Home » Modeling » EMF » Contents not loading when using FlatEObjectImpl(working on performance improvements)
Contents not loading when using FlatEObjectImpl [message #540046] |
Mon, 14 June 2010 16:55 |
Tamar Cohen Messages: 103 Registered: July 2009 |
Hi EMF world --
I'm doing some performance tuning of my EMF code. When I change my .genmodel to extend FlatEObjectImpl instead of BasicEObjectImpl, the generated code no longer returns children when I call eContents().
I do also have some custom settings in the ResourceFactoryImpl as follows:
loadOptions.put(XMLResource.OPTION_EXTENDED_META_DATA, extendedMetaData);
loadOptions.put(XMLResource.OPTION_USE_PARSER_POOL, m_parserPool);
loadOptions.put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STY LE, Boolean.TRUE);
loadOptions.put(XMLResource.OPTION_USE_LEXICAL_HANDLER, Boolean.TRUE);
loadOptions.put(XMLResource.OPTION_LAX_FEATURE_PROCESSING, Boolean.TRUE);
loadOptions.put(XMLResource.OPTION_LAX_WILDCARD_PROCESSING, Boolean.TRUE);
loadOptions.put(XMLResource.OPTION_SKIP_ESCAPE, Boolean.TRUE);
loadOptions.put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
loadOptions.put(XMLResource.OPTION_DEFER_ATTACHMENT, Boolean.TRUE);
loadOptions.put(XMLResource.OPTION_DEFER_IDREF_RESOLUTION, Boolean.TRUE);
loadOptions.put(XMLResource.OPTION_USE_DEPRECATED_METHODS, Boolean.FALSE);
loadOptions.put(XMLResource.OPTION_USE_XML_NAME_TO_FEATURE_M AP, m_nameToFeatureMap);
loadOptions.put(XMLResource.OPTION_CONFIGURATION_CACHE, Boolean.TRUE);
Am I supposed to do something else to tell the FlatEObjectImpl to load its children?
thanks
Tamar
Re: Contents not loading when using FlatEObjectImpl [message #540051 is a reply to message #540046] |
Mon, 14 June 2010 17:06 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------000100060008020703080503
Tamar,
It should still be returning the right (same as before) list:
public EList<EObject> eContents()
if (eContents == null)
eContents = *EContentsEList.createEContentsEList(this)*;
return eContents;
It's a "view" on all the containment references...
Tamar Cohen wrote:
> Hi EMF world --
> follows:
> extendedMetaData);
> m_parserPool);
> LE, Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.FALSE);
> Boolean.TRUE);
> its children?
> thanks
> Tamar
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Tamar,<br>
<br>
It should still be returning the right (same as before) list:<small><br>
</small>
<blockquote><small> @Override</small><br>
<small> public EList<EObject> eContents()</small><br>
<small> {</small><br>
<small> if (eContents == null)</small><br>
<small> eContents = <b>EContentsEList.createEContentsEList(this)</b>;</small ><br>
<small> }</small><br>
<small> return eContents;</small><br>
</blockquote>
It's a "view" on all the containment references...<br>
<br>
<br>
Tamar Cohen wrote:
<blockquote cite="mid:hv5mtu$ieo$1@build.eclipse.org" type="cite">Hi
EMF world --
<br>
..genmodel to extend FlatEObjectImpl instead of BasicEObjectImpl, the
<br>
<br>
follows:
<br>
extendedMetaData);
<br>
m_parserPool);
<br>
LE, Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
<br>
<br>
Boolean.TRUE);
<br>
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
Boolean.FALSE);
<br>
<br>
Boolean.TRUE);
<br>
<br>
its children?
<br>
<br>
thanks
<br>
<br>
Tamar
<br>
</blockquote>
</body>
</html>
--------------000100060008020703080503--
Ed Merks
Current Time: Sat Apr 27 01:23:03 GMT 2024
Powered by FUDForum. Page generated in 0.03679 seconds
