about.mappins and Buckminster 3.6 [message #542467] |
Thu, 24 June 2010 19:47  |
After upgrading my Buckminster / Hudson combo to 3.6, I encountered a bug (well, atleast I think so):
I'm trying to override the new default about.mappings action, i.e. I wish to use my own buildFile instead of the predefined buildFileId.
When I add the buildFile via alterActorProperties I get an exception that having both is not allowed; however I can't remove the buildFileId either.
Trying to remove it leads to:
org.eclipse.buckminster.core.common.model.ImmutablePropertyE xception: buildFileId
at org.eclipse.buckminster.core.common.model.ExpandingPropertie s.remove(ExpandingProperties.java:391)
at org.eclipse.buckminster.core.cspecext.model.AlterAttribute.p erformPropertyAlterations(AlterAttribute.java:68)
at org.eclipse.buckminster.core.cspecext.model.AlterAction.alte rActorProperties(AlterAction.java:91)
at org.eclipse.buckminster.core.cspecext.model.AlterAction.alte rAttribute(AlterAction.java:82)
at org.eclipse.buckminster.core.cspecext.model.CSpecExtension.a lterCSpec(CSpecExtension.java:111)
at org.eclipse.buckminster.core.cspec.AbstractResolutionBuilder .applyExtensions(AbstractResolutionBuilder.java:132)
at org.eclipse.buckminster.pde.cspecgen.PDEBuilder.build(PDEBui lder.java:70)
at org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:316)
at org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:201)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath (LocalResolver.java:163)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath (LocalResolver.java:184)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.r efreshProject(MetadataSynchronizer.java:313)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$M etadataRefreshJob.run(MetadataSynchronizer.java:126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Is this a feature or a bug? If it is a feature, how am I supposed to override the default about.mappings action??
FUDForum. Page generated in 0.05017 seconds
