 06 July 2010 12:11 Go to previous messageGo to next message
Am 06.07.2010 15:44, schrieb Bastien:
> Eike,
> Thanks for the tip, I've had already located this method, but a confirmation is always welcome ;)
> First, I modified the org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.createRevisionInfos(List <CDOID>, CDOBranchPoint, boolean, RevisionInfo[]) for it to return all kinds of revision infos.
> then I had to modify org.eclipse.emf.cdo.internal.server.Repository.loadRevisions (List <RevisionInfo> infos, CDOBranchPoint branchPoint, int referenceChunk, int prefetchDepth) method, basically I removed the whole switch about the RevisionInfo.Type
Why don't you attach a patch to the bugzilla you submitted? Then it'd be easier to talk about it ;-)
That doesn't sound reasonable for a Signal that should have the major payload in the respsone and the root cause should be investigated. Note that the timer expires only after a period of no incoming data at the client and is reset if more data arrives before expiration. It's not a total request-start/response-end timeout!
I doubt that the OpenChannelTimeout would help here. You may want to change the Signal read timeout via ISignalProtocol.setTimeout(long). For a CDOSession that's available via org.eclipse.emf.cdo.net4j.CDOSession.Options.getProtocol().
Not that I know of ;-(
> Bastien.
Re: [CDO] Profiling CDO [message #545232 is a reply to message #545107] Wed, 07 July 2010 05:33 Go to previous messageGo to next message
Hi Eike,
I added this line in my retreival code :
session.options().getProtocol().setTimeout(300000L);
Then the prefetching is working properly Smile
But I still have a few questions!
Here's the use case:
-This model is uploaded once on the server,
-Several clients need to retreive it, but each of them once.
that's my I'm wondering if, for every client which have to retreive this model, the server will do the prefetching.
Bastien.
Re: [CDO] Profiling CDO [message #545246 is a reply to message #545232] Wed, 07 July 2010 05:50 Go to previous messageGo to next message
--------------050506050305010005000307
Hi Bastien,
The server does what the client requests. Of course the repository has an own revision cache to optimize back-end accesses.
Cheers
/Eike
Am 07.07.2010 11:34, schrieb Bastien:
> Hi Eike,
> Then the prefetching is working properly :)
> Bastien.
boundary="------------010305090206050809060401"
--------------010305090206050809060401
<html>
<head>
</head>
Hi Bastien,<br>
<br>
<br>
<br>
<!--WISESTAMP_SIG_70556_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.02060101.02000405@esc-net.de" alt="Blogger"
src="cid:part2.08050709.03030707@esc-net.de" alt="Twitter"
src="cid:part3.07090202.04070203@esc-net.de"
_service=""><img
src="cid:part4.01080408.00040402@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_70556_END--><br>
<br>
<blockquote cite="mid:i11hm8$c9a$1@build.eclipse.org" type="cite">Hi
Eike,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Bastien.
<br>
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.02060101.02000405@esc-net.de>
name="twitter.png"
Content-ID: <part2.08050709.03030707@esc-net.de>
name="linkedin.png"
Content-ID: <part3.07090202.04070203@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.01080408.00040402@esc-net.de>
filename="xing.png"
--------------010305090206050809060401--
--------------050506050305010005000307--
Re: [CDO] Profiling CDO [message #545276 is a reply to message #545246] Wed, 07 July 2010 06:50 Go to previous messageGo to next message
Eike,
Thanks for the infos, what I wanted to know was, are the revisions prefetched by cdoPrefetch() stored server or client side?
I've done some tests with different clients (on different machines), these revisions seems to be stored in the cache server side.
first client prefetching: 122998ms
first local copying: 1749ms
second client prefetching: 1235ms
second local copying: 1734ms
Given that I have lots of models on my CDO, and the fact that they can be retreived at any time, my feeling is that I need a big cache server side to store a lot of revisions.
Bastien.
[Updated on: Wed, 07 July 2010 06:50] by Moderator
Re: [CDO] Profiling CDO [message #545300 is a reply to message #545276] Wed, 07 July 2010 07:25 Go to previous messageGo to next message
Am 07.07.2010 12:50, schrieb Bastien:
> Eike,
The word "stored" confuses me. I guess you're really meaning "cached".
The repository caches as many revisions as it can to reduce reloading them from the storage back-end.
The client caches as many revisions as it can to reduce reloading them from the repository.
> I've done some tests with different clients (on different machines), they seems to be stored server side.
Makes sense.
Also sounds like a good idea ;-)
Re: [CDO] Profiling CDO [message #545337 is a reply to message #545300] Wed, 07 July 2010 09:20 Go to previous messageGo to next message
Eike,
First of all, I would like to precise that in my previous post, when I wrote "first client / second client", I litterally meant it: the second client fetching was performed from another workstation.
So it seems to me, as confirmed by the second test (3s to fetch our model from a second client), that the network protocol is not the bottleneck anymore.
To confirm this analysis, we captured the TCP traffic of the previous tests. In both cases, the impact of my modification was significant: only 10 requests from the client to the server.
My feeling is that most of the time is now spent requesting the storage back-end in order to construct the server cache.
2 minutes seems a long time for such an operation, considering that my test model weights 3Mo and has about 50000 elements.
Do you have any advices to improve the back-end storage?
For now I'm using mysql, and my mapping strategy is horizontalNonAudit.
Given that my goal is to retreive the wholeness of my model, I'm in a situation where lazy loading shouldn't be used.
Bastien.
Re: [CDO] Profiling CDO [message #545392 is a reply to message #545337] Wed, 07 July 2010 11:46 Go to previous messageGo to next message
--------------060307090006070407070701
Hi Bastien,
You could open an embedded session in the repository and have a background thread preload and cache the often used resources. As you noticed, a large cache also helps (not configurable anymore). We use H2 as our default test DB and it seems pretty fast.
Stefan might remember if horizontalNonAudit mapping strategy is the most optimized one. I recall something like "WithRanges" optimization, but that might be a write optimization...
We might also consider more back-end protocol optimizations but I guess that effort needs to be funded somehow, given that you can have optimal results already with small workarounds like the aforementioned preload-thread.
Cheers
/Eike
Am 07.07.2010 15:20, schrieb Bastien:
> Eike,
> Bastien.
boundary="------------060904070109050104010608"
--------------060904070109050104010608
<html>
<head>
</head>
Hi Bastien,<br>
<br>
H2 as our default test DB and it seems pretty fast.<br>
<br>
optimization, but that might be a write optimization...<br>
<br>
aforementioned preload-thread.<br>
<br>
<!--WISESTAMP_SIG_60067_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.00080203.05090604@esc-net.de" alt="Blogger"
src="cid:part2.04010702.00080605@esc-net.de" alt="Twitter"
src="cid:part3.00040102.01010802@esc-net.de"
_service=""><img
src="cid:part4.08040903.00030307@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_60067_END--><br>
<br>
<blockquote cite="mid:i11uvc$1gb$1@build.eclipse.org" type="cite">Eike,
<br>
<br>
workstation.
<br>
<br>
<br>
<br>
<br>
<br>
storage back-end in order to construct the server cache. <br>
<br>
<br>
<br>
horizontalNonAudit.
<br>
<br>
<br>
<br>
<br>
Bastien.
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.00080203.05090604@esc-net.de>
name="twitter.png"
Content-ID: <part2.04010702.00080605@esc-net.de>
name="linkedin.png"
Content-ID: <part3.00040102.01010802@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.08040903.00030307@esc-net.de>
filename="xing.png"
--------------060904070109050104010608--
--------------060307090006070407070701--
Re: [CDO] Profiling CDO [message #545547 is a reply to message #545392] Thu, 08 July 2010 04:03 Go to previous messageGo to next message
Bastien, Eike,
Bastien, if you are able to try with H2, then this would help in
identifying the bottleneck.
If it is the database, then custom database optimizations (such as
partitioning) could help. So if you have some DB optimization/profiling
knowledge (or maybe you have a DB-guru at hand) then have a look if
there's any SQL that requires too much time. Maybe there is a column
index missing during CDO setup.
Also, on the DB-side,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=305962 is still open which
could result in a bottleneck of objects are read more than once (ok,
seems not to be the case for you).
It is an optimization for the auditmode and yes, it optimizes storing
more than reading ... So, if you don't need audit-mode, then the
non-audit strategy is more optimized.
Stefan
Re: [CDO] Profiling CDO [message #545693 is a reply to message #545547] Thu, 08 July 2010 12:02 Go to previous messageGo to next message
Hi Stephan,
I'm actually performing measurements and tests on both mysql and H2, my first impression is that H2 is faster than mysql (between 30 & 50%).
I'm still investigating so a post with more detailed numbers and tests explaination is coming tomorrow.
Bastien.
Re: [CDO] Profiling CDO [message #546224 is a reply to message #545547] Mon, 12 July 2010 04:37 Go to previous messageGo to next message
Hi Stefan,
I did some tests since my last post.
I am still using the same test model:
- 3Mo size
- about 50 000 model elements
- maximum depth: 7
I measured the performances with H2 and Mysql
Prefetching time server side:
- H2: between 60 and 80 seconds
- Mysql: between 120 and 130 seconds
Local copy of the model:
both about 1 or 2 seconds.
The gain with H2 is between 30 and 50%, but I still think 60 or 80 sec is too much for the retreival of a 50 000 elements sized model.
So, I managed to get the sql trafic between jdbc and the databases, and I could analyse a 4 requests pattern:
SET OPTION SQL_SELECT_LIMIT=DEFAULT
SELECT cdo_class FROM cdo_objects WHERE cdo_id=123
SET OPTION SQL_SELECT_LIMIT=1
SELECT cdo_version, cdo_created, cdo_revised, cdo_resource, cdo_container, cdo_feature, vt_data, value FROM MyMetamodel_MymodelElement WHERE cdo_id=123 AND (cdo_revised=0)
I'm not sure if the SET OPTIONS resquests are relevant here (maybe generated by jdbc), but I think It should be possible to decrease the amount of SELECT requests by combining the two of them.
Considering these informations, I'm actually working on some back-end modifications in order to do some other measurements.
Bastien.
Re: [CDO] Profiling CDO [message #546275 is a reply to message #546224] Mon, 12 July 2010 07:11 Go to previous message
--------------050706010705040501020704
Hi Bastien,
Comments below...
Cheers
/Eike
Am 12.07.2010 10:37, schrieb Bastien:
> Hi Stefan,
> - 3Mo size
What does that mean?
> - maximum depth: 7
I doubt that. Note that the second query string (the FROM clause in particular) can only be concatenated from the result of the first one. But of course we'd be happy if you could prove us wrong ;-)
> Bastien.
boundary="------------060901020200050006080303"
--------------060901020200050006080303
<html>
<head>
</head>
Hi Bastien,<br>
<br>
Comments below...<br>
<br>
<!--WISESTAMP_SIG_27611_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
src="cid:part1.06070700.04050309@esc-net.de" alt="Blogger"
src="cid:part2.09060805.08090802@esc-net.de" alt="Twitter"
src="cid:part3.06060700.01000603@esc-net.de"
_service=""><img
src="cid:part4.00020204.03010600@esc-net.de" alt="Xing"
underline;"><a
</div>
</span><!--WISESTAMP_SIG_27611_END--><br>
<br>
<blockquote cite="mid:i1ek8p$jbl$1@build.eclipse.org" type="cite">Hi
Stefan,
<br>
<br>
<br>
- 3Mo size
<br>
</blockquote>
What does that mean?<br>
<br>
<blockquote cite="mid:i1ek8p$jbl$1@build.eclipse.org" type="cite">-
<br>
- maximum depth: 7
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
model.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
one. But of course we'd be happy if you could prove us wrong ;-)<br>
<br>
<br>
<br>
<br>
<br>
Bastien.
<br>
</blockquote>
</body>
</html>
name="blogger.png"
Content-ID: <part1.06070700.04050309@esc-net.de>
name="twitter.png"
Content-ID: <part2.09060805.08090802@esc-net.de>
name="linkedin.png"
Content-ID: <part3.06060700.01000603@esc-net.de>
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.00020204.03010600@esc-net.de>
filename="xing.png"
--------------060901020200050006080303--
--------------050706010705040501020704--
Previous Topic:What's going on at topcased.org?
Next Topic:[Teneo] Extra Lazy Loading problems
Current Time: Mon Sep 15 02:26:43 EDT 2025
Powered by FUDForum. Page generated in 0.12901 seconds
