Re: How to investigate "Too many open files" error? [message #540767 is a reply to message #540057] |
Thu, 17 June 2010 10:00 |
mxm Messages: 4 Registered: June 2010 |
I am experiencing the same problems. I ran eclipse over night and since than
"Too many Files error" after working some minutes, that leads to not being able to store changes and a broken workspace.
I it tried to raise the local limit, but ulimit -n 2000, which is the doubled value, but that does not change anything.
I can not restart, did that help for you? I can not restart here!
[Updated on: Thu, 17 June 2010 10:02] Report message to a moderator
Re: How to investigate "Too many open files" error? [message #540854 is a reply to message #540767] |
Thu, 17 June 2010 13:46 |
Frank Theinen Messages: 10 Registered: July 2009 |
mxm wrote on Thu, 17 June 2010 06:00 | I am experiencing the same problems. I ran eclipse over night and since than
You are setting the 'soft' limit, not the 'hard' limit as with 'ulimit -Hn 2000'. But it doesn't seem to work anyway: I enlarged the hard limit from 8192 to 16384 (soft limit is 1024), but after the java process used file descriptor 8191 the problem occurred again.
Quote: | I can not restart, did that help for you? I can not restart here!
When closing Eclipse the file descriptors are freed, so restarting helps.
FUDForum. Page generated in 0.05449 seconds
