Re: build fails and then succeeds without me changing anything [message #540355 is a reply to message #540056] |
Tue, 15 June 2010 19:03 |
Andrew Niefer Messages: 990 Registered: July 2009 |
Check that you only have one instance of the org.eclipse.ui.views bundle in
your build setup.
In particular, look to see if you have imported this bundle into your
workspace and this is somehow available to the build.
Generally this kind of problem is caused by a feature specifying an "unpack"
value for a binary feature that does not match the shape on disk.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265471
The only way I can see this happening in a plugin based product build is
perhaps if there are multiple copies of the bundle available, one of which
is a folder. If there are multiple copies, this could also explain why it
succeeds sometimes and fails others, depending on which instance gets
chosen by the osgi resolver (which will be somewhat random).
-Andrew
Sam Jones wrote:
> I have a headless PDE/Build that sometimes passes and sometimes fails,
> seemingly without reason. I can run it 6 times in a row, and it will pass
> 2 and fail 4, in no particular order.
> What seems to be happening is that the generated target "assemble.archive"
> doesn't always reference the libraries correctly. Sometimes libraries are
> copied as a .jar file, and sometimes as a directory, and the build fails
> when that target is expecting one but gets the other. It's also not always
> the same library.
> Here is the last page or so of my build's console output on a failure:
> jarIng_NoManifest:
> jarUp:
> jarIng_NoManifest:
> jarUp:
> jarIng_NoManifest:
> jarUp:
> jarIng_NoManifest:
> jarUp:
> jarIng_NoManifest:
> customAssembly:
> generate.p2.metadata:
> assemble.archive:
> customAssembly:
> BUILD FAILED
> /home/sjones/eclipse/plugins/org.eclipse.pde.build_3.5.2.R35 x_20100114/scripts/productBuild/productBuild.xml:42:
> The following error occurred while executing this line:
> /home/sjones/eclipse/plugins/org.eclipse.pde.build_3.5.2.R35 x_20100114/scripts/build.xml:129:
> /home/sjones/eclipse/plugins/org.eclipse.pde.build_3.5.2.R35 x_20100114/templates/headless-build/customTargets.xml:12:
> /home/sjones/eclipse/plugins/org.eclipse.pde.build_3.5.2.R35 x_20100114/scripts/productBuild/allElements.xml:20:
> /home/sjones/eclipse/plugins/org.eclipse.pde.build_3.5.2.R35 x_20100114/scripts/genericTargets.xml:192:
> /home/sjones/workspace/package.org.eclipse.pde.build.contain er.feature.all.xml:24:
> /home/sjones/workspace/package.org.eclipse.pde.build.contain er.feature.all.xml:15:
> /home/sjones/eclipse/plugins/org.eclipse.pde.build_3.5.2.R35 x_20100114/scripts/productBuild/allElements.xml:75:
> /home/sjones/workspace/package.org.eclipse.pde.build.contain er.feature.linux.gtk.x86.xml:99:
> /home/sjones/workspace/package.org.eclipse.pde.build.contain er.feature.linux.gtk.x86.xml:280:
> /home/sjones/workspace/tmp/<project
> name>/plugins/org.eclipse.ui.views_3.4.1.M20090826-0800 not found.
> Total time: 40 seconds
> Here is the target in question:
> <target name="assemble.archive">
> <antcall target="customAssembly">
> <param name="rootFolder"
value="${eclipse.base}/linux.gtk.x86/${collectingFolder}"/ >
> <param name="customTarget" value="pre.archive"/>
> </antcall>
> <zip destfile="${archiveFullPath}" filesonly="false"
> whenempty="skip" update="true">
> <zipfileset
file="${eclipse.base}/plugins/com.ibm.icu_4.0.1.v20090822.jar "
fullpath="${pluginArchivePrefix}/com.ibm.icu_4.0.1.v20090822.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.core.commands_3.5.0.I200 90525-2000.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.core.commands_3.5.0.I2009 0525-2000.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.core.contenttype_3.4.1.R 35x_v20090826-0451.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.core.contenttype_3.4.1.R3 5x_v20090826-0451.jar "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.core.databinding_1.2.0.M 20090819-0800 "
prefix=" ${pluginArchivePrefix}/org.eclipse.core.databinding_1.2.0.M2 0090819-0800 "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.core.databinding.observa ble_1.2.0.M20090902-0800 "
prefix=" ${pluginArchivePrefix}/org.eclipse.core.databinding.observab le_1.2.0.M20090902-0800 "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.core.databinding.propert y_1.2.0.M20090819-0800 "
prefix=" ${pluginArchivePrefix}/org.eclipse.core.databinding.property _1.2.0.M20090819-0800 "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.core.expressions_3.4.101 .R35x_v20100209.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.core.expressions_3.4.101. R35x_v20100209.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.core.filesystem_1.2.1.R3 5x_v20091203-1235.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.core.filesystem_1.2.1.R35 x_v20091203-1235.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.core.jobs_3.4.100.v20090 429-1800.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.core.jobs_3.4.100.v200904 29-1800.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.core.resources_3.5.2.R35 x_v20091203-1235.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.core.resources_3.5.2.R35x _v20091203-1235.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.core.runtime_3.5.0.v2009 0525.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.core.runtime_3.5.0.v20090 525.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.equinox.app_1.2.1.R35x_v 20091203.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.equinox.app_1.2.1.R35x_v2 0091203.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.equinox.common_3.5.1.R35 x_v20090807-1100.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.equinox.common_3.5.1.R35x _v20090807-1100.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.equinox.preferences_3.2. 301.R35x_v20091117.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.equinox.preferences_3.2.3 01.R35x_v20091117.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.equinox.registry_3.4.100 .v20090520-1800.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.equinox.registry_3.4.100. v20090520-1800.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.help_3.4.1.v20090805_35x .jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.help_3.4.1.v20090805_35x. jar "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.jface_3.5.2.M20100120-08 00 "
prefix=" ${pluginArchivePrefix}/org.eclipse.jface_3.5.2.M20100120-080 0 "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.jface.databinding_1.3.1. M20090826-0800 "
prefix=" ${pluginArchivePrefix}/org.eclipse.jface.databinding_1.3.1.M 20090826-0800 "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.jface.text_3.5.2.r352_v2 0091118-0800 "
prefix=" ${pluginArchivePrefix}/org.eclipse.jface.text_3.5.2.r352_v20 091118-0800 "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.osgi_3.5.2.R35x_v2010012 6.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.osgi_3.5.2.R35x_v20100126 .jar "
> <zipfileset
file="${eclipse.base}/plugins/org.eclipse.swt_3.5.2.v3557f.jar "
fullpath="${pluginArchivePrefix}/org.eclipse.swt_3.5.2.v3557f.jar "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.text_3.5.0.v20090513-200 0.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.text_3.5.0.v20090513-2000 .jar "
> <zipfileset
dir="${eclipse.base}/plugins/org.eclipse.ui_3.5.2.M20100120-0800 "
prefix="${pluginArchivePrefix}/org.eclipse.ui_3.5.2.M20100120-0800 "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.ui.views_3.4.1.M20090826 -0800 "
prefix=" ${pluginArchivePrefix}/org.eclipse.ui.views_3.4.1.M20090826- 0800 "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.ui.workbench_3.5.2.M2010 0113-0800 "
prefix=" ${pluginArchivePrefix}/org.eclipse.ui.workbench_3.5.2.M20100 113-0800 "
> <zipfileset
file=" ${eclipse.base}/plugins/org.eclipse.equinox.launcher_1.0.201 .R35x_v20090715.jar "
fullpath=" ${pluginArchivePrefix}/org.eclipse.equinox.launcher_1.0.201. R35x_v20090715.jar "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.core.resources.compatibi lity_3.4.1.R35x_v20100113-0530 "
prefix=" ${pluginArchivePrefix}/org.eclipse.core.resources.compatibil ity_3.4.1.R35x_v20100113-0530 "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.core.runtime.compatibili ty.registry_3.2.200.v20090429-1800 "
prefix=" ${pluginArchivePrefix}/org.eclipse.core.runtime.compatibilit y.registry_3.2.200.v20090429-1800 "
> <zipfileset
dir=" ${eclipse.base}/plugins/org.eclipse.equinox.launcher.gtk.lin ux.x86_1.0.200.v20090520 "
prefix=" ${pluginArchivePrefix}/org.eclipse.equinox.launcher.gtk.linu x.x86_1.0.200.v20090520 "
> </zip>
> </target>
> and here is a listing of the tmp directory it is looking in:
> sjones@cc0:~/workspace/build.configuration$ ls
> /home/sjones/workspace/tmp/<project name>/plugins/
> org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
> org.eclipse.core.commands_3.5.0.I20090525-2000.jar
> org.eclipse.equinox.launcher.gtk.linux.x86_1.0.200.v20090520
> org.eclipse.core.contenttype_3.4.1.R35x_v20090826-0451.jar
> org.eclipse.equinox.preferences_3.2.301.R35x_v20091117.jar
> org.eclipse.core.databinding_1.2.0.M20090819-0800
> org.eclipse.equinox.registry_3.4.100.v20090520-1800.jar
> org.eclipse.core.databinding.observable_1.2.0.M20090902-0800
> org.eclipse.help_3.4.1.v20090805_35x.jar
> org.eclipse.core.databinding.property_1.2.0.M20090819-0800
> org.eclipse.jface_3.5.2.M20100120-0800
> org.eclipse.core.expressions_3.4.101.R35x_v20100209.jar
> org.eclipse.jface.databinding_1.3.1.M20090826-0800
> org.eclipse.core.filesystem_1.2.1.R35x_v20091203-1235.jar
> org.eclipse.jface.text_3.5.2.r352_v20091118-0800
> org.eclipse.core.jobs_3.4.100.v20090429-1800.jar
> org.eclipse.osgi_3.5.2.R35x_v20100126.jar
> org.eclipse.core.resources_3.5.2.R35x_v20091203-1235.jar
> org.eclipse.core.resources.compatibility_3.4.1.R35x_v2010011 3-0530
> org.eclipse.text_3.5.0.v20090513-2000.jar
> org.eclipse.core.runtime_3.5.0.v20090525.jar
> org.eclipse.core.runtime.compatibility.registry_3.2.200.v200 90429-1800
> org.eclipse.ui.views_3.4.1.M20090826-0800.jar
> org.eclipse.equinox.app_1.2.1.R35x_v20091203.jar
> org.eclipse.ui.workbench_3.5.2.M20100113-0800.jar
> org.eclipse.equinox.common_3.5.1.R35x_v20090807-1100.jar
> As you can see, it's looking for a folder for org.eclipse.ui.views, but
> this time through the build it created a .jar instead, breaking the
> assembly.
> Is there anything I can try to troubleshoot this?
Re: build fails and then succeeds without me changing anything [message #606062 is a reply to message #540056] |
your build setup.
-Andrew
> the same library.
> jarIng_NoManifest:
> jarUp:
> jarIng_NoManifest:
> jarUp:
> jarIng_NoManifest:
> jarUp:
> jarIng_NoManifest:
> jarUp:
> jarIng_NoManifest:
> customAssembly:
> assemble.archive:
> customAssembly:
> BUILD FAILED
> </antcall>
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> <zipfileset
> </zip>
> </target>
> assembly.
FUDForum. Page generated in 0.02837 seconds
