Home » Eclipse Projects » Eclipse 4 » Readiness of replacing a RCP app with e4
Readiness of replacing a RCP app with e4 [message #539618] Fri, 11 June 2010 09:37 Go to next message
Hi all
We have built our app on top of RCP because RCP provides us all the
components in the Eclipse platform.
We use:
*the Common Navigator
*Properties view
*Resource management
*Import/Export... the list goes on...
Are these components (re)usable in a plug-in created using e4?
Re: Readiness of replacing a RCP app with e4 [message #540114 is a reply to message #539618] Mon, 14 June 2010 20:41 Go to previous messageGo to next message
They're not usable in an e4 RCP app. They are usable in an
Compatibility Workbench RCP app, but since the compatibility layer
pretends to be the 3.6 API running on top of the modeled workbench, I'm
not sure what it would buy you (although it would run the CSS theming)
What would you like out of e4 that you don't think is available in 3.6?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Readiness of replacing a RCP app with e4 [message #540372 is a reply to message #540114] Tue, 15 June 2010 16:44 Go to previous messageGo to next message
So the package explorer that I see in the e4 UI, is that an e4 "navigator"
or is that using the navigator from 3.6 somehow?
I'm trying to figure how much work it would be to migrate an RCP app with
the mentioned features into an e4 app.
Cheers
Greg
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:hv6i37$m2c$2@build.eclipse.org...
> They're not usable in an e4 RCP app. They are usable in an Compatibility
> Workbench RCP app, but since the compatibility layer pretends to be the
> 3.6 API running on top of the modeled workbench, I'm not sure what it
> PW
> Paul Webster
Re: Readiness of replacing a RCP app with e4 [message #540518 is a reply to message #540372] Wed, 16 June 2010 08:48 Go to previous messageGo to next message
Which e4 UI? If you mean the e4 SDK, that's just 3.6 with the
development bundles installed. If you mean the 4.0 Early Adopter SDKs,
that's the 3.6 package explorer being hosted on an e4 modeled workbench
(org.eclipse.ui.workbench).
> with the mentioned features into an e4 app.
Right now, 3.x plugins can run using the compatibility layer. But
certain aspects of it don't work well at the moment (menus come to mind).
In the e4 world, you can write dependency injected parts, but there is
not support for the Project Explorer, your menus and commands have to be
written using the model, not the extension points, etc.
As for effort ... you would have to put in a fair bit of effort to move
to the e4 world, or you can run some tests with the compatibility layer
and your 3.6 views/editors/etc.
PW
Paul Webster
Re: Readiness of replacing a RCP app with e4 [message #540648 is a reply to message #540518] Wed, 16 June 2010 16:17 Go to previous message
Ok thanks Paul. Exactly the info I wanted.
Just one other thing - will there ever be a pure e4 project explorer? And if
so, will it be in the next year or so?
news:hvah24$tjc$1@build.eclipse.org...
> Which e4 UI? If you mean the e4 SDK, that's just 3.6 with the development
> bundles installed. If you mean the 4.0 Early Adopter SDKs, that's the 3.6
> Right now, 3.x plugins can run using the compatibility layer. But certain
> In the e4 world, you can write dependency injected parts, but there is not
> As for effort ... you would have to put in a fair bit of effort to move to
> the e4 world, or you can run some tests with the compatibility layer and
> PW
> Paul Webster
Re: Readiness of replacing a RCP app with e4 [message #577665 is a reply to message #539618] Mon, 14 June 2010 20:41 Go to previous message
PW
Paul Webster
Re: Readiness of replacing a RCP app with e4 [message #577747 is a reply to message #540114] Tue, 15 June 2010 16:44 Go to previous message
Cheers
Greg
> PW
> Paul Webster
Re: Readiness of replacing a RCP app with e4 [message #577841 is a reply to message #540372] Wed, 16 June 2010 08:48 Go to previous message
PW
Paul Webster
Re: Readiness of replacing a RCP app with e4 [message #577874 is a reply to message #577841] Wed, 16 June 2010 16:17 Go to previous message
> PW
> Paul Webster
Previous Topic:When are my (injected) POJO methods called?
Next Topic:Where does TableViewer select an entry?
Current Time: Thu Sep 11 01:52:37 EDT 2025
Powered by FUDForum. Page generated in 0.04807 seconds
