Home » Language IDEs » C / C++ IDE (CDT) » installing cdt didnt work
installing cdt didnt work [message #542267] Thu, 24 June 2010 08:07 Go to next message
hi,
as the title says, i installed cdt and nothing happened. what i did:
downloaded the eclipse helios win32 zp and extracted it to c:\Program Files
started eclipse, entered http://download.eclipse.org/tools/cdt/releases/helios into the install new software dialog
checked main features and optional features, next, ok, agree... restart
and nothing changed. no new->project->c++, no new c++-perspective, no new c++-preferences... what did i do wrong?
maybe i just overlooked a checkbox or something like that, but i'm trying to find the problem for an hour now, but i found nothing...
Re: installing cdt didnt work [message #543900 is a reply to message #542267] Wed, 30 June 2010 22:08 Go to previous messageGo to next message
same problem here but with Fedora 13.
eclipse doesn't "see" CDT
C++ is never mentioned in any eclipse option .
icon6.gif  Re: installing cdt didnt work [message #543902 is a reply to message #542267] Wed, 30 June 2010 23:03 Go to previous messageGo to next message
If you are a windows user easiest way to get a working Eclipse for C/C++ is to get it installed from:
http://code.google.com/a/eclipselabs.org/p/wascana/downloads /list
Very Happy
Re: installing cdt didnt work [message #543924 is a reply to message #542267] Thu, 01 July 2010 02:35 Go to previous messageGo to next message
Johannes Linke wrote on Thu, 24 June 2010 08:07
hi,
Does CDT appear in the Installation Details (Help->About Eclipse)? Is there anything in the log when you start Eclipse (logfile is in $MYWORKSPACE/.metadata/.log)?
Re: installing cdt didnt work [message #544024 is a reply to message #542267] Thu, 01 July 2010 07:45 Go to previous messageGo to next message
On Thu, 24 Jun 2010 08:07:07 -0400, Johannes Linke
<johannes.linke@gmx.de> wrote:
>hi,
Random suggestion = move your whole eclipse folder in to c:\, not
c:\program files and see if that helps straight away.
A colleague has been having problems here with installing features and
then not having them available. I think moving eclipse out of program
files and in to the root folder has solved it (for the moment).
Re: installing cdt didnt work [message #544025 is a reply to message #543902] Thu, 01 July 2010 07:49 Go to previous messageGo to next message
> :d
As I understand it, that's the easiest way to get Eclipse/CDT on
Windows as a working version including the MinGW compiler. If the OP
already has MinGW, or Qt, or some other supported toolchain installed
then that's probably not the best way.
Also, if the OP wants to develop in Java and C++ then it sounds like
he's gone about it the right way.
If he only wants C/C++ IDE, and already has supported toolchains
installed, then the easiest way is to install the "Eclipse IDE for
C/C++" that you can download as a package from eclipse.org.
However - check out my comments on there possibly being issues with
installing in to Program Files.
Re: installing cdt didnt work [message #544589 is a reply to message #544025] Sun, 04 July 2010 10:35 Go to previous message
i actually think that is a bug, and i rather wanted a fix instead of a workaround Smile cdt is installed according to installation details, and there is nothng in the log. when moving to c: , cdt is not installed anymore.
edit: solved by moving to c: . i really wonder how this majow bug made it into the release.
[Updated on: Mon, 05 July 2010 10:22] by Moderator
Previous Topic:a simple CDT problem...no reference to C++ when creating new project
Next Topic:Error 1 and No rule to make target
Current Time: Sun Nov 02 21:33:50 EST 2025
Powered by FUDForum. Page generated in 0.05189 seconds
