Home » Eclipse Projects » Rich Client Platform (RCP) » I want do something before closing a view
I want do something before closing a view [message #542179] Thu, 24 June 2010 07:39 Go to next message
Ricky Ru is currently offline Ricky RuFriend
Hi friends,
As the title indicates, what should I do for it? I think I should add a listener and implement the close method. But can anyone tell me what the api is?
Re: I want do something before closing a view [message #542252 is a reply to message #542179] Thu, 24 June 2010 11:16 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel KrüglerFriend
On 24.06.2010 09:39, Ricky Ru wrote:
> Hi friends,
> api is?
You could use an IPartListener2 and listen for the partClosed
event. Since this is an often-occuring task, You might want
to create a helper class that accepts an IViewPart and does
this for you, see below.
HTH & Greetings from Bremen,
Daniel Krügler
public abstract class PartOpenCloseObserver {
private IPartListener2 listener = new IPartListener2() {
public void partActivated(IWorkbenchPartReference partRef) {
public void partBroughtToTop(IWorkbenchPartReference partRef) {
public void partClosed(IWorkbenchPartReference partRef) {
if (partRef.getPart(false) == part) {
partRef.getPage().removePartListener(listener);
PartOpenCloseObserver.this.partClosed(part);
public void partDeactivated(IWorkbenchPartReference partRef) {
public void partHidden(IWorkbenchPartReference partRef) {
public void partInputChanged(IWorkbenchPartReference partRef) {
public void partOpened(IWorkbenchPartReference partRef) {
PartOpenCloseObserver.this.partOpened(part);
public void partVisible(IWorkbenchPartReference partRef) {
private IWorkbenchPart part;
public PartOpenCloseObserver(IViewPart part) {
Assert.isNotNull(part);
this.part = part;
part.getSite().getPage().addPartListener(listener);
public PartOpenCloseObserver(IEditorPart part) {
this.part = part;
public abstract void partOpened(IWorkbenchPart part);
public abstract void partClosed(IWorkbenchPart part);
Re: I want do something before closing a view [message #542630 is a reply to message #542179] Fri, 25 June 2010 13:46 Go to previous messageGo to next message
Christophe Fondacci is currently offline Christophe FondacciFriend
Member
Hello Ricky,
If you're sure the view has been created (view controls were created / view had focus), you could simply overload the dispose() method in your view part and add all your "something" work in this method.
Note that this method will not be called if the view was never shown and the user simply clicked the cross without displaying the view, unless you forced view initialization through :
IWorkbenchPage.showView(YourView.VIEW_ID, null, IWorkbenchPage.VIEW_CREATE);
Hope this helps,
Christophe
http://www.nextep-softwares.com
Re: I want do something before closing a view [message #543352 is a reply to message #542630] Tue, 29 June 2010 08:01 Go to previous message
On 25.06.2010 15:46, Christophe Fondacci wrote:
> Hello Ricky,
I stumbled several times across the problem, that the ViewPart.dispose()
function is actually called, *after* the controls have been disposed,
which is sometimes too late for some-cleanup work - Therefore I
recommend to listen to an IPartListener2 instead.
- Daniel Krügler
Previous Topic:RCP product licence control
Next Topic:[databinding] Example for remove/add Viewer entries
Current Time: Thu Mar 30 09:36:09 GMT 2023
Powered by FUDForum. Page generated in 0.01506 seconds
